قديم 31-05-2009, 03:10 PM
الصورة الرمزية د0تامر محمد
د0تامر محمد د0تامر محمد غير متواجد حالياً
من انا؟: طبيب بشرى -كاتب قصة وروائى
التخصص العملى: طبيب بشرى
هواياتي: الكتابه خاصه الادبيه -السيارات
الموقع: الشرقيه
د0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond repute
سيارات فاو الصينية
سيارات فاو الصينية
SUV
المواصفات
CA6480P6E
Passenger Capacity5-7
Weights and Capacities (kg)
Load Capacity
Front Axle Curb Weight874
Rear Axle Curb Weight621
Total Curb Weight1,495
Front GAW (gross axle weight)870
Rear GAW1,450
GVW (gross vehicle weight)2,320
Dimensions (mm)
Overall5,140×1,790×1,825/1,840/1,925/1,940
Pickup Bed (interior)
Wheelbase3,025
Axle Track (front/rear)1,460/1,450
Spring Center to Center (front/rear)780/1,335
Performance
Max. Gradeability (%)31
Top Speed (km/h)135
Min. Turning Diameter (m)12
Braking Distance (m) (from 60km/h at full load)≤61.2
Min. Ground Clearance (mm)185
Approach/Departure Angle (°)(front/rear)27/23
Fuel Consumption (L/100km at 60km/h with full load)9
Max. Exterior Noise Level (dBA) 77
Max. Operating Range (km) 400
Engine
Model JM491Q-ME/XG491Q-ME
Type 4 Cylinder Inline, OHC, Multi-point Fuel Injection
Displacement (L)2.237/2.237
Peak Power (kW) @ rpm 76 @ 4,200-4,600
Max.Torque (N.m) @ rpm 193 @ 2,000-2,600
Bore & Stroke (mm)91×86
Compression Ratio 8.8:1
Emissions RatingEuro-2
Fuel Capacity (L) 60
Clutch Dry Single Plate, Diaphragm Type, Dampened
Gear-box5 Speeds Forward / 1 Reverse, Overdrive in 5th, Synchronized
Steering system Integral Power Steering, Gear Ratio 23.76 (Optional Power Steering)
Propeller Shaft Spicer type, 2 section with hanger bearing
Cab 5 Door SUV
Frame Ladder Type, Channel Section Side Rail, Riveted Boxed Construction
Rear AxleHypoid Single Reduction, Fabricated Axle Housing, Semi-floating, Ratio 4.55
Front SuspensionCoil-spring Double Wishbone with Double Acting Telescopic Shoc Absorbers
Rear SuspensionLeaf Spring Suspension with Double Acting Telescopic Shock Absorbers
Tires 215/75R15
Brake SystemDual Circuit Hydraulic System with Vacuum Assist
Body
Electrical System 12V, Negative Ground
Hongqi HQ3
المواصفات
THE TECHNICAL PARAMETERS OF HQ3
Technical ParametersHQ430HQ300
Type for Succeed personsType For GrandType For Business
General Construction
Overall Length(mm)49654965
Overall Width(mm)17951795
Overall Height(mm)14851485
Wheelbase(mm)28502850
Tread Front/Rear (mm)1535/15351535/1535
Turning Radius Min.(m)5.25.2
Luggage Compartment Capacity (VDA Type) (L)430430430
Nominal Total Weights (kg)177517301730
GR Clearance W/Axle (mm)150150
Parameter of Wind Resistance0.270.27
Safe Level of PassivityNCAP 5 NCAP 5
Power Assy
Marking of Engine3UZ-FE3GR-FE
Engine TypeV8/DOHC/32V (VVT-i)V6/DOHC/24V (DUAL-VVT-i)
Engine TechnicsETCS-i, ACIS
Engine Capacity(cc)42922995
Max Power and Rpm Max Power(Kw/rpm)206/5600170/6200
Max Torque(Nm/rpm)430/3400300/4400
Compression Ratio10.510.5
OilNo Plumbum Gasoline Beyond 95# No Plumbum Gasoline Beyond 95#
Fuel Tank Capacity(L)7070
EC(L/100km)11.310.1
EC90km/h(L/100km)6.95.8
0-100km/h ACCELERATED TIME(s)7.38.7
Max Speed(km/h)250235
TransmissionA761E 6ATA760E 6AT
Drive TypeEngine Front Configaration and Rear Drive Engine Front Configaration and Rear Drive
Tyre and Chassis
Tyre Size215/55 R17215/55 R17
Spare Wheel StandardFull DimensionFull Dimension
FR Suspension TypeDouble Wishbone, Coil, Have Subframe (Member) , Have Bar, Stabilizer
RR Suspension TypeMultilink, Coil, Have Subframe (Member), Have Bar, Stabilizer
FR/RR BrakeVentilated Disc Brake with Floating Caliper 1-Cylinder
Power Control SystemABS, EBD, BA, TRC, VSC, HAC
Besturn
المواصفات
Besturn 2.3 AT
Besturn 2.0 AT
Comfort
Luxury
Premium
Comfort
Luxury
Premium
Dimensions
Length/Width/Height (mm)
4,705 / 1,782 / 1,465
