العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > رينو RENAULT > رينو كليو Clio
رينو كليو Clio The Renault Clio is a supermini car produced by the French automobile manufacturer Renault. Originally launched in 1990, it is currently in its third generation. The Clio has seen substantial critical and commercial success, being consistently one of Europe's top-selling cars since its launch,[1] and it is largely credited with restoring Renault's reputation and stature after a difficult second half of the 1980s. Symbol of its success and its longevity, the Clio is the only car to have been elected European Car of the Year twice, in 1991 and in 2006.
قديم 17-12-2010, 02:35 PM
عاجل New Renault Clio III Sport 2.0 16v
New Renault Clio III Sport 2.0 16v Part 2
RENAULT Clio Sport 2 0 16V 201 PS
قديم 17-12-2010, 04:04 PM
الصورة الرمزية MmFFoR
افتراضي رد: New Renault Clio III Sport 2.0 16v
الكليو عربيه حلوه بس مش مرغوبة بالمره في السوق المصري و العالمي خصوصا لو مستعمل مش عارف ليه!
قديم 17-12-2010, 07:52 PM
عاجل رد: New Renault Clio III Sport 2.0 16v
because
some thing
the same looks like that!!
for an exampLe
MISFIRE ROUGH RUNNING
Clio's and Megane's etc. With individual pencil ignition coils are prone to misfire and rough running, with out test equipment, diagnose by substitution with new coil (about £40) until bad unit is found. These coils work in pairs 1 and 4, 2 and 3 and you find the partner will fail shortly after.
NON START NO CRANKING
If car not cranking and battery ok (headlights bright) check for bad connection on starter motor, it is very hard to see but you can reach it from the N/S of the car reaching behind engine follow wires to starter motor, you want to just wiggle the small spade terminal on solenoid try not to pull it off as it is very hard to refit.
NON START CRANKING
Most Renaults have a CPS (Crankshaft Position Sensor), some times these become contaminated with particles from the clutch and can stop them working. If possible remove and clean. Some times it can be very hard to get senor out a trick that will some times work is, if you can see a hole in the bell housing near the CPS sensor try spraying carburettor cleaner onto the flywheel when cranking engine this will some times clean the sensor and vehicle will start. If still no luck may need new sensor, see non start section for testing.
MEGANE 1996-2003 NONSTART CLICK HERE
MEGANE 2005 BATTERY GOING FLAT
There is a known problem with the radio not switching off fully and draining the battery, disconect radio wiring loom to test, if battery stays charged will need new radio.
IMMOBILIZER PROBLEMS
KEYCARD PROBLEMS CLICK HERE
LATER CLIO'S
Later immobilizer sometimes gets unsynchronised just turn Ignition on for 3-5 minutes turn off and restart car.
If fob not working, just hold down button until to LED stops flashing.
INFA-RED REMOTE
Older remote system (clio's Laguna etc) with infa-red can suffer water leaks from sunroof or roof aerial into the receiver between sun visors, if it is the first time it has happen, you maybe able to unclip receiver unit and dry out.
KEYLESS NON START
If a Laguna, Megane with keyless system won't start worth checking clutch switch as connector has be known to get knocked off.
AIR BAG LIGHT ON
If Clio air bag light keeps coming on, check cables under passenger seat, cable tie them together.
CLIO LOSS OF SIDE LIGHTS
Side lights not working, check that the relays are push in correctly, fuse box is above passengers foot well.
قديم 25-10-2011, 07:58 PM
قديم 26-10-2011, 10:52 PM
clio, sport
الساعة الآن 06:52 PM.
