قديم 21-03-2011, 03:10 PM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Report: Hyundai Elantra faces pair of airbag recalls
Filed under: Sedan, Government/Legal, Safety, Hatchback, Hyundai
2009 Hyundai Elantra Touring - Click above for high-res image gallery
Hyundai has issued two airbag recalls that cover nearly 300,000 Elantras. The first recall, which involves some 188,697 vehicles sold between 2007 to 2009, will fix a passenger airbag issue. According to the automaker, the Elantra's front passenger seat contains a sensor that measures the weight of the passenger, but in the case of the affected vehicles, the sensor may not properly detect the passenger's weight. In the event of a crash, the airbag can deploy even if a child is sitting in the front seat. Hyundai says that the sensors could be damaged by moisture, so the automaker is adding a protective sleeve around the device.
The second recall concerns 95,783 2007-2008 Elantra models and involves a sensor used in the two-stage deployment of the passenger-side airbag. Most newer airbag systems employ a dual-stage deployment, with a sensor detecting if the occupant is sitting too close to the bag. In the event of a crash only the low pressure stage will deploy. In the affected Elantra models, electronic noise may confuse the sensor, and during a crash the sensor will revert to its default mode, which will cause both stages of the airbag to deploy. To fix this issue, a Hyundai technician will reprogram the airbag control module.
Hyundai will issue a formal recall notice to customers by April 8. Customers will be directed to a Hyundai dealer for a free of charge repair. Customers who already paid to fix this issue after March, 2010 will also be reimbursed for their cost.
Gallery: Review: 2009 Hyundai Elantra Touring
[Source: Detroit News]Report: Hyundai Elantra faces pair of airbag recalls originally appeared on Autoblog on Mon, 21 Mar 2011 08:01:00 EST. Please see our terms for use of feeds.
Read | Permalink | Email this | Comments
أكثر...
الساعة الآن 01:47 AM.
