قديم 15-09-2009, 08:50 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Frankfurt 2009: Audi S5 Sportback unveiled. No, you can't have this one, either.
Filed under: Frankfurt Motor Show, Performance, Europe, Hatchback, Audi
Audi S5 Sportback - Click above for high-res image gallery
If you're annoyed that the Audi A5 Sportback isn't going to be made available in the U.S., you might as well stop reading now, because this will probably be upsetting to you. Audi has just formally announced the S5 Sportback, which, as you likely gathered, kicks things up with the blown 3.0L V6 that's standard kit in the S4, available in the A6, and will shortly replace the V8 as the motivator under the S5 coupe's hood. Quattro is standard, as is the seven-speed S tronic twin-clutch gearbox; a sport differential can be added at extra cost.
Other standard S-car bits include the metallic-finished mirrors, quad pipes, snazzy S-design wheels (dubs are optional), and polished vertical grille slats. Basically, it's the S5 with two extra doors and a hatchback. It's probably a blast to drive, and it demonstrates that you can turn a standard model into a sporty hatch without going all Crosstour.
Power from the six is 333 horses and 324 lb-ft - good for a 5.4-second run to 62 mph (100 km/h) and an electro-nannied 155-mph top end. Audi says that the powertrain's good a smidge over 24 mpg - with whose grandmother behind the wheel, we have no idea. Inside? You know the deal - it's nice. Starting price when it lands in Deutschland Audi stores this spring will be €57,900, demonstrating that more sensible fun doesn't necessarily come on the cheap. Check out a slew of additional pics in the gallery below, and the official flowery-language press release after the jump.
Gallery: Audi S5 Sportback
[Source: Audi]
Continue reading Frankfurt 2009: Audi S5 Sportback unveiled. No, you can't have this one, either.
Frankfurt 2009: Audi S5 Sportback unveiled. No, you can't have this one, either. originally appeared on Autoblog on Mon, 14 Sep 2009 19:29:00 EST. Please see our terms for use of feeds.
Permalink | Email this | Comments
أكثر...
الساعة الآن 07:23 AM.
