قديم 10-06-2011, 12:00 AM
افتراضي Acura ZDX 2011 | Acura ZDX 2011 Review
The Acura ZDX 2011, looks good and wide from its outer appearance. It’s a sports wagon. For me, this ZDX looks imaginary from outside. It looks more like a leather suited imaginary character of some fiction-based Batman or Spiderman movie. It has very shiny and lustrous
look. It’s so gleaming that we feel if we are going to touch it, its going to make us GLOW with it.
PERFORMANCE:
2011 Acura ZDX has an all aluminum body engine. It is 3.7liter VTEC V6 engine. It outputs 300 horsepower and 270 lbs-ft of torque. It achieved an EPA city/highway mileage rating of 16/23mpg which means that it consumes less fuel. These specifications show that Acura ZDX 2011, is powerful but it is not so quick and sharp because it has a lot of weight of steel, glass and plastic.
The Acura ZDX has an advanced feature of “Integrated Dynamics System”. It is a feature which keeps the steering soft and the brake firm. It adjusts the steering and brake according to the driving conditions and the action of the driver.
EXTERIOR AND INTERIOR:
There are six different exterior color of Acura ZDX. As I have mentioned before that the exterior of ZDX looks more unreal than realistic. It seems like an “alien-car” which can run, fly and swim anytime. It would fly into space anytime. It is a five-door wagon. The doors can slide and open up to a large extent. The power tailgate can be accessed with the key remote, a button on the driver’s door or you can open it manually as well. The rear of this wagon looks as if it has been crushed by mistake or by an accident. It should’ve been a bit wider and larger than it actually is.
The ZDX has long seats covered with good foamy leather. The seats can be adjusted in ten different ways. This car is full of buttons. There are so many buttons that you can easily get confused on which button to press. There are number of navigation features inside the car with an LED fitted in the lower part of the dashboard which helps you locate directions. The backseats looks wide enough but are not very comfortable. The side doors of the rear seats have a “V” shaped cut maybe that’s what makes it a bit uncomfortable to sit.
SAFETY FEATURES:
There are number of safety features in this wagon. It’ll be much better to list them one by one:
  • It has a tough body made up of aluminum and steel, which saves the people sitting inside in case of an accident.
  • Blind Spot Information. This feature helps you when you are about to change the lane. It senses if something is behind you or on the other side when you’re about to change your lane.
  • It has “Vehicle Stability Assist” which helps in keeping the car under control in case of skidding, over steering or under steering.
  • It has “Collision Mitigating Braking System” which helps in decelerating the car if it senses any frontal collision. It alarms the driver by giving visual or audible warnings.
  • It has “Tire Pressure Monitoring System” which senses if any of the tires is under-inflated. It informs and warns the driver about it.
الساعة الآن 08:08 PM.
