قديم 01-05-2011, 12:07 AM
مميز حقيقة استعمال الماء كوقود 100% !!!!!!!!!
the video
http://youtu.be/V3oK7bVf1_Q
Convert your car to BURN WATER !! You Can Drive Around Using WATER as FUEL, 100% water cars are still on the drawing board
Fuel from Water H2O
http://youtu.be/oCvnhQR7slY
http://youtu.be/kpTwQ-ZXfbE
water and gasoline mixture used in a car engine
http://youtu.be/VGKPaDj2qzQ
Engine Running on Water
http://youtu.be/nnUv6M0N6z4
water engine
http://youtu.be/5zLYxr2BM4Y
Water4Gas System Kit
Water4Gas Hydrogen-On-Demand Generator Hardware Kit
You Can Easily Assemble The Basic Water-Gas System under $60!
IMPORTANT! When You Order Water4Gas E-books You Are Not Ordering The Devices Shown Below!
Water4Gas.com offers a 300 pages easy guide on how to make and install the hydrogen system. Whit your order you will get free access to the readers-only marketplace where you can buy these discounted ready-to-install water for gas kits from more than 500 manufactures around the world.
Hydrogen Generator (Electrolyzer): A quart-sized highly durable jar contained unique coiled electrodes design (instead of plates) that use less battery electricity to produce more HHO. The hydrogen generator use the electrolysis process to converts water into hydrogen and oxygen. This is done by sending electricity from the car battery through the spirals suspended in the water. The tension caused by the 12 Volts electricity tears apart the H2O and produce hydrogen and oxygen gas as shown in the video below.
The generated HHO gas bubbles are sucked into the engine by the venturi suction (Gas Powered Suction) .
Catalyst: Simple and safe Baking Soda, the catalyst is needed to conduct electricity in the distilled water to split H2o into HHO.
MAP Sensor Enhancer: When the HHO system improves the combustion quality, the oxygen sensor in your car will see much more oxygen and begin injecting more fuel. When this happens you will probably not see any mileage improvements due to the computer fighting against the Water4Gas device. The MAP Sensor Enhancer allows you to adjust the fuel injection and the amount of fuel going into the engine. The enhancer is very important for fine tuning your HHO system.
Vaporizer: Cools down the engine, enhances combustion and fuel economy by adding water vapor to the gasoline.
The PCV Enhacer: Also known as "PCV jar" is a important part of the Water4Gas hydrogen system. It cleans out harmful carbon dioxide and unused fuel from the engine. It keeps the spark plugs and the oil cleaner. It removes unwanted water and sludge out of the crankcase and recycles burnable gases.
Fuel Heater: The fuel heater uses the energy from the car radiator to pre-heat the fuel for better combustion efficiency and gas economy without any modifications to the radiator.
Two 3.5 feet vacuum hoses: One connect to the air filtert the other too the intake manifold.
Vacuum T-connector: Helps to feed the oxygen and hydrogen gas from the electrolyzer into the engine by connecting to the vacuum line.
Mechanical installation hardware: 8" cables for the Hydrogen Generator, bungee cords, 1/4" vinyl tubing, 11" cables for the Fuel Heater and flex tubing to protect wiring connection.
Each of the listed devices is an extremely powerful fuel saving tool and can easily be built from cheap hardware. With the help of the detailed illustrations in the e-books it takes only a few hours to put together the complete Water4Gas kit.
Download Water4Gas
For more read water4gas review and latest water 4 gas information.
Water4Gas Kit That Converts A Car Or Truck Into A: "WATER POWERED ****
Here is the Best Water4Gas Kit Ready To Install, For Your Own Hydrogen On Demand Generator Project, Based On The Water4Gas Plans.
This Water4Gas Kit allows you to convert water into HHO gas or hydrogen-on-demand and inject it to your engine’s intake manifold and/or air induction system. This is called a supplemental hydrogen or hydrogen on demand system and has many advantages to the efficient operation of your car.
Almost all of the final assembly, and wiring work are done for you. This saves preparation time and lets you install and benefit from the unit much sooner.
