قديم 13-05-2009, 01:06 PM
الصورة الرمزية oldman
الفرق بين ناقل الحركة اليدوي(صندوق سرعات يدوي) وناقل الحركة الذاتي (صندوق سرعات ذاتي)
Manual Transmission vs. Automatic Transmission
<TABLE class=MsoTableGrid dir=rtl style="WIDTH: 501.95pt; BORDER-TOP-STYLE: none; BORDER-RIGHT-STYLE: none; BORDER-LEFT-STYLE: none; BORDER-COLLAPSE: collapse; BORDER-BOTTOM-STYLE: none" cellSpacing=0 cellPadding=0 width=669 border=1><TBODY><TR><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 48.3pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=64></TD><TD style="PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 203.15pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-WIDTH: 1pt; BORDER-RIGHT-COLOR: windowtext" width=271>
ناقل الحركة اليدوي
Manual Transmission
</TD><TD style="PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 250.5pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-WIDTH: 1pt; BORDER-RIGHT-COLOR: windowtext" width=334>
ناقل الحركة الذاتي
</TD></TR><TR><TD style="BORDER-TOP-WIDTH: 1pt; BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 48.3pt; BORDER-TOP-COLOR: windowtext; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=64>
الشكل:
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 203.15pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none" width=271>
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 250.5pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none" width=334>
</TD></TR><TR style="HEIGHT: 21.1pt"><TD style="BORDER-TOP-WIDTH: 1pt; BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 48.3pt; BORDER-TOP-COLOR: windowtext; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 21.1pt" width=64 rowSpan=3>
التحكم:
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 203.15pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none; HEIGHT: 21.1pt" width=271>
عصا اختيار النقلات stick shift
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 250.5pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none; HEIGHT: 21.1pt" width=334>
عصا اختيار النقل Automatic gear selector
</TD></TR><TR style="HEIGHT: 70.5pt"><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 203.15pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none; HEIGHT: 70.5pt" width=271>
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 250.5pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none; HEIGHT: 70.5pt" width=334>
تعمل عصا اختيار النقلات للاختيار بين النقلات الأمامية المختلفة لصندوق التروس كالتالي:
النقلة الأولى 1, النقلة الثانية 2, النقلة الثالثة 3, ........ وتستمر حسب عدد النقلات وقد تصل إلى 6 نقلات.
وكذلك نقلة الحياد N, حيث ليس هناك تعشيق للتروس. ونقلة الحركة للخلف R, والتي تحتاج إلى ضغط أو جذب للعصا حتى لا يتم نقلها عن طريق الخطأ أثناء السير للأمام. وفي الغالب يرسم على مقبض العصا حركة النقلات.
تعمل عصا اختيار وضعية النقل بالترتيب التالي:
|وضع التثبيت
P, وضع الرجوع للخلف R, وضع الحياد N, وضع السير D الذي يتم خلاله عدد من النقلات في العادة 3 إلى 4 ووصلت الآن إلى 8 نقلات, وضع الثاني 2 or S للحركة للأمام بحيث لا يتعدى ناقل الحركة النقلة الثانية, وضع الأول 1or L للحركة للأمام بحيث لا يتعدى ناقل الحركة النقلة الأولى.
هذا يكون الترتيب: من اليسار إلى اليمين, من أعلى إلى أسفل أو مع عقارب الساعة)
</TD></TR><TR style="HEIGHT: 251.5pt"><TD style="BORDER-TOP-WIDTH: 1pt; BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 48.3pt; BORDER-TOP-COLOR: windowtext; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 251.5pt" width=64>
اختلاف الأجزاء:
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 203.15pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none; HEIGHT: 251.5pt" vAlign=top width=271>
- قابض احتكاكي Friction clutch
- بدال (دعسة) القابضClutch pedal
- وصلات فصل وتعشيق القابض mechanical or hydraulic links
- تروس عدلة أو مائلة spur gears, helical gears
- أعمدةShafts
- موفق الحركة
synchronizer mechanism
- زيت تزيت ناقل الحركةLubricant oil
- رمان بلي Roller bearings
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 250.5pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none; HEIGHT: 251.5pt" vAlign=top width=334>
- محول عزم Torque converter
- التروس الكوكبية Planetar gearset
- أقراص قابض وسيور فرامل Clutches and bands
- مجمع صمامات هيدروليكي valve body
أو وحدة تحكم إليكترونية
-Module ECM, Electronic Control
- زيت ناقل الحركة Oil and lubricating oil
- مضخة Fluid pump
- منظم Governor
- مبرد Active cooler
</TD></TR></TBODY></TABLE>
<TABLE class=MsoTableGrid dir=rtl style="WIDTH: 503.4pt; BORDER-TOP-STYLE: none; BORDER-RIGHT-STYLE: none; BORDER-LEFT-STYLE: none; BORDER-COLLAPSE: collapse; BORDER-BOTTOM-STYLE: none" cellSpacing=0 cellPadding=0 width=671 border=1><TBODY><TR><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 53.4pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=71></TD><TD style="PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 228pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-WIDTH: 1pt; BORDER-RIGHT-COLOR: windowtext" width=304>
ناقل الحركة اليدوي
</TD><TD style="PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 222pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-WIDTH: 1pt; BORDER-RIGHT-COLOR: windowtext" width=296>
ناقل الحركة الذاتي
</TD></TR><TR><TD style="BORDER-TOP-WIDTH: 1pt; BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 53.4pt; BORDER-TOP-COLOR: windowtext; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=71>
المميزات
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 228pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none" width=304>
- يوفر الوقود بمقدار 2- 5 ميل بالجالون
- السيارة المركب بها تكون أرخص بمقدار 800 إلى 1200 دولار
- أرخص في الصيانة
- أكثر انتشار في أوربا وباقي بلدان العالم
- تعجيل أحسن بمقدار ملحوظ
- أداء أعلى
- أعطاء تحكم أكبر من السائق على أداء السيارة
- لا يحتاج إلى مبرد للزيت
- أقل وزنا من ناقل الحركة الذاتي
- ليس به مضخة زيت, والتي تستهلك جزء من قدرة المحرك.
