قديم 08-04-2011, 11:52 PM
من انا؟: احمد حمدي
الموقع: البحيره
افتراضي الانجلون سياره انجليزيه وليست صينيه ؟
Full Detailed unique appearance not only of England SC5-RV
Hits: 672 Last updated: December 10, 2010 09 35 pm when the font size: [big] [middle] [small]
In general, the main consumer groups of young car always make efforts in design: cool, personalized fashion modeling is its compulsory nature of England is full of flavor SC5-RV is no exception. But before the test drive Shique listed SC5-RV shape in the outside except Xiaobian given more to come.
"Superfluous" in Journey Into Amazing Caves
Appearance of the features we all familiar with, Xiao Bian will not go into here, too, let us look at cut open the "superfluous" after the other features of it:
Before entering the car, let's take a look at the British SC5-RV seal process is. On the door panels and door frames are wrapped around the seal, and is a full circle, double sealed barrier to more effective noise, and in its own brand of small cars in the sealing process such as this are rare.
Greeted the steering wheel shape is quite stylish, but small grip body ring; the barrel body of the instrument panel was designed for the young movement of its characteristics, color, lighting applications has improved a lot, looks a bit delicate feeling.
Three-dimensional convex shape of the center console, the hexagonal pattern in the performance of a mechanical beauty, about the plastic decorative panels made of aluminum material of the effects of drawing, it looks a little bit high sense; and as all the standard navigation system equipment is where the most praiseworthy, while reproducing all the control buttons integrated in the touch-screen navigation, the panel makes the whole center console is very simple, by two kinds of external storage devices (SD / USB), the user can have a rich selection of music, young people are very similar tastes.
SC5-RV's interior design is very thoughtful, with as many as 18 storage cells, beverages, cell phones, high-speed cards, coins, umbrellas are related to storage space,, instrument panel storage box can be used as small change the lower left box, high-speed down the change, notes can be placed inside, it is to hand; deputy under the driver's seat can easily accommodate a small drawer Ms. high heels, is a commendable small details. Front seatback storage bags, rear passengers on the good storage space.
Many models are not original to the consumer with fire extinguishers, which makes the car even after we run trips Auto Parts City. Has been unlucky in this respect but not mean. Light water fire extinguisher is not only small, light weight and put the driver can reach out to enough to place in the critical moment for the owners to secure more time.
Size is not dominant, but tolerance is
SC5-RV of the length and breadth for the 3919 × 1745 × 1505mm, wheelbase 2461mm. Compared with major competitors, body length and wheelbase, not dominant, but it has some flexibility in the car, turning radius of 5 meters, in the narrow road turned more easily. Width and height slightly better.
We test drive the SC5-RV offers leather seats, seat shape is very consistent with oriental figure, and has some support, while a reasonable benefit from dashboard design: 180cm drivers who will not be less than too many complaints. Enough leg space, stretching the legs can be natural.
The rear seats flat, sitting more straight, with plenty of head room and leg space, which does not feel awkward sitting in a long time. SC5-RV in the back is obviously the standard three, it offers three separate adjustment head, in the middle there is a separate three-point seat belts, full-flat floor makes the middle passenger's feet are not affected. Special child seat interface design, but also the general trend.
"Heart" is not active in beating
The listing of SC5-RV equipped with a number MR479QA only 1.5 liter engine, which sets the early 1.5L engine is a lucky self-developed engine, in which there are plenty of low-speed power output, the response is also more sensitive. Maximum output power of 69kw, the maximum torque of 135Nm. Both figures are lower in its class among the data, the only bright spot is that transfer can be achieved in the 3400 peak torque, high torque characteristics of the low turn helps to ease urban driving.
Matching 5-speed manual transmission is relatively mature portfolio, shift smoothly, but the intensity of the clutch a bit stiff, binding sites is relatively vague, need to pay more to adapt.
Sound when the engine idling and no real critical engine parts to 3500 rpm and a little bit small surprise, the dynamic response becomes positive, if used to use this power when overtaking, speed confidence. Overall, however, how much power is still far from straightforward.
SC5-RV hydraulic power steering more relaxed nature, but if you want to get rich from it the way the body feedback and precise steering feel is not likely, after all, the positioning of its city car travel, not a control type of car. In contrast, clutch, brake pedal foot feeling a little tight, but the proportion of better control and drive a short way to get started, did not feel the slightest bit awkward. Sitting high and low power characteristics of high torque transfer, easy steering, the pedals have a sense of proportion, creating a SC5-RV relaxed urban driving performance.
The highway, to the SC5-RV speed to 120km / h, still need some patience, high-speed dynamic performance is not so calm city. Fortunately, in the 120km / h or less, the stability of the performance of the car is not bad, in their own brand on the car which belongs to the level. From a practical point of view driving, 100km / h corresponding to the speed of 2500 rpm, 120km / h speed corresponding to 3000, is a normal performance.
SC5-RV with McPherson front suspension structure after the torsion beam, tuned slightly more rigid, even if the body center of gravity high and cornering roll control was reasonable. SC5-RV chassis performance has some surprises, the overall sound, not the past performance of brands that piecemeal, 60km / h over a continuous slow to cope with the time, but do not think suspension, the chassis effort really need to accumulate, Geely recently several new The chassis has a good performance.
After a day of test drive, Xiao Bian England SC5-RV for this may have a deeper understanding: not just unique appearance, its interior design and workmanship of human nature, does not take significant force to the meat of the 1.5L 6 million less than the price, really has no small cost, and the high price only with version with version four thousand yuan higher than the low, but increased the positive and co-pilot airbags, parking sensor, seat belt reminder system does not function leather upholstery seat and 15-inch alloy wheels and other configuration, making this section of the AO with low-cost high-level small car must be more among the young breed of consumers.
حصري من الموقع الرسمي للسياره
قديم 09-04-2011, 12:02 AM
الصورة الرمزية سالم سلامه
سالم سلامه سالم سلامه غير متواجد حالياً
سالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond reputeسالم سلامه has a reputation beyond repute
افتراضي رد: الانجلون سياره انجليزيه وليست صينيه ؟
ماهذا ياباشا اخوك ثقافته فرنساوى هههههههههههه
قديم 09-04-2011, 12:10 AM
من انا؟: احمد حمدي
الموقع: البحيره
المشاركة الأصلية كتبت بواسطة سالم سلامه مشاهدة المشاركة
معلش اصل ادمير عداني ده معناه ان العربيه انجليزي ومنتجه فالصين بالشراكه زي العربيات الالماني وغيرها كتير
قديم 10-04-2011, 03:18 AM
mms mms غير متواجد حالياً
mms has a brilliant futuremms has a brilliant futuremms has a brilliant futuremms has a brilliant futuremms has a brilliant futuremms has a brilliant futuremms has a brilliant futuremms has a brilliant futuremms has a brilliant futuremms has a brilliant futuremms has a brilliant future
ما هذا الابداع الظاهر من كم الكلمات ان السياره انجليزى قوى .
قديم 10-04-2011, 03:30 AM
الصورة الرمزية ابوشروق
ابوشروق ابوشروق غير متواجد حالياً
الموقع: القاهره
ابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond reputeابوشروق has a reputation beyond repute
ايه يا عم احمد انتا لسه مرشح نفسك للانتخابات قلبت انجليزى ليه يعم ترجم للبحراوى اخوك اصوله واجداده من الدلنجات مش لندن
حبيبت قلبى سبيدر
الساعة الآن 09:35 PM.
