قديم 19-05-2011, 07:33 AM
الصورة الرمزية tarbook
tarbook tarbook غير متواجد حالياً
من انا؟: خالد صلاح الدين سمير
التخصص العملى: Computer Science
هواياتي: السيارات واسماك البحار
الموقع: مصر ام الدنيا القاهره
tarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond reputetarbook has a reputation beyond repute
افتراضي BMW E36 Start Button
Step 1: First thing your going to need remove the cigarette lighter so you can modify the hole to fit your new start button. To do this use your finger and pull the out through the hole in holder. You may disconnect it if you would like, The picture shows where to put your finger find the hole.
http://a7lashare.com//uploads/images...0dca7640c0.jpg
Step 2: Next you want to pull out your console, be careful when pulling this out, some wires you'll need to disconnect: cigarette power, heated seats, and a light bulb. Once this is out pop the cigarette lighter out from the console. Push up on it from the bottom, will take a little bit of force but it will
right out.
Step 3: Now to the Use the Emery to make the hole Slightly larger for your start button.
Step 4: There are three screws, one to the left and right of the steering wheel, and one closer to the gas pedal.
Step 5: Below is a wiring diagram for the relay.
Step 6: Now Find on the green wire and give it a cut, in the middle so you have some slack on both sides. With a piece of wire tap into the green wire and tape all ends With piece of wire into the green wire connect it to the relay as shown on the wiring diagram Below is a picture of the ignition harness, this is where the wires you are tapping terminate. Your going to want to cut them down towards the harness that goes towards the starter as shown in the second picture.
Step 7: Next is to cut the Yellow/Black wire. ( NOTE - Some cars may have a Green/Black wire instead of Yellow/Black, there is no difference in the cars, just different productions of the E36 - 3 series) if you want your car to start with only the button ( which is what I did ) tape off the end of the wire that goes towards the ignition. to wire to the side of the Yellow/Black wire that goes towards the starter.
Step 8: Here is just a picture of the relay used with the wires connected to it
Step 9 : run Now the start
اشهد ان لا اله الا الله وحده لا شريك له واشهد ان محمد رسول الله عليه افضل الصلاه والسلام على الحبيب المصطفى
التعديل الأخير تم بواسطة AbOnOrA ; 19-05-2011 الساعة 07:40 AM سبب آخر: اظهار الصور
قديم 19-05-2011, 07:41 AM
الصورة الرمزية AbOnOrA
Aِِbo(Nora&Islam&Judy)
Wael Magdy Salah
من انا؟: ابو نورا واسلام
التخصص العملى: IT Consultant
الموقع: ام الدنيا مصر
افتراضي رد: BMW E36 Start Button
nice topic , thanks
اخر موضوعاتى
قديم 19-05-2011, 11:13 PM
thanx and u r welcome
قديم 19-05-2011, 11:14 PM
الصورة الرمزية nktis
nktis nktis غير متواجد حالياً
من انا؟: عبد من عباد الله
التخصص العملى: صيدلي
هواياتي: الصيد والتربيه
الموقع: هنا
very good effort,,,,,,,thanks
وأتت ملائكة النعيم كما روت*
روحي بطون أكفها خضراء*
صعدت بروحك والعبير يحفها*
والنور ترسم دربه الأنواء*
شرقت حشاشات النحيب وأينعت*
أكبادنا فبكاؤنا إيماء*
قديم 25-06-2011, 02:30 AM
الساعة الآن 03:42 AM.
