قديم 14-04-2010, 11:25 AM
الصورة الرمزية بدر بسيونى
مشرف الكورى
من انا؟: مصرى
التخصص العملى: كيميائى
شيفورليه N200 او Wuling Rongguang
شيفورليه N200
او الاصل لتلك السيارة Wuling Rongguang من انتاج SAIC-GM-Wuling Automobile الصينية
وصنعت بالاتفاق مع جنرال موتورز لتتوجه فى الاساس للهند وانزلها منصور مصر باسم شيفورليهN200
السيارة الاصلية
المواصفات الفنية للسيارة الصينية
Technical Parameters
Wuling RongguangLZW6407B3-BasicLZW6407B3-StandardLZW6407B3-ComfortLZW6407B3-Luxury
Vehicle Dimensions Parameters
Length/Width/Height (mm)3995/1620/19004035/1620/19004105/1620/1900
Wheel Base(mm)2700
Tread (front/rear) (mm)1386/1408
Engine
Engine TypeLAQ
Displacement (ml)1206
Compression Ratio 9.8:1
Rated Power (kw/r/min)60.5/5300
Max Torque (N.m/r/min)108/4000
Driving modeRear wheel driving
Steering System
TypeMechanical steeringPower steering
Suspension System
Front Front-Mac Pherson strut
RearRear-leaf springRear-coil spring
Driving system
Transmission5 Forward speed with synchronizer
Tires175/70R14LT
Braking system
TypeFront disk & rear drum; double circuit, hydraulic brake system
Economical Parameters
50Km/h fuel consumption(L) ≤5.5
Fuel tank volume(L)45
EmissionChinese Standard Ⅲ / IV
Weight Parameters
Base Curb Mass (kg)1180
Gross weight (kg)1750/1850
Passenger quantity5~8
Power Parameters
Max Speed (km/h)≥130
Track Parameters
Min Turning Radius (m)5.2
Max Climbing Angle(°)≥16
اما سيارة منصور فبموديل واحد فقط
Technical Specifications
Engine Displacement (cc)1206
Compression Ratio9.8:1
Rated Power (HP/rpm)85 / 6000
Max. Torque (Nm/Rpm)108 / 4000
Fuel TypeGasoline
Five-Speed, Manual Transmissions
Electronic Fuel Injections
Catalytic Converters
Tires 165/70 R13s
Brake : Front Disk / Rear Drums
Front Door Power Windowss
Central Door Lock With Remote Controls
Seat Beits in all rawss
Outside Mirror W/Manual Outside Adjustments
Roof End Spoilers
Bumper Body colors
Body Color Front Grille Covers
Under Engine Stone Shields
Front & Rear Fog Lamps
Central High Mounted Stop Lights
Gauge / Speedometer / Trips
2 Speakerss
Radio W / MP3 with USB Interface Ports
Roof Antennas
2 Front Seats s
2nd Raw Benchs
3rd Raw Bench s
Power Steering0
Air Conditioning 0
Dimensions:
Wheel Base mm 2,500
Length mm3,860
Width mm 1,570
Height mm1,860
Passenger 8
والالوان المتاحة
قديم 14-04-2010, 03:07 PM
corsair
افتراضي رد: شيفورليه N200 او Wuling Rongguang
الله عليك يا استاذ بدر العربية ال m200 شكلها اجمل بكتير من الزفته السوزوكي الفان اللي الواحد خلاص اتخنق منها لكن الصين ديه عايشة علشان تقلد بس
قديم 14-04-2010, 06:57 PM
suzuki van 2010 suzuki van 2010 غير متواجد حالياً
suzuki van 2010 is on a distinguished road
بص على العربية دى السنادى والسنة اللى جاية
وشوف الفرق بين العربيتين السنة الجاية
متتريأش على الفان سوزوكى عشان مفيش فان زيها
انا اشتريت الاتنين فى يوم واحد على فكرة
اشتريت الفان والشيفورليه
وندمت والمصحف انى جيبت الشيفورليه
اكتشفت انها صينى اساسا ومنصور حط علامته التجارية عليها
لكن معلش عادى الحمد لله
قديم 14-04-2010, 08:26 PM
الصورة الرمزية acounter01
acounter01 acounter01 غير متواجد حالياً
من انا؟: الباشا
هواياتي: التليفونات المحمولة
الموقع: مصر
acounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond reputeacounter01 has a reputation beyond repute
يا باشا مش اجمل ولا حاجة
دي شكلها زي الميكروباص
ودي بردة شكلها زي الميكروباص
الفائدة الوحدية انها عائلية
قديم 28-04-2010, 10:23 PM
مشرف الكورى
من انا؟: مصرى
المشاركة الأصلية كتبت بواسطة acounter01 مشاهدة المشاركة
هى ميكروباص ياباشا
الساعة الآن 01:00 AM.
