قديم 08-12-2010, 01:15 AM
منقول BRISK IS THE BEST SPARK PLUGS IN EGYPT NOW!
Homepage
Contacts Contact
Distributors Czech Republic
Distributors
Who we are Company's management
History
Awards
Photo gallery
Environment
Quality
Support FAQ Spark plugs
Glow plugs
Ask the question
Download
Catalogue Spark
plugs
Glow
plugs
Technical
ceramics
Ignition
electrodes
Sensors Other
products
BRISK Tábor a.s.
Vožická 2068, 390 02 Tábor
Tel: +420 381 492 111
Fax: +420 381 492 276
E-mail::
brisk@brisk.cz
Web:: www.brisk.cz
Spark plugs EXTRA
Wide range spark plugs with prolonged change interval
The centre electrode is from nickel alloy filled with cooper core. Two or three ground electrodes of BRISK Extra spark plugs enable the spark-gap construction which is opened into combustion chamber. This improves mixture ignition in the initial phase of ignition and inhibits flame extinction caused by heat transfer from electrodes.
The use of more electrodes extends change interval up to 60.000 km. Length stability of electrode gap and stability of thermal properties for long operating time predestine these spark plugs for use on wide variety of both, most up to date engines and engines of older construction.
These spark plugs are manufactured in two-electrode design with possibility of spark-over from burning deposits on insulator tip and in three-electrode design, too.
Correct choice of spark plug you find in catalogue BRISK.
TC LDC
Replacement CHANGE interval:
max. 60.000 km
SMS AUTO SPARE PARTS TRADING L.L.C.
Dubai-Deira
Naif/al remal building-sh 10
U.A.E.
E-mail: smsfzco@yahoo.com
Tel: 009714-2348061
Fax: 009714-2348062
GSM: 00971506503087
IT IS available NOW IN CAIRO EGYPT ELTAWFEKIA AREA !
FACE OF MASRAH GALAL EL SHARKAWY DIRECTLY !!ON THE MAIN STREET !!
Spark plugs PREMIUM
The unique patent-registered spark plugs
- completely new spark gap shape
- higher power
- better acceleration
- superior fuel energy utilization
LGSGS
max. 30.000 km
Example of marking: DO15LGS, LOR14LGS, AR08GS...
PREMIUM ZC / ZS
Two auxiliary electrodes deposited on insulator tip with special patented technology enable simultaneous flashover of two surface sparks and one air spark by single impulse of ignition system. Each spark has chance to jump around full circumference of auxiliary electrode (360°). The spark gap protrudes deep into combustion chamber and improves initial flame front propagation. A number of sparks and sufficient distance between them decrease probability of incomplete ignition of mixture in combustion chamber and increase flame propagation rate and engine power.
ZC / ZS
max. 20.000 km
Example of marking: DR14ZC, LR15ZC, L10ZS...
PREMIUM LGS / GS
Spark gap enabling surface flashover (extreme long) with the possibility of spark-over around full circumference 360°. Ignition spark will jump always at point of highest fuel concentration. Substantially higher flame propagation rate in the initial phase of flame propagation in the combustion chamber enables superior fuel energy utilization. The combustion velocity in conjunction with knock sensor assures engine-power increase. The spark gap of spark plugs BRISK PREMIUM "LGS" is protruded deep into combustion chamber.
Spark plugs A-line yttrium
Complete product range of spark plugs consisting of field-proven types
Complete product range for sale consisting of field-proven types of spark plugs with electrodes from yttrium alloy and with constructional correction which improves flame front propagation and reduces voltage demand. It covers 97% of car fleet.
Change interval is extended up to 100.000 km. Optimization of the basic assortment of spark plugs needed for installation on most engine types.
Single electrode wide-range spark plug
with center electrode from yttrium alloy with high resistance to burnings. Perfectly meets engine demands in all operating modes. Constructional adjustment of ground electrode into shape of letter „A“ improves flame front propagation in the initial phase and reduces demand on voltage supplied by ignition system.
