Body Two Box 4 Door Hatchback
Brakes Front Disc brake Rear Drum brake
Dimension & weight Front Track - Fuel Tank Capacity 37 ltr Gross Vehicle Weight - Ground Clearance 165 mm Kerb Weight 1135 kgs Overall Height 1550 mm Overall Length 3795 mm Overall Width 1695 mm Rear Track - Wheelbase 2470 mm
Engine Bore X Stroke - Compression Ratio - Displacement 1405 cc No. cylinders / arrangement / Valves 4 cylinders Type 475 IDI Turbo Intercooled Diesel
Performance Max. Power 71 ps @ 4000 rpm Max. Torque 135 nm @ 1750 rpm
Steering Min. Turning Radius - Type Power Assisted Rack & Pinion - Hydraulic
Suspension Front Independent, lower wishbone, McPherson strut with coil spring Rear Semi-Independent, twist beam with coil spring and shock absorber
Transmission Transmission Type Synchromesh with overdrive
Tyres & Wheels Tyres 175/65 R14 Wheel Size -
Dimension & weight Front Track - Fuel Tank Capacity 37 ltr Gross Vehicle Weight - Ground Clearance 165 mm Kerb Weight 1140 kgs Overall Height 1550 mm Overall Length 3795 mm Overall Width 1695 mm Rear Track - Wheelbase 2470 mm
Engine Bore X Stroke - Compression Ratio - Displacement 1248 cc No. cylinders / arrangement / Valves 4 cylinders Type 4 Cyl., SDE common rail diesel
Performance Max. Power 75 ps @ 4000 rpm Max. Torque 190 nm @ 1750 rpm
Tyres & Wheels Tyres 175/65 R14 Wheel Size Radial Tubeless
Body Two Box 4 door Hatchback
Dimension & weight Front Track - Fuel Tank capacity 37 ltr Gross Vehicle Weight - Ground Clearance 165 mm Kerb weight 1075 kgs Overall Height 1550 mm Overall Length 3795 mm Overall Width 1695 mm Rear track - Wheelbase 2470 mm
Engine Bore x stroke - Compression ratio - Displacement 1172 cc No. cylinders / arrangement / Valves 4 cylinders Type 4 Cyl., multi point fuel injection
Performance Max. Power 65 ps @ 5500 rpm Max. Torque 96nm @ 3300 rpm
Transmission Transmission type Synchromesh with overdrive
Tyres & Wheels Tyres 175/70R 13 Wheel size -
_________________________ _________________________ ____________-
الموديل الرابع Indigo Manza
وبه 8 فئات
Indigo Manza Aura+ Safire
Body Three Box 4 door Sedan
Brakes Front Ventilated Disc Rear Drum
Dimension & weight Front Track - Fuel Tank Capacity 44 Litres Gross Vehicle Weight 1595 kg Ground Clearance 165 mm Kerb Weight 1125 kg Overall Height 1550 mm Overall Length 4413 mm Overall Width 1703 mm Rear Track - Wheelbase 2520 mm
Engine Bore X Stroke - Compression Ratio - Displacement 1368 cc No. cylinders / arrangement / Valves 4 Cylinders Type MPFI, Petrol with Intelligent Port Resizing
Performance Max. Power 90 PS@ 6000 rpm Max. Torque 116 Nm @ 4750 rpm
Steering Min. Turning Redius 5.1 m Type Power Assisted Rack & Pinion - Hydraulic, Tilt adjustable
Suspension Front Independent; Lower Wishbone; McPherson Strut with Coil Spring Rear Semi Independent; Twist Beam with Coil Spring and Hydraulic Shock Absorbers
Transmission Transmission Type 5+1-speed Manual
Tyres & Wheels Tyres 185/60 R15 Tubeless Radials Wheel Size 5.5 J x 15
Indigo Manza Aura (ABS) Safire
Dimension & weight Front Track - Fuel Tank Capacity 44 Litres Gross Vehicle Weight 1585 kg Ground Clearance 165 mm Kerb Weight 1115 kg Overall Height 1550 mm Overall Length 4413 mm Overall Width 1703 mm Rear Track - Wheelbase 2520 mm
Indigo Manza Aura Safire
Indigo Manza Aqua Safire
Dimension & weight Front Track - Fuel Tank Capacity 44 Litres Gross Vehicle Weight 1575 kg Ground Clearance 165 mm Kerb Weight 1100 kg Overall Height 1550 mm Overall Length 4413 mm Overall Width 1703 mm Rear Track - Wheelbase 2520 mm
Indigo Manza Aura (ABS) Quadrajet
