قديم 10-06-2008, 05:28 AM
الصورة الرمزية AbOnOrA
Aِِbo(Nora&Islam&Judy)
Wael Magdy Salah
من انا؟: ابو نورا واسلام
التخصص العملى: IT Consultant
الموقع: ام الدنيا مصر
مواصفات هيونداى اكسنت مو2005
2005 Hyundai Accent
Technical specifications
ENGINE
Type: DOHC, four-cylinder, inline
(transverse-mounted)
Materials: cast iron block/aluminum cylinder head
Displacement: 1.6 liters (1600cc/97.6 cubic inches)
Bore x stroke: 76.5mm x 87.0mm (3.01 inches x 3.42 inches)
Compression ratio: 10.0:1
Horsepower: 104 bhp @ 5,800 RPM
Torque: 106 lb-ft @ 3,000 RPM
Valves per cylinder: four
Fuel system: electronic multi-port fuel injection
four-jet fuel injectors, in-tank fuel pump
Ignition: electronic ignition
Emission controls: three-way catalyst with EGR
SUSPENSION
Front: independent, MacPherson struts with coil springs, anti-roll bar and hydraulic shock absorbers.
Rear: independent, strut with multi-links, coil springs, anti-roll bar and hydraulic shock absorbers.
TRANSMISSION
5-speed manual
Gear ratios:
1st 3.62:1
2nd 2.05:1
3rd 1.37:1
4th 0.97:1
5th 0.78:1
Reverse 3.25:1
Final drive ratio 3.84:1
(more)
2005 Hyundai Accent specifications / page 2
4-speed automatic
Gear ratios:
1st 2.85:1
2nd 1.58:1
3rd 1.00:1
4th 0.69:1
Reverse 2.18:1
Final drive ratio 4.04:1
STEERING
Type: Power-assisted rack-and-pinion
Overall ratio: 15.3:1
Turns, lock to lock: 2.9
Turning circle: 32.5 feet (curb to curb)
BRAKES
Power assisted, dual-diagonal braking system
Front: 9.5-inch (241mm) vented disc with floating caliper and pad wear sensor
Rear: Power-assisted 7.1-inch (180mm) drum
ABS: N/A
WHEELS 13 x 5J steel with deluxe full wheel covers (Accent GLS)
14 x 5J alloy (Accent GT)
TIRES P175/70R13 all season, steel-belted radial, T105/700-14 compact spare (Accent GLS)
P185/60HR-14 (Accent GT)
ELECTRICAL
Battery: Maintenance free, 12 volt, 55 amp/hour
Alternator: 75 amp with internal IC regulator
EXTERIOR DIMENSIONS
3-door GLS & GT 4-door GLS
Wheelbase: 96.1 inches (2440mm)
Overall length: 166.7 inches (4234mm)
Overall width: 65.7 inches (1670mm) excludes side mirrors
Overall height: 54.9 inches (1395mm)
Track: front 56.5 inches (1435mm)
Track: rear 56.1 inches (1425mm)
2005 Hyundai Accent specifications / page 3
INTERIOR DIMENSIONS
Headroom
Front: 38.9 inches (988mm)
Rear: 38.0 inches (965mm)
Legroom
Front: 42.6 inches (1082mm)
Rear: 32.8 inches (833mm)
Shoulder room
Front: 52.8 inches (1340mm)
Rear: 52.4 inches (1330mm)
Hip Room
Front: 54.1 inches (1374mm)
Rear: 53.0 inches (1346mm)
( 3-door) (4-door)
EPA Passenger volume: 87.9 cubic feet 89.3 cubic feet
EPA Cargo Volume: 16.9 cubic feet 11.8 cubic feet
EPA Total Volume: 104.9 cubic feet 99.8 cubic feet
CAPACITIES
Fuel tank: 11.9 gallons
Crankcase: 3.5 quarts
Coolant: 5.7 quarts
CURB WEIGHT
(3-door) (4-door)
manual trans: 2280 lb 2290 lb
auto trans: 2339 lb 2350 lb
FUEL ECONOMY
City Highway
manual trans, GLS 3-door 29 mpg 33 mpg
manual trans, GLS 4-door 29 mpg 33 mpg
manual trans, GT 3-door 29 mpg 33 mpg
auto trans, GLS 3-door 26 mpg 35 mpg
auto trans, GLS 4-door 26 mpg 35 mpg
اخر موضوعاتى
قديم 13-09-2012, 06:58 PM
الصورة الرمزية YahiaAshraf
هواياتي: السيارات - الكمبيوتر
الموقع: Alexandria
افتراضي رد: مواصفات هيونداى اكسنت مو2005
: 12C186~161::1 2C186~161:
هيونداي و طريق الألف ميل Ahmed Anwer Hyundai هيونداى 21 22-09-2013 09:08 PM
قصة نشأة و تطور شركة هيونداي owner Hyundai هيونداى 4 12-08-2012 12:22 AM
تصنيف السيارات حسب سعرها ب 2012 محمد اشرف منتدى السيارات العام 17 07-08-2012 04:16 PM
هيونداي عملاق كوري يغزو العالم (قصة نشأة و تطور شركة هيونداي ) YahiaAshraf Hyundai هيونداى 3 13-07-2012 03:43 PM
جينيسيس.. هيونداي HaShiMoto Hyundai هيونداى 2 18-07-2008 10:33 PM
الساعة الآن 11:27 PM.