Wheelbase (mm)
2,675
Track (front/rear) (mm)
1,540 / 1,540
Weight
Curb Weight (kg)
1,470
1,460
Performance
145
148
Fuel Consumption(L/100km at 90km/h)
6.4
6.2
Engine
Engine Model
L3
LF
Engine Type
DOHC 16-valve inline 4-cylinder engine with variable valve timing (S-VT)
Engine Displacement (L)
2.261
1.999
Peak Power (kW/rpm)
120 / 6,500
108 / 6,500
Max. Torque (Nm/rpm)
204 / 4,000
183 / 4,000
Transmission
5-speed sequential-shift electronically controlled automatic transmission with intelligence
Wheels and Tires
205/55R16 91V tires with 16 x 7.0J aluminum alloy rims
Suspension
Double wishbone independent front suspension with anti-roll bar
E-type multi-link independent rear suspension with anti-roll bar
Brake System
ABS+EBD+TCS+EBA
DSC(Dynamic Stability Control)
CCS
Cruise Control System
Safety
Dual Front Airbags(dual stage)
Front Side Airbags (seat-mounted)
Front and Rear Side Curtain (SRS) Airbags
Safety belt alert
Exterior Features
Halogen Headlamps
High-Intensity Discharge (HID) Headlamps with auto-leveling and cleaning functions
Power-adjustable outside mirrors (passenger side with wide-angle feature )
Power-adjustable and heated outside mirrors (power-folding, passenger side with wide-angle feature)
Interior Features
Multi-function leather-trimmed steering wheel with audio and cruise control functions
Multi-function leather-trimmed steering wheel with audio functions
Height/Angle adjustable Steering Column
Power-assisted rack-and-pinion steering with engine-speed-sensing variable power assist
Central Information Displayer(Computer)
Auto-dimming inside rearview mirror
Auto-dimming inside rearview mirror with integrated compass and electronic parking assist display
Rear window sunshade
GPS Navigation System
Multi-Media Displayer (with DVD player)
Audio System
6 speaker sound system
4 speaker sound system
AM/FM digital tuner with integrated single-feed, six-disc CD auto-changer
Air Conditioning
Automatic climate control with pollen filter
Seating
Woven fabric seating
Velour cloth seating
Leather seating
6-way manually-adjustable driver's seat
8-way power-adjustable driver’s seat
8-way power-adjustable driver’s seat (heated)
Driver's seat with manually-adjustable lumbar support
4-way manually-adjustable front passenger's seat
4-way power-adjustable front passenger's seat
4-way power-adjustable front passenger's seat (heated)
Heated rear seat
Moonroof
Power sliding-glass moonroof with interior sunshade
Note: "●" Standard "-" N/A
قديم 31-05-2009, 06:44 PM
الموقع: الشرقيه
افتراضي رد: سيارات فاو الصينية
فاو الصينية هى شركة
تصنيع السيارات فى الصين. فاو الصين رقم 1 لصناعة السيارات.
تأسست الشركة في عام 1953.
فاو الذباب سماء واسعة في أنحاء من العالم ، ونشر اجنحته وارتفاع عال ، والآن في مشرق السماء الزرقاء
في عام 1988 ، كرايسلر بيع جزء كبير من الآلات والمعدات ، فضلا عن الترخيص لتصميم كاف من السيارات 2.2 لتر على التوالي - 4 المحرك الأول للسيارات الأشغال
l .
فاو تعمل العديد من المشاريع المشتركة في الصناعة التحويلية اهتمامات الصين. سيتشوان فاو تويوتا موتور (مدينة تشانغتشون بمقاطعة جيلين) وتنتج شركة تويوتا الطراز فاو أيضا في مشروع مشترك مع روسيا خبى فى منجم تشونغشينغ Altaysky Kray لانتاج نسخة محلية من منجم تشونغشينغ الادميرال.
شركة مجموعة اف ايه دبليو الصين ، ويشار إلى فاو نظرا الى الاسم الأصلي للالسيارات الاولى ، وكسر لأول مصنع 15 يوليو 1953.
ومنذ ذلك الحين ، تم فاو في طليعة تشجيع صناعة السيارات فى الصين.
وبدأت الحياة على الرغم من فاو مجرد منتج للشاحنة ، وسعت في وقت لاحق في ضوء الرسوم قطاع السيارات والشاحنات
في عام 1991 ، والعمل في شراكة مع شركة فولكس واجن إيه جي ، وفاو خلق حالة جديدة من أحدث منشأة لانتاج سنوي مع طاقة انتاجية تزيد عن 150،000 وحدة.
في عام 2002 ، وصناعة السيارات فى تيانجين (مجموعة) شركة تم دمج شركة مجموعة اف ايه دبليو ، وبدأ الإنتاج في مشروع مشترك مع شركة تويوتا.
