قديم 17-12-2010, 02:30 AM
انذار SaLt Water into FueL !!??
How to Burn Water ??!!
save aLot of money
قديم 17-12-2010, 08:54 AM
افتراضي رد: SaLt Water into FueL !!??
ححاول لما أرجع من السفر أشوف نظام القصه دى
وياريت لو عندك داتا هندسيه مكتوبه
حول هذا المعنى
لافينى بها
يمكن نعرف
save aLot of money
قال رسول الله
___________
م/سمير
قديم 17-12-2010, 12:50 PM
عاجل رد: SaLt Water into FueL !!??
حول هذا المعنى
لافينى بها
يمكن نعرف
save aLot of money
ok
i shall try
all my best
م/سمير
التعديل الأخير تم بواسطة cars admire ; 17-12-2010 الساعة 12:56 PM
قديم 17-12-2010, 11:04 PM
ok
i shall try
all my best
م/سمير
John S. Kanzius (March 1, 1944 – February 18, 2009) was an American inventor, radio and TV engineer, one-time station owner and ham radio operator (Call Sign K3TUP) from Erie, Pennsylvania. He invented a method that has the potential to treat cancer, inspired by his own such battle.[1] [2] He also demonstrated a device that generated flammable hydrogen-containing gas from salt-water-solution by the use of radiowaves. In the media this was dubbed "burning salt water". Both effects involve the use of his radio frequency transmitter.
Kanzius, an autodidact, stated that he was motivated to research the subject of cancer treatment by his own experiences undergoing chemotherapy for treatment of non-Hodgkin's lymphoma.[3][4]
Cancer therapy
Kanzius RF Therapy is an experimental cancer treatment that employs a combination of either gold or carbon nanoparticles and radio waves to heat and destroy cancer cells without damaging healthy cells.[5][6][7]
The specific absorption rate for radio waves by living tissue in the proposed wavelengths and intensity levels is very low. Metals absorb this energy much more efficiently than tissue through dielectric heating; Richard Smalley has suggested that carbon nanotubes could be used to similar purpose.[8] If nanoparticles were to be preferentially bound to cancer sites, cancer cells could be destroyed or induced into apoptosis while leaving healthy tissue relatively unharmed.[9] This preferential targeting represents a major technical challenge. According to a presentation by Dr. Steven Curley, the types of cancer potentially treatable using Kanzius RF therapy include essentially all forms of cancer.[10]
Kanzius built a prototype Kanzius RF device in his home, and formed Therm Med., LLC to test and market his inventions.[11][12] The device was successfully tested at University of Pittsburgh Medical Center in 2005.[2] As of 2007-04-23, preliminary research using the device at The University of Texas M. D. Anderson Cancer Center[13][14][15] and the University of Pittsburgh Medical Center[11] has shown early promise. If federal approval is granted, testing on human patients may follow.[9][16][4]
[edit] Water-related discovery
Later in 2007, Kanzius announced that the same radio frequency transmitter can also be used to generate a hydrogen-oxygen mixture dissociated from salt water.[14][17] The discovery was made accidentally while he was researching the use of radio waves for desalination. Kanzius said that "In this case we weren't looking for energy, we were looking for something that might do desalinization. The more we tried desalinization, the more heat we produced, until we got fire".[17] Kanzius admitted that this process could not be considered an energy source, as more energy is used to produce the RF signal than can be obtained from the burning gas and stated in July 2007 that he never claimed his discovery would replace oil, asserting only that his discovery was "thought provoking."[18] The details of the process are still unreleased pending the issuance of a patent.[18]
Kanzius proposed that the flame is produced by burning of hydrogen and oxygen, released from the water by radio waves "forcing together" the "normally separated" hydrogen and oxygen in the water, a process he calls "reunification". [18] In water (H2O), hydrogen is covalently bonded to oxygen, and thus the process must "reunite" pairs of hydrogen atoms and pairs of oxygen atoms, releasing dihydrogen (H2) and dioxygen (O2). The energy from the radio waves is absorbed by the water and splits the water into hydrogen and oxygen which then react together to reform the water and re-release the energy and form a flame. In other words, the process turns radio energy into chemical energy, which then turns to heat and light energy, but does not "take energy from water". Rather, energy is put into the water in order to break it up into its components, which now may combust. The water torch, a form of oxyhydrogen torch, is an earlier example of the process of breaking down water and then recombining oxygen and hydrogen to release heat and light energy.[citation needed]
Nevertheless, this discovery may be a clean way to break down water into its elements and perhaps a cheaper way than electrolysis which in most forms produces toxic output from chemical reactions with the electrodes, or otherwise is produced with platinum electrodes, which are very expensive. It is difficult to compare the processes without detailed analysis.[citation needed]
Kanzius' experiment has been confirmed by Rustum Roy, a materials scientist at Pennsylvania State University, in a demonstration before the Material Science faculty, using Kanzius' RF transceiver[19], which Kanzius had brought to the lab for the day.[14] On his website, Roy writes: "It is clear that Mr. Kanzius has demonstrated the ability to dissociate aqueous solutions of sodium chloride at normal sea water concentrations into hydrogen and oxygen."[20][14][17]
According to Roy, "The salt water isn't burning per se, despite appearances. The radio frequencies act to weaken the bonds between the elements that make up salt water, releasing the hydrogen. Once ignited, the hydrogen will burn as long as it is exposed to the frequencies."[21] The temperature and flame color varies with water solutions and concentrations.[21]
قديم 17-12-2010, 11:16 PM
حول هذا المعنى
لافينى بها
يمكن نعرف
save aLot of money
م/سمير
Possible Energy Source: Burning Seawater
The discovery has scientists excited by the prospect of using salt water, the most abundant resource on earth, as a fuel.
