قديم 31-05-2009, 02:29 AM
الصورة الرمزية د0تامر محمد
د0تامر محمد د0تامر محمد غير متواجد حالياً
من انا؟: طبيب بشرى -كاتب قصة وروائى
التخصص العملى: طبيب بشرى
هواياتي: الكتابه خاصه الادبيه -السيارات
الموقع: الشرقيه
د0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond repute
أحدث سيارات شيرى الصينية
موديلات شيرى
خاص بمصر موتورز 00غير قابل للنقل
A3 سيدان وهتشباك
المواصفات للهاتشباك
Powertrain1.6MT1.8MT
Measure and weight
Length x width x height   mm4282×1792×1467
Wheelbase         mm2550
Tread(front/rea)      mm1550/1540
Kerb weight        kg1350
Minimum ground clearance  mm157
Turning diameter       m10.9
Tire specs205/55R16
Engine
ModelACTECO-SQR481FACTECO-SQR481FC
Type4-In line、16 vavles、DOHC
Displacement       cc15971845
Max. output         kW/rpm87.5/615097/5750
Max. torqe         N.m/rpm144/4300170/4300
Compress ratio10.5
Max. speed        km/h174175
Transmission5MT5MT
Oil tank capacity57L
EmissionEUⅣ+OBD
Brake/suspension/drivetrain
Brake system(front/rear)Ventilation Disc/Disc
Suspension(front/rear)Front suspension:Macpherson strut Independent type
Rear suspension:Multilink Independent type
DrivetrainFF
Main Equipment
MODELBasicStandardComfortableLuxury
Safety
Color-keyed anti-scraping bar
Color-keyed anti-scraping bar with shines strip
Front 3-point seat belt with
pretensioner(PT) & L/L
ABS+EBD
ESP(ABS+EBD+TCS)
Driver and front passenger airbags
Side airbag
Front and rear curtain airbag
Automatic lamp light
Common back radar
Automatic wiper
Theft alarm system
Exterior
Electric heated outside mirror
Alloy wheels
Interior
Inner lamplight close protractedly
Comfortable and Convenient
Electic accelerograph
Manual adjustable headlamps
Electric adjustable headlamps
Hydraulic assisted steering
EPS(Electric power steering)
Tilt steering wheel
Steering wheel with audio control and
Bluetooth
Remote keyless entry with windows auto
close feature
Four fully electric windows(Auto up/down )
Trunk open Inside
12V power supply socket
Cloth seat cover
Driver 4-way manual adjustable seat
Driver 8-way manual adjustable seat
Manual waist rest
Electric air-condition
Air-conditioning system-automatically
thermostatic
Luxury
CD+USB interface
Four speakers with stereo sound
Eight speakers with stereo sound
Note:
1. Optional Colour: Chery white,Magic black,Nasdaq silver,Wolfsburg gray,Aegean blue,Indicolite gold,Passion Red
*المواصفات للسيدان
Powertrain1.6MT1.8MT/CVT2.0MT2.0AT
Measure and weight
Length x width x height   mm4352×1794×1464
Wheelbase         mm2550
Tread(front/rea)      mm1540/1530
Kerb weight        kg1385
Minimum ground clearance  mm127
Tire specs205/55R16
Engine
ModelACTECO-SQR481FACTECO-SQR481FCACTECO-SQR484F
Displacement       cc159718451971
Max. output         kW/rpm80/600097/5750102/5750
Max. torqe         N.m/rpm144/4200170/4300182/4300-4500
Compress ratio10.5
Max. speed        km/h186191195
Transmission5MT5MT5MT4AT
EmissionEUⅣ+OBD
DrivetrainFF
Main Equipment
Safety
Black side shield blanket