Extension of change interval up to 45.000 km.
Type: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 28, 32, 33, 34, 36, 38
Wide range spark plug with two electrodes and with center electrode from yttrium alloy with high resistance to burnings. Opened spark gap improves mixture ignition in the initial phase of combustion process. Two ground electrodes enable spark-over from burning deposits on insulator tip and reduce possible misfiring of the mixture.
Extension of change interval up to 55.000 km.
Type: 20, 23, 26
Three-electrode wide range spark plug with center electrode from yttrium alloy and with high resistance to burnings. Opened spark gap improves mixture ignition in the initial phase of combustion.
Three ground electrodes enable extension of change interval up to 70.000 km.
Type: 1, 21, 22, 24, 27, 29, 37
One-electrode wide range spark plug with center electrode with platinum contact and ground electrode from yttrium alloy. This configuration enables optimize the thermal balance of active parts of spark plug such a way that it covers engine needs under all operating modes for a very long time period.
Constructional adjustment of ground electrode improves flame front propagation and reduces demand on voltage supplied by ignition system.
Extension of change interval up to 100.000 km.
Type: 25, 31, 35, 39, 40
Comparison graph of lifetime and voltage demand of individual spark-plug product lines:
قديم 19-12-2010, 02:29 PM
مميز رد: BRISK IS THE BEST SPARK PLUGS IN EGYPT NOW!
Product Information: Features & Benefits
Ignite Your Vehicle's Performance & Save on Gas
Halo Performance Spark Plugs are designed and engineered to help you maximize fuel efficiency, reduce harmful emissions, and improve your vehicle's performance. They are built using state-of-the-art facilities and follow the highest quality control standards.
The Halo Spark Plug uses a unique and innovative concept that replaces the conventional single or newer multiple electrode designs with a single circular "HALO" design. The result is a revolutionary and exclusive 360° Firing Technology that generates rotating sparks at multiple points along the halo ring, igniting the air/fuel mixture much more quickly and efficiently.
Unlike conventional air gap spark plugs, which generate a short spark that travels in a direct path, the Halo uses more efficient surface air gap firing technology, which produces a longer, more powerful spark that arcs towards the ground electrode for maximum firing performance.
The patented "Halo Ring" design of the ground electrode provides optimal access to the air/fuel mixture and is instrumental in helping to improve combustion efficiency. Since the flame kernel is not blocked as in other spark plugs, it can travel upward through the ring into the combustion chamber, igniting the air/fuel mixture quicker than conventional spark plugs. This results in a more efficient combustion process, leading to improved fuel efficiency, enhanced engine performance, and reduced emissions.
The Halo's cutting-edge Firing Technology ignites the air/fuel mixture up to 30% faster than conventional spark plugs, resulting in a more efficient combustion (approximately 95% versus 75% for standard plugs) and maximum utilization of the energy contained in the fuel. In other words, more of the fuel is burned and converted into "work" before it is vented off by the exhaust valve.
This quicker initiation allows for a more complete burn of the fuel inside the combustion chamber. This yields more power from a given volume of fuel, resulting in an improvement in fuel economy of up to 10% (as shown in the trial results and testimonials, users often report MPG gains of 10 to 20%).
The more complete burn also reduces the amount of unburned Hydrocarbons, Carbon Monoxide, and Oxides of Nitrogen (NOx). As a result, harmful emissions are reduced by as much as 20%, making the Halo an environmentally friendly product.
In addition, both horsepower and torque are increased by up to 5%. Although a 5% increase in HP may not sound like a lot compared to superchargers and turbochargers, the Halo can instantly boost your horsepower for a fraction of the cost of other products. This results in better throtle response, quicker acceleration, and greater towing capacity (ideal for for towing trailers and boats).
More Bang for Your Buck: Tests show that when the surface of the piston reaches top-dead-center (TDC) on the combustion stroke, the size of the flame front/head produced by the Halo Spark Plug is already six times the size of the flame front/head produced by conventional spark plugs. This means better fuel efficiency and more power.
