العودة   مصر موتورز مجتمع السيارات > السيارات الكورية والماليزية > كيا KIA > برايد Pride
برايد Pride اقدم سيارات كيا انتشاراً فى مصر تم اعادة تجميعها استنادا على موديل فورد - مازدا المسماه فورد فيستيفا او مازدا 121 ويعاد تصنيعها فى ايران وسوريا حتى الان
قديم 16-12-2010, 11:19 PM
عاجل Bosch Spark PLug TechnoLogy
قديم 31-03-2011, 05:55 PM
افتراضي رد: Bosch Spark PLug TechnoLogy
قديم 06-04-2011, 11:22 PM
eyquem
plasma spark plugs
Brisk Premium ZC Spark Plug is a spark plug that has no grounding electrode
firestorm spark plugs
e3 spark plugs
The Brisk Premium LGS spark plug
I think we can using a spark plug non-fouler to extend the o2 sensor out of the exhaust stream. Kind of like this:
The old spark plugs are the same size as a traditional o2 sensor bung. Unfortunately, as the OP mentioned, the tacos use a two bolt mounted o2 sensor. I think the only way around the problem is to get the o2 sensor simulator. An o2 sensor heat sink isn't made for our style of o2 sensor that I'm aware of.
aftermarket o2s have a plate that bolts up and the o2 screws into the plate i bet that would be perfect but idk how effective that method is... i wonder if seeing to low of a reduction after the cat could throw a code too.... either way youd need an aftermarket o2 and the simulator is cheaper and very easy to install its only 3 wires and just 3m tape it to the ac duct or something. i somehow got my first o2 sensor the first time i did it because depending on which way you count if you count from the opposite side its the front o2 lol i believe thats what i did something like that tho its been a while, didnt hurt anything truck was just slow as balls. i instantly knew and fixed it.
: 14369D~149:
قديم 06-04-2011, 11:23 PM
. R and L Visible
Edensburg PA
Reflex Giant
The Reflex Ignition Co.
Cleveland Ohio
http://www.enginebrain.com/feedback.html
: 14369D~149::1 4369D~149:
قديم 06-04-2011, 11:46 PM
الصورة الرمزية MmFFoR
مش فاهم؟
bosch
الساعة الآن 12:56 PM.