Dimension & weight Front Track - Fuel Tank Capacity 44 Litres Gross Vehicle Weight 1650 kg Ground Clearance 165 mm Kerb Weight 1200 kg Overall Height 1550 mm Overall Length 4413 mm Overall Width 1703 mm Rear Track - Wheelbase 2520 mm
Engine Bore X Stroke - Compression Ratio - Displacement 1248 cc No. cylinders / arrangement / Valves 4 Cylinders Type Comman Rail Diesel
Performance Max. Power 90 PS@ 4000 rpm Max. Torque 200 Nm @ 7500 - 3000 rpm
الموديل الخامس Indigo XL
Indigo XL Diesel
Body Three Box 4 door Saloon
Brakes Front Discs Rear Discs
Dimension & weight Front Track - Fuel Tank capacity 42 litre Gross Vehicle Weight 1585 kg Ground Clearance 165 mm Kerb weight 1185 kg Overall Height 1540 mm Overall Length 4377 mm Overall Width 1620 mm Rear track - Wheelbase 2650 mm
Engine Bore x stroke - Compression ratio - Displacement 1396 cc Fuel System DICORE No. cylinders / arrangement / Valves Direct Injection Common Rail
Performance Max. Power 70PS/4000rpm Max. Torque 140Nm/1800-3000rpm
Steering Min. Turning Radius 5.5 mm Type Rack and Pinion Type with Collapsible Steering Column
Suspension Front Independent Mcpherson Strut with Coil Spring and Anti-roll Bar Rear Independent 3-link McPherson Strut with Anti-roll Bar
Transmission Transmission Type -
Tyres & Wheels Tyres 175/65 R14 (Tubeless) Wheel size 9 Spoke Alloy Wheels
Indigo XL Petrol
Dimension & weight Front Track - Fuel Tank capacity 42 litre Gross Vehicle Weight 1550 kg Ground Clearance 165 mm Kerb weight 1150 kg Overall Height 1540 mm Overall Length 4377 mm Overall Width 1620 mm Rear track - Wheelbase 2650 mm
Engine Bore x stroke - Compression ratio - Displacement 1396 cc Fuel System MPFI No. cylinders / arrangement / Valves 16 Valve Twin Cam with 32-bit Microprocessor
Performance Max. Power 101PS/6100rpm Max. Torque 124Nm/3500rpm
الموديل السادس IndigoCS
وبها 4 فئات
IndigoCS LE
Brakes Front Ventilated Dics Rear Drum
Dimension & weight Front Track - Fuel Tank capacity 42 Litres Gross Vehicle Weight 1510 kg Ground Clearance 165 mm Kerb weight 1065 kg Overall Height 1540 mm Overall Length 3988 mm Overall Width 1620 mm Rear track - Wheelbase 165 mm
Engine Bore x stroke - Compression ratio - Displacement - Fuel System Turbocharged diesel engine with Intercooler No. cylinders / arrangement / Valves -
Performance Max. Power 70 PS @ 4500 rpm Max. Torque 135 Nm @ 2500 rpm
Steering Min. Turning Radius 5.0 m Type Vacuum assisted dual circuit, diagonal split hydraulic brakes through tandem master cylinder
Suspension Front Independent McPherson strut with Antiroll Bar Rear Independent 3- link Mc Pherson strut with Antiroll Bar
Transmission Transmission Type Manual-5 speed
Tyres & Wheels Tyres Radial Wheel size 165 x 65 R 14
Engine Bore x stroke - Compression ratio - Displacement - Fuel System MPFI Petrol engine with 32 bit microprocessor No. cylinders / arrangement / Valves -
Performance Max. Power 65 PS @ 5200 rpm Max. Torque 105 Nm @ 2600 rpm
Tyres & Wheels Tyres Radial Wheel size 175 x 65 R 14
الموديل السابع Marina
وبه 7 فئات
Marina LX Dicor
Brakes Front Ventilated disc brake Rear Drum brake
Dimension & weight Front Track 42 Litres Fuel Tank capacity - Gross Vehicle Weight 1565 kg Ground Clearance 165 mm Kerb weight 1130 kg Overall Height 1575 mm Overall Length 1458 mm Overall Width 1625 mm Rear track - Wheelbase 2450 mm
Engine Bore x stroke - Compression ratio - Displacement 1366 cc Fuel System 32-bit microprocessor based DICOR(Direct Injection Common Rail) No. cylinders / arrangement / Valves 16-valve engine with Dual Over Head Camshafts and a Variable Geometry Turbocharger(VGT)