Halo also features rotating sparks, which virtually eliminates point/gap erosion (and consequent degradation in performance - usually beginning at about 2,000 miles in standard plugs), reduces build up and increases wear resistance for an extended performance life. The multiple firing path performance characteristic of the Halo design resists plug fouling better, since alternate paths can be found in the event deposits begin to form on the center electrode. If these deposits occur on a standard plug in the most common firing location, it often inhibits or prevents firing, since another path is less likely to be found.
The center electrode is made of an Yttrium alloy, which has been used in spark plugs for racing cars for years. Yttrium is a rare-earth metal that provides remarkable protection against heat corrosion and surface erosion, further enhancing the Halo's service life and performance. Since Yttrium is much easier to mine, requiring only a fraction of the raw earth material necessary to produce a Platinum plug, it's a better choice for the environment.
LSG BRISK is proud to bring this advanced technology from the racing world to you.
Standard spark plugs must be gapped to ensure performance. This gapping is an inexact science at best and typically results in only one point of the standard side-wire electrode being at the properly specified distance from the center electrode. With the Halo, the gap is pre-set at the factory and never has to be adjusted, making it easy to install and maintain. This creates a consistent gap, which is always set for optimum engine performance.
The LSG Halo offers drivers and fleets a cost-effective and environmentally friendly solution to help increase fuel efficiency, maximize engine power, and reduce toxic emissions.
Revolutionary Halo Spark Plug, Proven to Increase Gas Mileage in Fleets by up to 10% while Reducing Emissions by up to 20%, Now Available to Consumers Online
LSG BRISK, LLC today announced that its revolutionary spark plug, the LSG Halo, is now available to consumers on its new Web site. The spark plug is the world's first to use an innovative 360° Firing Technology to improve fuel efficiency by up to 10% and reduce harmful emissions by up to 20%. The Halo is currently being used by various organizations, including cities, police departments and schools to increase the efficiency of their fleets.
LSG BRISK, LLC today announced that its revolutionary spark plug, the LSG Halo, is now available to consumers on its new Web site, www.lsgbrisk.com. The innovative spark plug uses a patented 360° Firing Technology to improve fuel efficiency by up to 10% and reduce harmful emissions by up to 20%. The Halo is currently being used by various organizations, including cities, police departments, and schools to increase the efficiency of their fleets and the company is making the technology available to the public in an effort to help consumers find relief from skyrocketing gas prices.
Gas prices have risen about 30% since February to a national average of $2.87 for a gallon of regular unleaded and will likely continue to climb towards the $3 level throughout the U.S. as demand continues to rise with the approach of summer.
"With soaring gas prices, we are pleased to make this technology available to consumers, giving them an opportunity to realize the same fuel savings that our fleet clients are currently enjoying. In addition, they will also be helping to protect the environment, and their health, by lowering vehicle emissions that contribute to acid rain, smog, and global warming," said Ram Mistry, executive VP of global sales.
Unlike conventional spark plugs, which generate a spark at basically the same location each time, the Halo features an exclusive 360° Firing Technology that generates rotating sparks that fire at multiple points along a circular ground electrode. Thanks to this unique design and cutting-edge firing technology, the Halo is able to ignite the air/fuel mixture approximately 30% faster than traditional spark plugs, resulting in a more efficient combustion (around 95% versus 75% for standard plugs) and maximum utilization of the energy contained in the fuel. This increased efficiency will help drivers increase their gas mileage, maximize engine performance, and lower harmful emissions such as Hydrocarbons, Carbon Monoxide, and Oxides of Nitrogen (Nox), which contribute to global warming and other environmental hazards.
Other benefits of the Halo include up to 5% increase in horsepower and torque, better cold starts, cleaner engines and smoother acceleration. Many customers have indicated that they noticed an improvement in performance immediately after installing the plugs, however, the company indicated that vehicles should be driven between 500 to 1000 miles before realizing the full fuel-saving potential of the Halo Spark Plugs.