- أكثر كفاءة في العمل ليس هناك انزلاق كما في محول العزم
- يمكن للسائق الاستفادة القصوى من قدرة المحرك.
- أصلح للسيارات الصغيرة حيث إنها في العادة تستخدم محرك صغير, النقل الذاتي قد يقلل من سرعتها.
- أحسن في الطرق الجبلية والطينية من ناحية التحكم .
- يمكن التحكم في مقدار العزم المطلوب للعجل, كما يمكن استخدام المحرك كفرملة للسيارة بطريقة فعالة.
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 222pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none" vAlign=top width=296>
- توفر الراحة للسائق
- نقل مريح وسريع
- أسهل في عملية القيادة حيث لا يوجد عدد 2 بدال (البنزين والفرامل) فقط.
- القدم اليسرى لا تستخدم خلال القيادة, واليدين على عجلة القيادة معظم الوقت, تحكم أحسن وأكثر سلامة.
- يضع حمل أقل على المحرك وأجزاء نقل الحركة, ولهذا تكون تكلفة الصيانة أقل بالنسبة للعمر التشغيلي للسيارة.
- أقل صيانة فليس هناك الحاجة إلى استبدال قرص القابض الذي يتآكل ويحتاج إلى تغيير.
- أكثر انتشار في أمربكا, تمثل 84% من السيارات المباعة في أمريكا الشمالية
- أصلح للسيارات الخاصة بالمعوقين
العيوب
- التعب مع التعامل مع السيارة في ظروف الازدحام المروري, للحاجة للضغط على بدال القابض والنقل اليدوي المستمر.
- يحتاج إلى تغيير الزيت بمعدل أعلى من صندوق التروس الذاتي
- تأكل أكثر, وخاصة القابض
- يحتاج إلى مهارة وخبرة في التعامل
- صعوبة بداية الحركة على مطلع للمبتدأين
(بعض السيارات تجهز بوسيلة التشبث على المطلع)
- لعدم الإقبال عليها في أمريكا مثلا, تجد صعوبة في إعادة البيع. يمثل فقط من 8- 10% من مبيعات السيارات سنويا, ولكن الحال يختلف في أوربا وكثير من البلدان.
- استهلاك أعلى للوقود 10%
- ناقل الحركة الذاتي يتم به نقل مبكر يفقد جزء كبير من القدرة القصوى 20%
- أغلى سعراً
- أثقل وزنا
- تكلفة إصلاح أعلى
- في حالة عدم عمل بادئ الحركة, لا يمكن تقويم السيارة عن طريق دفع السيارة ورفع القدم من على بدال القابض لتقويم المحرك عن طريق العجل. (في هذه الحالة تقوم السيارة عن طريق توصيلة كبل للبطارية, أو قطر السيارة, أو تحميلها على شاحنة).
- في بعض البلاد في حالة حصول الشخص على رخصة قيادة على السيارات بناقل الحركة الذاتي, لا يسمح له بقيادة السيارات ذات ناقل الحركة اليدوي والعكس صحيح.
- يحتاج إلى صيانة دورية (تغير فلتر- زيت- حابك (صوفة) أمامية وخلفية)
الاستخدام
</TD><TD style="PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 228pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-RIGHT-STYLE: none" vAlign=top width=304>
- السيارات الصغيرة (الاقتصادية)
- أكثر انتشار في الدول الأوربية, ومعظم دول العالم
- اختيار أول للشباب
- السيارات الرياضية
- معظم سيارات السباق تكون ذو ناقل حركة يدوي.