Wheel cover shield blanket
Rear mid two-point seat belt
ISO-FIX
ABS+EBD
ESP(ABS+EBD+TCS)
Side airbag
Front fog light
Common back radar
Visual reverse radar Aidded System
Automatic wiper
TPMS(Tire pressure monitor system)
Immobilizer
Theft alarm system
Fire extinguisher
Exterior
Common wiper blade
Boneless wiper blade
Electric outside mirror
Alloy wheels
Interior
Beige upholstery
Dark upholstery
Manual rear window curtain
Fabric door shield
Leather door shield
Left map bag sunvisor,right face-painting
mirror sunvisor
mirror sunvisor with illuminating
Glass case
Front cup bracket
Ignition and ashtray
Front and rear roof light
Foot rest pedal
Tilt steering wheel
Bluetooth
close feature
(one- touch and jam protection Front)
Trunk open Inside
Cloth seat cover
Leather seat cover
Electronic heated front seats
Two-direction adjustable seat pillow
Four-direction adjustable seat pillow
Driver 8-way electric adjustable seat
Manual waist rest
Manual air-condition
thermostatic
Indicator of exterior temperature
Luxury
Hands-free phone capbility via Bluetooth
CD+USB interface
DVD+10CD
Note:
1. Optional Colour: Chery White,Magic Black,Nasdaq Silver,Wolfsburg gray,Aegean Blue,Passion Red
2. ●Standard ○Optional
----------------شيرى ايستر-------------------
Engine2.0L2.4L
Transmission4AT5MT4AT
DriveFF
Engine
Engine code z4G63S4MSQR484F4G64S4M
Number of cylinders4 in line
Valve mechanism16 valves DOHC
Fuel injection systemElectronic Multipoint Injection
Displacement (cc)199719712350
Bore×stroke (mm)85×8883.5×9086.5×100
Compression ratio10:019:01
Maximum power (Kw/rpm)92/600095/575095/5500
Maximum torque (Nm/rpm)168/3000~4500180/4300~4500195/2500~3000
Fuel tank capacity (L)60
Fuel consumption at 90KM/h(Litres/100km)7.56.57.5
Maximum speed (km/h)175190190
Fuel typeUnleaded Gasoline
Dimensions & Weight
Length×Width×Height (mm)4770×1818×1445
Wheelbase (mm)2700
Front tread (mm)1550
Rear tread (mm)1530
Minimum ground clearance(full loading) (mm)125
Turning radius(minimum) (m)6
Kerb weight (kg)146014401470
Tyre Size205/55R16 91V/205/55R16 91W205/65R15×94H(205/55R16
91V/205/55R16 91W
Suspension & Brake
Front suspensionIndependent Macpherson strut with coil spring, dual acting tube damper and anti-roll bar
Rear suspensionIndependent multi-link with cylindrical coil spring, dual-acting tube damperand anti-roll bar
Front BrakeDisc
Rear BrakeDrum
ABS+EBDYes
يتبع باذن الله
قديم 31-05-2009, 02:55 AM
الصورة الرمزية oldman
افتراضي رد: أحدث سيارات شيرى الصينية
تسلم ايدك يا دكتور تامر تقرير ممتاز وفى انتظار باقى التقرير
قديم 31-05-2009, 03:18 AM
الموقع: الشرقيه
ايستر كروز
*المواصفات
Engine2.4L
Transmission4MT
DriveFF
Engine
Engine code z4G64S4M
Valve mechanism16 valves SOHC
Displacement (cc)2350
Bore×stroke (mm)86.5×100
Compression ratio9:01
Maximum power (Kw/rpm)95/5500
Maximum torque (Nm/rpm)195/2500~3000
Fuel tank capacity (L)62
Fuel consumption at 90KM/h(Litres/100km)8.8
Maximum speed (km/h)178
Dimensions & Weight
Length×Width×Height (mm)4662×1820×1590