Rustum Roy, a Penn State University chemist, has held demonstrations at his State College lab to confirm his own observations.
The radio frequencies act to weaken the bonds between the elements that make up salt water, releasing the hydrogen, Roy said. Once ignited, the hydrogen will burn as long as it is exposed to the frequencies, he said.
The discovery is "the most remarkable in water science in 100 years," Roy said.
"This is the most abundant element in the world. It is everywhere," Roy said. "Seeing it burn gives me the chills."
Roy will meet this week with officials from the Department of Energy and the Department of Defense to try to obtain research funding.
The scientists want to find out whether the energy output from the burning hydrogen - which reached a heat of more than 3,000 degrees Fahrenheit - would be enough to power a car or other heavy machinery.
  • Play CBS Video Video Waving Cancer Away Leukemia patient John Kanzius has developed a new cancer-fighting technique that uses radio waves to destroy cancer-causing agents. Benno Schmidt reports.
  • Researcher John Kanzius, seen here experimenting with radio waves to kill cancer cells in a 2005 photo, discovered that salt water could be "burned" by exposing it to a radio wave generator. The finding has some excited about salt water's potential as an abundant fuel source. (AP Photo/Gene J. Puskar)
HHO technology has finally been developed that lets average people like you and me run our cars with water! Below I have answered most of the important questions about this new technology.
How does HHO for gas work?
HHO stands for hydrogen-hydrogen-oxygen. This is the chemical recipe for water. When water is broken down into its basic components, it turns into hydrogen and oxygen atoms. HHO technology converts water into these two important gasses and mixes them with your car's fuel. Hydrogen is very flammable and will greatly improve your gas mileage! This fuel blend will not only save you gas, but it will help the environment too!
How do you convert a car to use hho technology?
To run your car with water, you much first install an HHO generator in your engine. Using a special HHO kit, you can easily set up a HHO generator in your cars engine. HHO kits can be used in any car, truck, or suv. Once installed, you simply add water and let it work! The kit will save tons of money in gas and uses very little water.
Is this a practical thing to do to my car?
HHO kits are very affordable. Also, the process is completely reversable. If you don't want to use HHO for gas any more, you simply remove it. Once you start saving money with one of these kits, you will never look back! The technology is getting very popular these days. More and more people are installing these in their cars.
Where do I get a kit?
Kits are available online direct from the manufactorers. Unfortunately, due to patent laws, this won't be available in stores for a while. The good news is that the kits available are very high quality and cheap! For a list of kits
Learning How To Turn Water Into Fuel
More and more people around the world are getting very excited about learning how to turn water into fuel. They are using water fuel conversion kits. These kits reduces the dependency of gasoline for your car.
Oil prices are rising more and more each and everyday. It seems like there is nothing we can do about it. It appears that we are victims of the oil companies. But now there is a way out.
In the Bible days the miracle was when Jesus turned water into wine. In this day and age the miracle is that we can turn water into fuel. It seems like a miracle, but the technology has been around for the over 80 years. It has been researched and proven safe and effective
Even though we say, run your car on water, you do not really run your car on 100% water, not yet anyway. The truth is we are not totally replacing gasoline with water. Instead, we are using water as a supplement to aid the combustion of gasoline in the engine, thus reducing fuel consumption.
Some of the benefits are:
Less of wear and tear on the engine of your car.
Water is a cleaner source of energy and it will help your engine to improve its performance.
Your engine would run smoothly and also have much more mileage. The mileage can increase up to 60% in some cases.
Another benefit of switching over to the hydrogen car system is that when water is broken up, oxygen would be released. This is much healthier than the harmful carbon exhausts of the vehicles that use oil to run. It cuts down on harmful emissions that damage your health and pollute the environment
By running your car on water, you are polluting much less, so you are entitled to tax reductions for running a more environmentally friendly vehicle
Gas prices are not going to go down anytime soon so you need to get your hands on the plans to build your own hydrogen generator. It is inexpensive and the parts you need are readily available locally at your electrical supply store. It is also completely safe to run cars on water. Your car won't be running just on water, but with the water added according to instructions you will be saving tons of trips to the gas station.
Like thousands of people around the world, you can buy a kit and the parts together for $100.00-$150.00. Don't fall victim to buying a kit already put together, or a ready-built kit, that will cost you upwards of $1,000. It is far better to assemble your own water car conversion kit from instructions you can find online. You can actually build and apply your own kit over the weekend. There are several places on the internet where you can find these kits. Check them out and save tons of money and gasoline. For more information on how you can run your vehicle on water and reap the benefits, please visit: http://www.UsingWaterAsFuel.info
التعديل الأخير تم بواسطة cars admire ; 17-12-2010 الساعة 11:22 PM
fuel, water
الساعة الآن 02:48 PM.