- سيارات النقل الثقيل, حيث تتحمل العزوم العالية لتحريك الحمولة الكبيرة للشاحنة.
- السيارات الفارهة وغالية الثمن
- أكثر انتشار في الولايات المتحدة
- اختيار أول في المناطق المزدحمة مروريا
- معظم سيارات الأجرة في أمريكا
- الاختيار الأول لكبار السن من السائقين
<TABLE class=MsoNormalTable style="WIDTH: 97%; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width="97%" border=0><TBODY><TR style="HEIGHT: 0.75pt"><TD style="PADDING-RIGHT: 0pt; PADDING-LEFT: 0pt; PADDING-BOTTOM: 0pt; PADDING-TOP: 0pt; HEIGHT: 0.75pt">
مقارنة بين سعر وكفاءة استهلاك الوقود والتسارع لسيارات ذات ناقل حركة يدوي وناقل حركة ذاتي
<TABLE class=MsoTableGrid style="MARGIN-LEFT: -0.6pt; WIDTH: 474pt; BORDER-TOP-STYLE: none; BORDER-RIGHT-STYLE: none; BORDER-LEFT-STYLE: none; BORDER-COLLAPSE: collapse; BORDER-BOTTOM-STYLE: none" cellSpacing=0 cellPadding=0 width=632 border=1><TBODY><TR><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 114pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=152 colSpan=2>
التسارع (ثانية)
صفر- 60 ميل/ساعة
<SUP>3</SUP>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BORDER-LEFT-WIDTH: 1pt; BORDER-LEFT-COLOR: windowtext; PADDING-BOTTOM: 0pt; WIDTH: 84pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=112 colSpan=2>
استهلاك الوقود
ميل/ جالون
<SUP>2</SUP>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BORDER-LEFT-WIDTH: 1pt; BORDER-LEFT-COLOR: windowtext; PADDING-BOTTOM: 0pt; WIDTH: 114pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=152 colSpan=2>
السعر
<SUP>1</SUP>
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BORDER-LEFT-WIDTH: 1pt; BORDER-LEFT-COLOR: windowtext; PADDING-BOTTOM: 0pt; WIDTH: 162pt; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=216>
موديل السيارة
</TD></TR><TR><TD style="BORDER-TOP-WIDTH: 1pt; BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 57pt; BORDER-TOP-COLOR: windowtext; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" vAlign=top width=76>
ذاتي
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 57pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" vAlign=top width=76>
يدوي
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 42pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" vAlign=top width=56>
ذاتي
يدوي
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 54pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" vAlign=top width=72>
ذاتي
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 60pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" vAlign=top width=80>
يدوي
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 162pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" vAlign=top width=216>
نوع النقل
</TD></TR><TR><TD style="BORDER-TOP-WIDTH: 1pt; BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; BORDER-LEFT: windowtext 1pt solid; WIDTH: 57pt; BORDER-TOP-COLOR: windowtext; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid" width=76>
10.1
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 57pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" width=76>
9.0
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 42pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" width=56>
26
29
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 54pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" width=72>
18,490
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0pt; WIDTH: 60pt; BORDER-TOP-STYLE: none; PADDING-TOP: 0pt; BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT-STYLE: none" width=80>
17,440
فورد فوكس أس أي أس
Ford Focus SES
9.8
8.4
23
26
22,795
21,995
هوندا أكورد إل أكس- بي
Honda Accord LX-P (4 cyl.)
10.1
8.6
28
31
19, 690
18,810
هوندا سيفيك أي أكس
Honda Civic EX
9.6
8.6
27
30
18,190
17,290
مازدا 3 أي
Mazda 3 i
10.5
9.1
29
33
24,700
21,700
ميني كوبر/كلبمان
Mini Cooper/Clubman
9.7
9.0
29
34
16,620
15,820
سيون أكس دي
Scoion XD
10.4
9.1
22
24
22, 040
20,972
سوبارو فورستير 2,5 أكس
Subaru Forester 2.5X
1 القيمة الأقل تدل على السيارة أرخص
2 القيمة الأكبر تدل على أن السيارة تسير مسافة أطول عند استهلاك جالون بنزين
3 القيمة الأقل تدل على تسارع أعلى
قديم 13-05-2009, 01:55 PM
الصورة الرمزية DK.Cupo
من انا؟: Driving King
الموقع: Egypt
افتراضي رد: الفرق بين ناقل الحركة اليدوي(صندوق سرعات يدوي) وناقل الحركة الذاتي (صندوق سرعات ذاتي)
مش بقولك النهارده اليوم العالمي للمواضيع الجامده
تسلم ياباشا
قديم 13-05-2009, 02:24 PM
مقارنه رائعه ptmnlo123per171
من تواضع لله رفعه
The ultimate car
would be designed by Italians
engineered by Germans
built by Japanese &
الساعة الآن 06:55 PM.
