العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > رينو RENAULT > رينو ميجان Mégane
رينو ميجان Mégane The Renault Mégane is a small family car produced by the French automaker Renault since 1995. It is offered in 3- and 5-door hatchback, saloon, coupé, convertible and estate bodystyles. The Renault Scénic (launched 1996) is the first modern compact MPV to be built in Europe
قديم 22-04-2009, 11:43 AM
الصورة الرمزية sharky
sharky sharky غير متواجد حالياً
التخصص العملى: Senior Procurement
الموقع: Nasr City
sharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond reputesharky has a reputation beyond repute
افتراضي المواصفات الفنية ... ريـــنو ميـــجانII
المواصفات الفنية الرينو ميجان:
ENGINE TYPES
1,6 16v
BODY TYPE
Body type classification Saloon Saloon
Number of doors 5
Number of seats 5
ENGINE
Induction capacity (cm3)1598 1998
Bore x stroke (mm) 79,5x80,5 82,7x93
Number of cylinders 4
Compression ratio 10:1 9,8:1
Number of valves 16 16
Maximum power kw ISO (bhp DIN) 83(115) 98,5(136)
Maximum power (revs/min) 6000 5500
Maximum torque Nm ISO (mkg DIN) 152 191
Maximum torque (revs/min) 4200 3750
HP 115
Injection type
Multipoint Multipoint
Fuel type Petrol Petrol
Administrative power 7 8
TRANSMISSION
Gearbox type Automatic gearbox
Transmission type Tensile Tensile
Number of gears 4
SUSPENSION
Front axle Pseudo Mc Pherson front axle assembly with rectangular arm and anti roll-bar Pseudo Mc Pherson front axle assembly with rectangular arm and anti roll-bar
Rear axle Torsion beam axle with exterior fixation points and programmed working drawing -helical spring Torsion beam axle with exterior fixation points and programmed working drawing -helical spring
TYRES
Tyres size / profile 195/65 R15 205/55 R16
BRAKING
Front Disks (Diameter mm) DV-280 DV-280
Rear Drum (Diameter mm) DP-240 DP-240
CAPACITIES
Fuel tank - Litres 60 60
PERFORMANCES
Maximum speed (km/h) 187 NC
0 - 100 km/h (s) 12''8 NC
1000 m D.A. (s) 34''20 NC
STEERING
Turning circle between kerbs / walls (m) 10,50 10,50
FUEL CONSUMPTION standard CEE n° 93/116 ( l/100 km)
CO² (g/km) NC 201
Urban (l/100 km) NC 11,8
Extra urban (l/100 km) NC 6,5
Combined cycle (l/100 km) NC 8,4
Ahmed Mohamed Saied
ريــنو ميــــجان ..... فخـــامة تستحــق الإحتـــرام
السيــــارة التى رفعـــت مقاييــــس فئــــة 1,6 لتــر
الساعة الآن 10:28 AM.