Wheelbase (mm)2800
Rear tread (mm)1530
Kerb weight (kg)1505
Tyre Size205/55R16 91W
Suspension & Brake
Rear suspensionIndependent multi-link with culindrical coil spring, dual-acting tube damper and anti-roll bar
Front BrakeDisc(venti)
Rear BrakeDisc
ABS+EBDYes
يتبع ان شاء الله
قديم 31-05-2009, 12:15 PM
الموقع: الشرقيه
شيرى كوين
المواصفات
1.6L
Transmission5MTCVT
DriveFF
Engine
Engine code zSQR480EDTRITEC1.6L
Valve mechanism8 valves SOHC16 valves DOHC
Displacement (cc)15961598
Bore×stroke (mm)80×8077×86
Compression ratio9.75:110.5:1
Maximum power (Kw/rpm)65/550085/6000
Maximum torque (Nm/rpm)132/3000~3500149/4500
Fuel tank capacity (L)55
Fuel consumption at 90KM/h(Litres/100km)7.57
Maximum speed (km/h)160
Dimensions & Weight
Length×Width×Height (mm)4393×1682×14244573×1682×14244393×1682×1424
Wheelbase (mm)246826482468
Front tread (mm)1425
Rear tread (mm)1419
Turning radius(minimum) (m)5.5
Kerb weight (kg)11001140
Tyre Size185/60R14 82H
Suspension & Brake
Front suspensionIndependent Macpherson strut with coil spring, single transverse link and dual-acting tube damper
Rear suspensionSemi-independent trailing arm type with cylindrical coil spring and dual-acting tube damper
Front BrakeDisc
Rear BrakeDrum
ABS+EBDOptional
تيجو
*المواصفات
Engine2.4L2.0L1.8L1.6L
Transmission4AT/5MT4AT/5MT5MT
DriveFF/AWDFF
Engine
Engine code4G64S4M4G63S4MSQR481FCSQR481F
Valve mechanism16 valves SOHC16 valves DOHC
Displacement (cc)2350199718451597
Bore×stroke (mm)86.5×10085×8881×89.581×77.5
Compression ratio9.5:110:0110.5:1
Maximum power (Kw/rpm)95/550092/600097/575080/5800
Maximum torque (Nm/rpm)195/2500~3000168/3000~4500170/4300~4500144/4200
Fuel tank capacity (L)57(metal)/55(plastic)
Fuel consumption at 90KM/h(Litres/100km)8.0/7.0/8.97.5/7.46.57
Maximum speed (km/h)170/175175/165190160
Dimensions & Weight
Length×Width×Height (mm)4285(4265 only if SOR7246 chooses 215/70R16 99H)×1765×1705(tyre:235/60R16100H)/1715(tyre:215:70R16 99H)
Wheelbase (mm)2510
Front tread (mm)1524(tyre:235/60R16 100H)/1500(tyre:215/70R16 99H)
Rear tread (mm)1519(tyre:235/60R16 100H)/1495(tyre:215/70R16 99H)
Minimum ground clearance(full loading) (mm)132(tyre:235/60R16 100H)/135(tyre:215/70R16 99H)
Kerb weight (kg)1400/1475/13801395/137514401375
Tyre Size235/60R16 100H(215/70R16 99H)/215/65R16 98H
Suspension & Brake
Front suspensionIndependent Macpherson strut with variable-pitch conical coil spring, anti-roll bar, single transverse link and dual-acting tube damper
Rear suspensionTrailing arm type with double wish bone, coil spring, tube damper and anti-roll bar
Rear BrakeDisc(drum optional)
ABS+EBDYes(rear drum:no)
يتبع
قديم 31-05-2009, 12:32 PM
fadynabil fadynabil غير متواجد حالياً
fadynabil is a jewel in the roughfadynabil is a jewel in the roughfadynabil is a jewel in the roughfadynabil is a jewel in the rough
ممتاز ... تقرير جيد .... ومنتظرين المزيد
احدث موديلات اسبيرانزا, صور اسبرانزا, صور شيرى, شيرى الصينية
الساعة الآن 02:13 AM.
