قديم 10-06-2009, 01:30 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Kia recalling 2001-2004 Optima sedans in rust-prone states over subframe corrosion
Filed under: , , ,
The 2001-2004 Kia Optima is being recalled in several states for corrosion of the front subframe. The recall covers some 36,538 examples sold in the U.S. in the following states: Connecticut, Delaware, Illinois, Indiana, Iowa, Main, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, Wisconsin, and the District of Columbia - all areas typically noted for being high rust threats due to their difficult winters and use of road salt.
According to the recall, internal corrosion of the front subframe can weaken the mounting points near the lower control arm, leading to everything from irregular tire wear to abnormal stress levels in the system that may contribute to a cras.
The recall begins this month, but neither Kia nor NHTSA have outlined a potential fix in the recall notice posted after the jump.
[Source: NHTSA]
Continue reading Kia recalling 2001-2004 Optima sedans in rust-prone states over subframe corrosion
Kia recalling 2001-2004 Optima sedans in rust-prone states over subframe corrosion originally appeared on Autoblog on Tue, 09 Jun 2009 18:20:00 EST. Please see our terms for use of feeds.
Read | Permalink | Email this | Comments
أكثر...
الساعة الآن 02:37 AM.
