العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > فولكس > VW News Archive
VW News Archive ارشيف الاخبار نقلاً عن المواقع العالمية
قديم 15-12-2010, 09:10 PM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Volkswagen recalling nearly 380,000 cars over fire risk
Filed under: Convertible, Coupe, Sedan, Wagon, Recalls, Safety, Hatchback, Volkswagen
2009 Volkswagen Jetta TDI - Click above for high-res image gallery
Volkswagen AG has just issued a recall of nearly 380,000 cars due to the potential for fuel leaks which could lead to a fire. According to The Detroit News, A total of 266,936 Jetta, Jetta SportWagen, Golf and Rabbit models from the 2007 to 2009 model years are affected, as well as an additional 110,350 New Beetle models (both hardtop and convertible).
The National Highway Traffic Safety Administration has issued an official recall bulletin, stating:
"The Jetta, Jetta SportWagen, Golf and Rabbit vehicles may have a small plastic tab located on the windshield washer fluid reservoir that may chafe against an underhood fuel supply line. The New Beetle and the New Beetle Convertible vehicles may have a fastening clamp on a hydraulic hose of the power steering system that may be located in an improper position which could cause chafing against an underhood fuel supply line."
In both instances, chafing could result in a fuel leak, which in the presence of an ignition source, could result in a fire.
NHTSA states that dealerships will either remove the plastic tab from the windshield washer fluid reservoir or, in the case of the New Beetles, inspect the position of the fastening clamp. Either way, the fix won't cost owners a thing, and the recall is expected to ramp up by the end of January.
Gallery: 2009 Volkswagen Jetta TDI
[Sources: The Detroit News, NHTSA]Volkswagen recalling nearly 380,000 cars over fire risk originally appeared on Autoblog on Wed, 15 Dec 2010 12:58:00 EST. Please see our terms for use of feeds.
Read | Read | Permalink | Email this | Comments
أكثر...
الساعة الآن 04:51 PM.