Performance Max. Power 70PS @ 4000 rpm Max. Torque 140 NM @ 1800-3000 rpm
Steering Min. Turning Radius 5.0 m Type Rack and pinion type with collapsible steering column
Suspension Front Independent, lower wishbone, McPherson strut, with anti-roll bar Rear Independent, 3-link, McPherson strut, with anti-roll bar and gas-filled dampers
Tyres & Wheels Tyres Radial Wheel size 175/65 R14
Marina LX TDI (New)
Engine Bore x stroke - Compression ratio - Displacement 1405 cc Fuel System Turbo Charged Indirect Injection Engine with Intercooler No. cylinders / arrangement / Valves -
Performance Max. Power 70PS @ 4500 rpm Max. Torque 13.5 kgm @ 2500 rpm
Marina GSX (New)
Engine Bore x stroke - Compression ratio - Displacement 1396 cc Fuel System MPFI Petrol engine with 32-bit Microprocessor No. cylinders / arrangement / Valves -
Performance Max. Power 85 PS @ 5500 rpm Max. Torque 12 kgm @ 3500 rpm
Marina GLX (New)
Marina LS TDI (New)
Marina SX TDI (New)
الموديل الثامن نانو
وبها 3 فئات
Nano LX
Brakes Front 180 mm Drum Brake With Vacuum Booster Rear 180 mm Drum Brake With Vacuum Booster
Dimension & weight Front Track - Fuel Tank Capacity 15 Liters Gross Vehicle Weight - Ground Clearance 180 mm Kerb Weight 635 kg Overall Height 1652 mm Overall Length 3099 mm Overall Width 1465 mm Rear Track - Wheelbase 2230 mm
Engine Bore X Stroke - Compression Ratio - Displacement 624 cc No. cylinders / arrangement / Valves 2 cylinders Type MPFI
Performance Max. Power 35ps @ 5250 rpm Max. Torque 48 nm @ 3000/500 rpm
Steering Min. Turning Radius 4 m Type -
Suspension Front Independent, Lower Wishbone, McPherson Strut with gas filled dampers Rear Independent, Semi Trailing arm with coil spring & gas filled shock absorbers
Transmission Transmission Type 5 - Speed Manual Transmission, One Reverse
Tyres & Wheels Tyres (f-r) Front 135/70 R12 - Rear 155/65 R12 Radial Tubeless Wheel Size 4 B x 12
Nano
Brakes Front 180 mm Drum Brake Rear 180 mm Drum Brake
Dimension & weight Front Track - Fuel Tank Capacity 15 Liters Gross Vehicle Weight - Ground Clearance 180 mm Kerb Weight 600 kg Overall Height 1652 mm Overall Length 3099 mm Overall Width 1465 mm Rear Track - Wheelbase 2230 mm
Dimension & weight Front Track - Fuel Tank Capacity 15 Liters Gross Vehicle Weight - Ground Clearance 180 mm Kerb Weight 615 kg Overall Height 1652 mm Overall Length 3099 mm Overall Width 1465 mm Rear Track - Wheelbase 2230 mm
التعديل الأخير تم بواسطة بدر بسيونى ; 07-02-2010 الساعة 12:54 PM
07-02-2010, 01:39 PM
رد: تقرير شامل عن جميع موديلات تاتا الهندية
شكرا ياباشا عالمجهود الكبير وعمار يا هند
مغترب مصراوى لبلده هاوى
07-02-2010, 01:55 PM
شكرا يا باشا على المجهود الجبار ده
على فكرة، فين مستوردينا من الإنتاج الهندى؟
07-02-2010, 03:31 PM
مشرف الكورى
من انا؟: مصرى
التخصص العملى: كيميائى
المشاركة الأصلية كتبت بواسطة moslem2
شكرا ياباشا وربنا يخليك
المشاركة الأصلية كتبت بواسطة atgps
فعلا احنا مش بنستورد من الهند الاالسوزوكى الماروتى والالتو والسكوربيو ماهيندرا بس فعلا تاتا مؤخرا بدات تظهر فى الساحة
14-02-2010, 04:18 PM
يا أخوانا أنا سمعت أن تاتا دى كل عربياتها رخيصة جدا جدا دا غير كدة أنهم أشتروا شركة جاجوار و شركة لاندروفر يعنى أكيد مش هتعمل أى حاجة يعنى
فعايزين الأهتمام شوية بتاتا دى لحد مانشوف أية نظامها
و أنا شوفت نانو المصريه لكن مشوفتهاش على الواقع على النت بس و سعرها حوالى من 20 إلى 25 فى الحدود دى
ptmnlo123per1147 صباح الفـــــــــــــــل ptmnlo123per1147
MasrMotors غير مسؤول عن أي
اتفاق تجاري أو تعاوني بين الأعضاء
التعليقات المنشورة لا تعبر عن رأي MasrMotors ولا نتحمل أي مسؤولية قانونية حيال ذلك
ويتحمل كاتبها مسؤولية النشر
الساعة الآن 10:43 AM .
Powerd BY eplusweb
Designing BY abo-karim