One of the first organizations to experience the benefits of the LSG Halo spark plug was the City of Little Rock, Arkansas. Darryl Syler, the city's Fleet Maintenance Manager, decided to conduct a trial on the city's Police Fleet to see how the Halo would perform. He had the spark plugs installed on 12 Ford Crown Victoria Police Cruisers and field-tested for about four months. To ensure the accuracy of the results, a blind test was performed. When the results were in, the City of Little Rock concluded that the Halo spark plugs improved their fuel economy by an average of 11.5%.
Mr. Syler later remarked, "I would like to tell you...how pleased we are with the results that we have had with the Halo plugs that we have been running in our Ford Crown Victoria Police Cars. They have really produced great numbers on the fuel mileage. I look forward to continued success with the Halo plugs and I would recommend them to anyone that inquires. We have seen an 11.5% increase in fuel mileage, and as fuel prices go up, this is going to be a tremendous help in cutting our fuel costs."
Based on the positive results they achieved on the trial, the City of Little Rock has decided to retrofit their entire fleet with the LSG Halo spark plugs. Thanks to the efforts of Mr. Syler and his team in the Fleet Maintenance Department, the City of Little Rock will save approximately $225,000 annually on their fuel costs while helping to clean and preserve the environment.
The Halo Spark Plug has been extensively tested by various fleets in both the U.S. and Canada, using a wide variety of vehicles, with very successful results. Some of the organizations benefiting from its use include the City of Little Rock, AR (11.5% improvement in mpg), the City of Hot Springs, AR (10.8% improvement in mpg), McKinney Independent School District, TX (22% improvement in mpg), and Summit Pest Control, TX (16.7% improvement in mpg). For more trial results, information, and a video of the Halo's Firing Technology versus other plugs, go to www.lsgbrisk.com.
About LSG BRISK, LLC
LSG BRISK, LLC (www.lsgbrisk.com) is an innovative, forward-thinking automotive parts company, specializing in the development, manufacturing, and marketing of environmentally friendly and cost-effective solutions that improve fuel economy and protect the environment.
The Halo Spark Plug is the world's first to use advanced 360° Firing Technology to increase gas mileage, reduce emissions, and enhance engine performance.
قديم 31-03-2011, 05:29 PM
افتراضي رد: BRISK IS THE BEST SPARK PLUGS IN EGYPT NOW!
:fun_3 6_3_11[1]:
قديم 19-10-2011, 11:22 PM
Dubai-Deira
U.A.E.
Tel: 009714-2348061
Fax: 009714-2348062
GSM: 00971506503087
http://www.brisk.biz/page.php?page=2800
قديم 24-10-2011, 04:33 PM
الصورة الرمزية elmanahry
الفاضل شكرا جزيلا لان هذا موضوع الساعة بالنسبة لى ولان معظم الناس لاتعرف هذا الصنف اشتريت منذ فترة بوجيهات NGK IRIDIUM والمفروض تعمل 60 الف كيلو ثمنهم 250 جنيها وبعد 16 الف ابتدات السيارة فى استهلاك عالى للبنزين واتصلت بالاستاذ عماد حبيب الذى قال لى على اجراءات سوف تتم فى الصيانة منها تغيير البوجيهات وطبعا لا اريد ان يفرض على التوكيل نوع من البوجيهات نحاس او لا اعرف مصنوعة باى تكنولوجيا واذا كنت فتحت انا عن موضوع عن الزيوت ارجو ان يستمر موضوعك على البوجيهات والانواع التى لم نسمع عنها وسوف اترك لسيادتك اختيار البوجيهات لسيارتى بحيث تكون اعلى اداء وارخص سعر وانا اعلم انه لوغاريتم خصوصا انا لم ادرس واعتقد ان هذا النوع امريكى وانا لست على استعداد لدفع 250 جنيها مرة اخرى فى بوجيهات ماتكملش 16 الف
God grant me the serenity
DR Elmanahry
carsadmire
الساعة الآن 05:59 AM.
