قديم 18-09-2012, 09:34 AM
fourseasons fourseasons غير متواجد حالياً
fourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond reputefourseasons has a reputation beyond repute
افتراضي بدائل قطع الغيار للوزة حبيبتى
كنت بتصفح موقع اجنبى كده عشان اشوف البوجيهات ال تصلح لعربيتى لقيت موقع كاتب حاجات كتير والبدائل بتاعتها .معلش الموضوع بالأنجليزى و حاحاول اترجمه .ولو شايفين الموضوع قيم نرجو التثبيت
Spark Plugs
Dimension : Specs 14mm thread size, Reach 19mm Hex Size 16mm
Factory install : Bosch FR7DTC (Triple earth electrode)
Some alternatives
BOScH FR7DC, FR7DCX etc
Denso K20PRU-11,K20PBR etc (normal),IK20 (Iridium), VK20 (Iridium/Platinum)
NGK BKR6E-11
Oil Filter
Dimensions: Height 81.8mm, Outer Diameter 82mm, Thread M20mm X 1.5mm (most important)
Factory install : Fleetguard (Shanghai factory) LF3881 Chery part no. 481H-1012010
Compatible oil filter, many Honda( e.g. 15400-PR3-0050), Mazda, Subaru,
Hyundai Sonata oil filter
Izuzu Gemini
Osaka 8-94217272-0
K&N HP-1004
FRAM PH3593A
Air filter
shape Rectangular panel, Dimensions: Height: 40 mm, Outside Length: 245 mm Outside Width: 220 mm
Chery Part no. A21-1109111
K&N air filter 33-2658 * may fit
K&N air filter 33-2054 * most likely to fit
Simota, ESE and hurricane
TOYOTA 1780107020, 1780146060 (alternatives are non-exact fit)
Wiper Blade
Hook type, Right 550mm Left 500mm
Factory install : Valeo, Right c/w spoiler
Alternatives, NWB, RainX (reinstall spoiler if possible)
Alloy wheel
Chery Part No: A21-3100020AM
ET 46 (offset in mm), 15X6JJ (15 inch, width 6 inch), max load 600kg, Bolt pattern 4X 114.3mm (4.5inch)
Tyre 195/55R15 V(speed rating)
Possible upgrade for tyres (no inch up) 205/50R15
(inch up) 205/45R16
(2 inch up) 205/40R17
Front Brake pads
Chery Part No: A21-3501070 (for A5 1.6L w/o electronic wear sensor)
width 119mm, Height 69.5mm, Thickness 19.3mm
Friction coefficient FF (important DO NOT Downgrade)
Note : there is another part with electronic wear sensor that appears on earlier A5, Chery part no: A21-3501080
Same as old Audi front brake pads
Alternatives: FBK, Honeywell,Nbrake NDB211, Mintex MDB1190, AUDI 443698151, VW 431698151 (Please compare first)
Rear Brake pads
Chery Part No: A21-3501090
Width 107.6mm, Height 42.5mm, Thickness 16mm
Similar to Toyota Camry (V1,V10,V20,V30 etc), Toyota Corolla (E11)
Mintex MDB1994, Toyota 0446620070 etc (many different part numbers), Nbrake NDB8067, Akebono
Front Disc Rotors
Chery Part No: A21-3501075
Internally Ventilated (double layer)
Bolt pattern 4X114.3mm + single screwhole
Diameter 240mm, Brake Disc Thickness 22mm, Height 48mm, Pitch Circle 150mm, Centering Diameter 68mm (approximate measurements)
Rear Disc Rotors
Chery Part No: A21-3502075
Brake Disc Type solid
Diameter 260mm, Brake Disc Thickness 10mm, Height 60mm, Pitch Circle 182 mm, Centering Diameter 68 mm (approximate measurements)
Ignition coil
Factory Install Bosch 0 221 503 485, Chery Part No: A11-3705110EA
Alternatives Valeo 245040, FIAT 9607405480, CITROEN 597060, PEUGEOT 597048 topline TIc 8040 (Malaysia)
Front Dampers
OEM Sachs (Shanghai)
chery part no. A21-2905010
Rear Dampers
Chery Part no. A21-2915010
Air flow sensor
4 Pins Terminal, 5V
Factory Install for 1.6L,made in Germany BOSCH 0 261 230 099 (intake manifold absolute pressure sensor), Chery part no: 480ED-108060
Alternatives FORD 2U1L 9F479 AA, OPEL 93 399 801, Honda Jazz 37830PWEG01
Note : for 2.0L, it is a different part from BoscH (also used in Audi A4 2006)
Exhaust tail pipe outer diameter 2 inch approx
ارجو يفيدكوا الموضوع
يا رب انصر مصر و لم شمل المصريين
قديم 18-09-2012, 09:25 PM
الصورة الرمزية sayif
sayif sayif غير متواجد حالياً
التخصص العملى: IT -Information Technology
هواياتي: Auto & Technology
الموقع: Iraq-العراق
sayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond reputesayif has a reputation beyond repute
افتراضي رد: بدائل قطع الغيار للوزة حبيبتى
شكرا على هذا الجهد واتمنى ارسال ام الموقع على النت
اطييب تحية
سيف العراق
قديم 18-09-2012, 10:28 PM
cmatcho cmatcho غير متواجد حالياً
cmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond reputecmatcho has a reputation beyond repute
عايزين ترجمه
قديم 19-09-2012, 11:29 PM
vipper_san vipper_san غير متواجد حالياً
من انا؟: محمد السيد
التخصص العملى: رائد فضاء
الموقع: الجيزة
vipper_san has a spectacular aura aboutvipper_san has a spectacular aura aboutvipper_san has a spectacular aura about
طب الدينامو ظروفه ايه
قديم 20-09-2012, 09:01 AM
الترجمة بس على قدى شوية
• Spark Plugs: البوجيهات
Dimension : Specs 14mm thread size, Reach 19mm Hex Size 16mm الأبعاد
Factory install : Bosch FR7DTC (Triple earth electrode) البوجيه المركب من المصنع
Some alternatives بعض البدائل
BOScH : FR7DC, FR7DCX etc
Denso: K20PRU-11,K20PBR etc (normal),IK20 (Iridium), VK20 (Iridium/Platinum)
NGK: BKR6E-11
• Oil Filter فلتر الزيت
Dimensions: الأبعاد
-Factory install المصنع
-Compatible oil filter, بعض البدائل
Izuzu Gemini
Osaka 8-94217272-0
K&N HP-1004
FRAM PH3593A
• Air filter فلتر الهواء
المصنع
البدائل
Wiper Blade المساحات
Alternatives, البدائل
Alloy wheel الجنوط
Possible upgrade for tyres مقاس الجنوط المسموح تركيبها
(inch up) 205/45R16
Front Brake pads تبل فرامل امامى
البدائل
Rear Brake pads تيل فرامل خلفى
Front Disc Rotors طنابير امامية
المواصفات
Rear Disc Rotors طنابير خلفيةن
Ignition coil موبنة التقويم
Front Dampers مساعد الأمامى
Rear Dampers مساعد خلفى
Air flow sensor حساس الهواء
4 Pins Terminal, 5V
الأصلى
البدائل
الساعة الآن 07:41 AM.