We have rounded up and pre-assembled all the materials you need to create your own Water4Gas project quickly and easily. This is a very easy e inexpensive way to enter the world of green energy, and start saving money on fuel and making a huge impact by reducing emissions.
The Water4Gas kit saves you time by providing the components ready-to-install.
This Complete Water4Gas Kits, are designed for fuel injected engines, up to 8.0 liters running on diesel or gasoline. It may be installed on cars, small trucks and SUV's and depending on the model you choose could Include:
Single or Dual Supply 1-6 cells hho kits ready-to-install
1 Vacuum kit ready-to-install including the connectors and check valves(spark arrest)
1 Wiring Harness Crimped and ready-to-install
1 PCV Enhancer ready-to-install
1 Map Sensor Enhancer ready-to-install
1 Fuel Heater ready-to-install
1 Full set of instructions for Assembly, Installation and Maintenance
The Water4Gas kit will save time and energy when rounding up the parts needed from independent suppliers. The first 1 cell Electrolyzer we manufactured took 2-3 weeks to acquire all the parts, and then cost almost $300.00 after paying retail prices and shipping costs.
This kit will require you gluing the final parts together. Next is to climb under the hood of your car and connect the vacuum line from the Electrolyzer unit to your engine’s intake manifold or air induction system, or both depending on model, the power and finally the MAP sensor enhancer or any other enhancer and you are done.
If you are interested in a larger system, don’t worry. All our Water4Gas kits are compatibles and have an easy upgrade path. Any Water4Gas Kit can be upgraded up to 18 cells immediately!
We believe you will be very happy with your purchase!
At ELCARSITE.COM we are dedicated to creating wonderful experiences for our customers “ONE AT A TIME”, for this reason we offers the best support and parts along with selling the Complete Water4Gas Kit. This allows you to buy replacement parts, or to only order the harder to find components you need to build your own. The purpose of this system is encouraging the wide spread use of alternative fuels. Hydrogen plays an important role in abundant, safe energy for each of us, and the world at large.
When using the Water4Gas Kit, owners often experience a positive increase in mileage and fuel savings. 25% to 250% appear to be the range in testimonials. 25% today is around $0.60 per gallon saved on gas!
Additional Information:
This Water4Gas Kit requires you to purchase a few accessories to install it, small gas hoses(when installing a fuel heater) and seal the vacuum lines(Amazing Goop included).
For more information about the popular Water4Gas movement, including technical data and a preview of the many benefits, please visit the link below:
</SPAN>
table.gadget{background-position:0%;background:tr ansparent none;border-collapse:collapse;border: 0;clear:none;float:none;f ont-family:arial,sans-serif;font-style:normal;font-variant:normal;height:aut o;letter-spacing:normal;line-height:normal;margin:0;pa dding:0;text-indent:0;text-transform:none;top:auto;v ertical-align:middle;white-space:normal;width:auto;w ord-spacing:normal;}table.gad get span.title a:hover,table.gadget span.title a:visited,table.gadget span.title a:active,table.gadget span.title{font-size:12px;color:#0000cc}t able.gadget span.powered a:hover,table.gadget span.powered a:visited,table.gadget span.powered a:active,table.gadget span.powered{font-size:10px;color:#0000cc}Google Translate My Page
MOST POPULAR Water4Gas Kit MODELS:
This one cell model is designed for engines up to 1.8 liters running on gasoline or diesel. It may be installed on cars and small trucks and Includes:
Single Supply 1 cell Water4Gas Kit ready-to-install
1 set of hardware installation
Dual Supply 1 cell Water4Gas Kit ready-to-install
This one cell model is designed for fuel injected engines up to 1.8 liters running on gasoline. It may be installed on cars and small trucks and Includes:
This one cell model is designed for engines up to 1.8 liters running on carbureted gasoline. It may be installed on cars and small trucks and Includes:
This super complete one cell model is designed for fuel injected engines up to 1.8 liters running on gasoline. It may be installed on cars and small trucks and Includes:
This 2 cells model is designed for engines up to 3.8 liters running on gasoline or diesel. It may be installed on cars, small trucks and SUV's and Includes:
Single Supply 2 cells Water4Gas Kit ready-to-install
This 2 cells model is designed for fuel injected engines up to 3.8 liters running on gasoline. It may be installed on cars, small trucks and SUV's and Includes:
This super complete 2 cells model is designed for fuel injected engines up to 3.8 liters running on gasoline. It may be installed on cars, small trucks and SUV's and Includes:
This 4 cells model is designed for engines up to 5.4 liters running on gasoline or diesel. It may be installed on cars, trucks and SUV's and Includes:
Single Supply 4 cells Water4Gas Kit ready-to-install
This 4 cells model is designed for fuel injected engines up to 5.4 liters running on gasoline. It may be installed on cars, trucks and SUV's and Includes:
This super complete 4 cells model is designed for fuel injected engines up to 5.4 liters running on gasoline. It may be installed on cars, trucks and SUV's and Includes:
This 6 cells model is designed for engines up to 8.0 liters running on gasoline or diesel. It may be installed on cars, SUV's, full size & large trucks, buses, tractors, heavy equipment and generators and Includes:
Dual Supply 6 cells Water4Gas Kit ready-to-install
This 6 cells model is designed for fuel injected engines up to 8.0 liters running on gasoline. It may be installed on cars, SUV's, full size & large trucks, buses, tractors, heavy equipment and generators and Includes:
This super complete 6 cells model is designed for fuel injected engines up to 8.0 liters running on gasoline. It may be installed on cars, SUV's, full size & large trucks, buses, tractors, heavy equipment and generators and Includes:
: 14369D~149::p laying_music::playing_mus ic::playin g_music::p laying_music:
التعديل الأخير تم بواسطة cars admire ; 01-05-2011 الساعة 12:17 AM
قديم 01-05-2011, 12:30 AM
hima elgmal hima elgmal غير متواجد حالياً
hima elgmal is a splendid one to beholdhima elgmal is a splendid one to beholdhima elgmal is a splendid one to beholdhima elgmal is a splendid one to beholdhima elgmal is a splendid one to beholdhima elgmal is a splendid one to beholdhima elgmal is a splendid one to beholdhima elgmal is a splendid one to behold
افتراضي رد: حقيقة استعمال الماء كوقود 100% !!!!!!!!!
مع احترامى الشديد لحضرتك
بس هى الترجمه هتنزل امته
قديم 01-05-2011, 12:48 AM
الصورة الرمزية MmFFoR
ان شاء الله حترجم الموضوع و اضيف الترجمة بكرة
شكرا يا ادماير
واحشانة موضوعاتك اللي في الجون
قديم 01-05-2011, 01:06 AM
مميز رد: حقيقة استعمال الماء كوقود 100% !!!!!!!!!
المشاركة الأصلية كتبت بواسطة hima elgmal مشاهدة المشاركة
الترجمه مش هتنزل
Customer Service: HHO Kit Order Status, Missing or Damaged HHO Kit Orders, Invoices
Contact Ads Sales Support: Have questions before purchasing Advertising on this site?
2710 S SAN JOAQUIN AVE.
TUCSON, AZ, 85713
USA
Ph:520-903-1913
fax:520-903-1913
التعديل الأخير تم بواسطة cars admire ; 01-05-2011 الساعة 01:23 AM
قديم 01-05-2011, 01:14 AM
مميز هناك العديد من البرامج المجانية للترجمة عبر الانترنيت !!!!!!
شكرا يا ادماير
الاخ العزيز
بدون اساءة لشخصكم الكريم والمحترم
اترك الترجمة لكل من يهمه الامرفقط!!
لذة المعرفة فى الجهد والبحث
المتعطش الدائم لها وليس فى
امتلاكها مهضومة مجهزة للاستخدام
مع جزيل الشكر لاهتمامك الدائم
بموضوعاتى !!
G IFT4U
كما انه هناك العديد من البرامج المجانية للترجمة عبر الانترنيت !!!!!!
TUCSON, AZ, 85713
USA
Ph:520-903-1913
fax:520-903-1913
التعديل الأخير تم بواسطة cars admire ; 01-05-2011 الساعة 01:24 AM
المال, تقنية تحويل الماء لوقود
الساعة الآن 08:06 AM.
