قديم 04-03-2012, 06:32 PM
m0105538 m0105538 غير متواجد حالياً
m0105538 is a jewel in the roughm0105538 is a jewel in the roughm0105538 is a jewel in the rough
حصرى اكواد اعطال كمبيوتر جيلي من ٢٠٠٤ في حالة نوع الكمبيوتر Bosch
Code:
Item:
Fault:
13
Oxygen/Lambda/O2 sensor
No change in voltage/open circuit.
14 Coolant Temperature Sensor (CTS)
Low voltage
15
High voltage
16 Knock sensor 1 (front engine cylinder bank) No change in voltage, bad wiring or bad sensor
17
Knock sensor 2 (rear engine cylinder bank)
18 Knock sensor fault in ECU Internal problem detected with knock signal processing functions
19
RPM signal (crankshaft sensor)
Incorrect RPM signal received from inductive pulse pick up sensor
21 Throttle position sensor High voltage
22
Low voltage
25
Injector valve 1
High voltage
26
Injector valve 2
High voltage
27
Injector valve 3
High voltage
28
Injector valve 4
High voltage
29
Injector valve 5
High voltage
31
Engine RPM signal (crankshaft sensor)
No signal - engine not running (try reading codes with engine running)
32 Injector valve 6 High voltage
38
Oxygen sensor
Voltage low (weak mix detected)
39
Oxygen sensor
Voltage high (rich mix detected)
44 Oxygen sensor Lean Exhaust
45 Oxygen sensor Rich Exhaust
46 Secondary Air Pump Low Voltage
47 Secondary Air Pump High Voltage
48
Battery voltage
Low voltage
49
Battery voltage
High voltage
52
Check engine light
High voltage
53
Fuel pump relay
Low voltage
54
Fuel pump relay
High voltage
55
Engine Control Unit (ECU) fault
Renew Engine Control Unit (ECU)
56
Idle Speed Control Valve (ISCV)
Low voltage
57
High voltage
61
Fuel Tank Vent Valve (FTVV)
Low voltage
62
High voltage
69
Intake air temperature
Low voltage
71
High voltage
73
Mass Air Flow Meter/Sensor (AFM or MAF)
Low voltage
74
High voltage
75
Transmission switch Torque Control (auto box)
Automatic Transmission only
76
Continuous Torque Control (auto box)
79
Full load inhibit (Traction Control)
Incorrect ignition/injector cut-off / voltage low
81
Injector valve 1
Low voltage
82
Injector valve 2
Low voltage
83
Injector valve 3
Low voltage
84
Injector valve 4
Low voltage
85
Injector valve 5
Low voltage
86 Injector valve 6 Low voltage
87
Air Conditioning (AC) cut off relay
Low voltage
88
High voltage
93 Hall Effect Switch (Camshaft Angle Sensor) Low voltage
94 Hall Effect Switch (Camshaft Angle Sensor) High voltage
97
Ignition/Injection cut-off (Traction Control)
High voltage
143
Immobiliser function in ECU
No or incorrect signal
144 Immobiliser no signal No signal received from immobiliser
145
Incorrect immobiliser signal received
Faulty unit or break in wiring
قديم 04-03-2012, 07:22 PM
افتراضي رد: اكواد اعطال كمبيوتر جيلي من ٢٠٠٤ في حالة نوع الكمبيوتر Bosch
جزاك الله خيرا على المعلومة الجميلة
الساعة الآن 01:12 AM.