وفي الوقت الحالي ، الإنتاج الحالي للفاو وضع استراتيجيات أشد التركيز على إنتاج السيارات مع المحافظة على مركز مهيمن في صناعة الشاحنات.
s.
فاو 27 التابعة المملوكة بالكامل وغالبة في الشركات الفرعية المملوكة جزئيا 20. ومن بين هذه فاو سيارات المحدودة وقطع غيار السيارات المحدودة ، وهي الشركات الفرعية المملوكة بالكامل ؛ فاو السيارات المحدودة ، وشركة فاو شيالى تم تيانجين للسيارات المحدودة وتشانغتشون للسيارات شركة فاو Sihuan المحدودة ، ويتم تداول اسهمها في البورصة ، وفاو فولكسفاجن - السيارات المحدودة وتيانجين فاو تويوتا موتور المحدودة ، والتي هي غير ذلك مشروعات مشتركة صينية اجنبية.
FAW's .
فاو إنتاج قواعد توزع بالتساوي في شمال شرق الصين وشمال الصين ومقاطعة شاندونغ الشرقية ، وجنوب غرب الصين.
FAW.
فاو أيضا مركز تكنولوجيا متقدمة للبحث وتطوير المنتجات الجديدة ، والتكنولوجيا ، والمواد في الصين. شركة إجمالي أصول تبلغ قيمتها 102.4 مليار يوان (12.4 مليار دولار أمريكي) مع أكثر من 132.400 موظف.
فاو توسعت منتجاتها الى 6 فئات مختلفة من بينها مركبات خفيفة ومتوسطة ، والشاحنات الثقيلة والسيارات والحافلات وسيارات صغيرة ووصل اجمالى قيمة مبيعات تتجاوز 7 ملايين سيارة.
فاو قد تمكنت من الحفاظ على موقف الرائدة في السوق المحلية في الوقت الذي توسع في أسواق عالمية جديدة ، وتنفيذ مخطط بعناية لبناء استراتيجية عالمية شاملة.
من أجل العمل على تحقيق حلمنا "لندع كل أسرة الصينية الخاصة سيارة" ، ونحن نجري لقيمة أساسية من قيم "أول سيارة ، أول شريك" وإدارتنا مفهوم "العرف الأولى". حاليا ، فاو الموظفين يعملون بجد لبناء جديد للفاو ، وهدفها أن تمكن رقميا ، لتصبح صناعة السيارات مع مجموعة واحدة بطاقة مليون وحدة ، والكفاءة في السوق الدولية.
في كانون الأول / ديسمبر 2001 ، فاو عقدت الدورة 11th الممثل للحزب المؤتمر السنوي للشركة اجتماعا مع ممثلي الحكومة في اللجنة المركزية ، وأعلن أن أكملت بنجاح فاو الثالث منحدر بين مرحلة خلال الفترة 1988-2001 ، واكثر من الضعف الإنتاج والتسويق في نطاق المبيعات والدخل والأرباح ، ودخل الموظف. في عام 2002 ، ومدد فاو أهدافها ، وأعلن التغييرات ذات الصلة لانضمام الصين الى منظمة التجارة العالمية ، التي تضمن للشركة استمرار النمو في السوق العالمية. فاو تدخل مثيرة وديناميكية العصر الجديد. من بداية متواضعة في عام 1953 ، فاو أصبحت لاعبا رئيسيا للسيارات في جميع أنحاء تحت قيادة رائعة برفقة بارزا من الموظفين المخلصين ، وبكل فخر فاو هى على وشك أن يصبح معيارا للابتكار ، وارضاء العالم مع أفضل السيارات والشاحنات.
منقول من موقع فاو
قديم 31-05-2009, 07:00 PM
الصورة الرمزية حازم شاهين
من انا؟: متسامح و حسن النية
الموقع: بورسعيد
مجهود رائع وإن كنت أعيب على الدكتور الأديب عدم التصرف فى الترجمة
و لكن شكرا جزيلا على مجهوداتك لتعريفنا على العناصر الخفية للإعصار القادم فى صناعة السيارات
قديم 31-05-2009, 09:24 PM
الصورة الرمزية SENY
SENY SENY غير متواجد حالياً
SENY has a spectacular aura aboutSENY has a spectacular aura about
الاسعار لو سمحت
شكرا علي الموضوع الجميل
قديم 01-06-2009, 12:25 AM
الموقع: الشرقيه
بالنسبة للترجمة لم اتدخل
هذا النص المترجم بواسطة جوجل وعذرا لضيق الوقت
الا يرى الجميع ان هذه السيارات الغير موجودة بمصر اكثر جودة وفخامة من سيارات اخرى صينية منتشرة بمصر !!
مع العلم ان فاو تعتبر اقدم شركات صناعة السيارات فى الصين ولها شاحنات عملاقة تصدر بكثافة الى الخارج
مكتب استيراد سيارات مستعملة من الخارج!! ahmed199 جمارك السيارات 3 05-12-2014 10:17 PM
الساعة الآن 05:46 PM.
