قديم 20-05-2011, 01:15 AM
الصورة الرمزية tarbook
tarbook tarbook غير متواجد حالياً
من انا؟: خالد صلاح الدين سمير
التخصص العملى: Computer Science
هواياتي: السيارات واسماك البحار
الموقع: مصر ام الدنيا القاهره
tarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond repute
افتراضي Refilling the Engine Coolant
Step 1 : Using a funnel start slowly pouring the coolant mix into the overflow tank.
Note : Take your time when pouring coolant back into your car The car will only accept new coolant at a certain rate and will easily overflow Do everything you can to avoid spilling coolant.
Step 2 : Fill the coolant up to the ( Cold ) mark on the passenger side of the tank You will find that if you wait a few moments when it gets to this mark the fluid level will go down Keep adding more fluid until it stops going down and stays at the Cold mark.
http://a7lashare.com//uploads/images...6234a3276a.jpg
Step 3 : Loosen the radiator bleed screw.
Step 4 : Turn the ignition to the On position .
Step 5 : Continue to slowly add coolant - adding more after the level has dropped.
Step 6 : Eventually coolant will start to bubble out of the bleed screw. When the bubbling has stopped and only fluid comes out of the bleed screw hole tighten the bleed screw while continuing to pour.
Step 7 : Replace the radiator cap.
Step 8 : Start the car and let it heat to the normal operating temperature.
Step 9 : Check for any obvious coolant leaks
BMW lover
اشهد ان لا اله الا الله وحده لا شريك له واشهد ان محمد رسول الله عليه افضل الصلاه والسلام على الحبيب المصطفى
قديم 21-05-2011, 04:38 AM
افتراضي رد: Refilling the Engine Coolant
سبحان الله
قديم 25-06-2011, 02:32 AM
:23_1 0_13:
قديم 25-06-2011, 04:44 AM
عايز افهم دى
يعنى الى قبلها فتحت مسمار تنفيث الهواء
طب دى حتعمل ايه لانى الى فاهمة العربية لسة مش مدورة مش حتدور الى فى الخطوة 8
قديم 25-06-2011, 03:05 PM
عايز افهم دى
انا هشرحهولك بالعميه بالبلدى ان شاء الله
بص يا جميل اول شى العربيه واقفه وبرده مش سخنه تروح فاتح غطه الريداتير وتحط ماء براحه فى الريداتير لحد العلامه بتاعت الماء والغطاء مفتوح تروح تفك مسمار الهواء
الى فى الصوره
وبعدين تجيب جنبك كام جركن ماء كده وتروح تدور العربيه تسبها شويه تقديرا 2 دقيقه لحد ما المأشر تحس انه ابتدى يطلع تروح مزود ماء بالراحه فى الريداتير وتعدى العلامه لان الماء هيطلع من المسمار على شكل بابيلز وتروح مزود شويه بنزين عشان الماء تتقلب فى الريداير وبعدين تزود ماء لحد ما تطلع البابيلز كلها من الريداتير اول ما تحس ان العربيه طلعت كل الهواء بتعها تروح رابط المسمار وتظبط الماء لحد العلامه بتعت منسوب الماء فى الريداتير بسس ادى كل الى فيها .
الموضوع لما يكون انجليش بيوصل المعلومه صح لانى مبعرفش اشرح عربى غير كده بطريقه بحس انها رخمه شويه
الساعة الآن 11:21 PM.
