قديم 11-11-2011, 05:30 PM
الصورة الرمزية shady mohamed
shady mohamed shady mohamed غير متواجد حالياً
shady mohamed will become famous soon enough
مميز الفويجو من 0-100 فى 3.6 ثانيه فقط و تحدى
فيديو رائع يوضح امكانيات الفيوجو التى نتجاهلها فى مصر
مع العلم ان شركه رينو تعترف ان الفويجو هى احسن السيارات و اقواها فى جميع فئات الرينو
اتفرج على الفويجو من 0-100 فى 3.6 ثانيه يعنى عربيه و لا فى الاحلام و كمان
اسرع من الفيرارى
شوف بنفسك
و على فكره الكلام ده مش فيديو و بس ده عن تجربه شخصيه
The Best Renualt Fuego In Middle East
Farah Technology Crocodile System
قديم 11-11-2011, 06:39 PM
مميز الموتور ده كاتينة جنزير مش كاوتش هو هو زى R18 !!!!
المشاركة الأصلية كتبت بواسطة shady mohamed مشاهدة المشاركة
اسرع من الفيرارى
شوف بنفسك
لمشاهده الفيدو اضغط هنا
1983 Fuego Turbo
I bought an NG-1 gearbox and it came with a car and an 807 Turbo engine attached! There was an injected 843 engine in the rear hatch as well! Neither engine had run for awhile, the 807 turbo apparently for want of a fuel pump, and the 843 due to a head gasket failure. I was even more interested in the 843 engine than the gearbox as I was missing some parts for my Gordini, plus it came with modern EFI and ignition. Perfect! IF I can get it to work. The turbo will have to wait for another car.
Here's the salt-ravaged 843 a hangin'. You can see why most Renault engines aren't well suited to Europa transplantation as the power steering, alternator and water pump drives would not clear the chassis or the firewall.
Here's the long block. Starting to look more familiar.
Look at the #2 intake port. Is that from coolant?
Look at the caramel sauce-like guck on the adjuster screw and head bolt. Is that an oil/coolant emulsion? That doesn't bode well for the bottom end.
I managed to get the head off without dislodging the liners. The bores were bone dry and acutally had loose carbon dust inside that needed to be vacuumed out. the combustion chambers were surprisingly free of crud, one was a little blacker than the others. Unfortunately the engine is seized somewhere, the liquid you see is penetrating oil. I wonder what happened when the gasket let go? We'll find out.
It is interesting to me that the 1983 843 case has mounting bosses that are compatible with the 1969 Europa's, yet the 1973 807 I have does not. This case looks nice and strong, and I must admit that if the valves, bores and journals are decent, It is tempting to try to salvage this one without a complete rebuild. Gotta find out more about the 843. I know the wrist pin is a different diameter and the compression height is different to accomodate the longer stroke.
Later... It turns out that the head is in decent shape. Maybe, just maybe the pistons and liners can be salvaged.
ركب على الفويجو 6 سلندر بتربو ومن غير تربو كمان !!!!!!!!!!!!
ده احتمال يكون شكل ال25 الجديدة !!!!!!!!
: 010104~171::C ONGRA~238:FLASHCa r
التعديل الأخير تم بواسطة cars admire ; 11-11-2011 الساعة 07:02 PM
قديم 11-11-2011, 06:57 PM
افتراضي رد: الفويجو من 0-100 فى 3.6 ثانيه فقط و تحدى
هو الموضوع تحدى و لا ايه .... طب خد دى
http://masrmotors.com/vb/showthread.php?t=71776
قديم 11-11-2011, 07:16 PM
: 018A1D~146::0 18A1D~146::01 8A1D~146::018 A1D~146:
قديم 13-11-2011, 10:47 PM
الصورة الرمزية dr_eslam_66
dr_eslam_66 dr_eslam_66 غير متواجد حالياً
من انا؟: أنا شاب ولاكن عمري ألف عام أخرس وقلبي مليان كلام
التخصص العملى: مهندس مدني
هواياتي: --------
الموقع: الإمارات
dr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond reputedr_eslam_66 has a reputation beyond repute
هوا معلش الفيجو دي الي موجودة في الفيديو لامؤاخذة بتاعتك ولا دا فيديو وخلاص؟
كمان هيا بالحالة دي بالماتور بتاعها الي ستوك ولا دي تعديلات أصلي علشان عربية تعمل كدة ياعني أكيد راكبلها أكبر تيربو تشارجر في العالم.
ممكن تقولنا شوية تفاصيل عن ماتور الفيجو الستوك كام سلندر كام حصان كام سي سي .
بالعربي الله يكرمكواااااااا.:fun_36_3_ 11[1]:
الساعة الآن 04:29 PM.
