قديم 22-11-2010, 03:18 PM
m__hassan m__hassan غير متواجد حالياً
التخصص العملى: مهندس معماري
الموقع: اسيوط
m__hassan is on a distinguished road
افتراضي يا خبراء المنتدى ومؤسسيه ارجوكم افيدوني محتار بين الاكسنت 2011والصني 2011
<HR style="COLOR: #7ccefd; BACKGROUND-COLOR: #7ccefd" SIZE=1>
روابط اعلانية <SCRIPT type=text/javascript><!--google_ad_client = "pub-7587135972382304";/* 300x250, created 9/15/09_sqr_img */google_ad_slot = "0741766085";google_ad_wi dth = 300;google_ad_height = 250;//--></SCRIPT><SCRIPT style="DISPLAY: none" type=text/javascript>(function(){va r g=true,h=null,i=false,j=( new Date).getTime();var k=this,aa=function(a,b,c) {a=a.split(".");c=c||k;!( a[0]in c)&&c.execScript&&c.execS cript("var "+a[0]);for(var d;a.length&&(d=a.shift()) if(!a.length&&b!==undef ined)c[d]=b;else c=c[d]?c[d]:c[d]={}},ba=function(){return Function.prototype.call.a pply(Function.prototype.b ind,arguments)},ca=functi on(a,b){var c=b||k;if(arguments.lengt h>2){var d=Array.prototype.slice.c all(arguments,2);return function(){var f=Array.prototype.slice.c all(arguments);Array.prot otype.unshift.apply(f,d); return a.apply(c,f)}}else return function(){return a.apply(c,arguments)}},l= function(){l=Function.pro totype.bind&&Function.pro totype.bind.toString().in dexOf("native code")!=-1?ba:ca;return l.apply(h,arguments)};var ea=function(a,b){var c=parseFloat(a);return isNaN(c)||c>1||c<0?b:c},n =function(a,b){if(a=="tru e")return g;if(a=="false")return i;return b},fa=/^([\w-]+\.)*([\w-]{2,})(\:[0-9]+)?$/,ga=function(a,b){if(!a)r eturn b;var c=a.match(fa);return c?c[0]:b};var ha=function(){return ga("","pagead2.googlesynd ication.com")},ia=functio n(){return ga("","pagead2.googlesynd ication.com")};var ja=/&/g,ka=/</g,la=/>/g,ma=/\"/g,p={"\u0000":"\\0","\u00 08":"\\b","\u000c":"\\f", "\n":"\\n","\r":"\\r","\t ":"\\t","\u000b":"\\x0B", '"':'\\"',"\\":"\\\\"},t= {"'":"\\'"},u=function(a, b){if(a<b)return-1;else if(a>b)return 1;return 0};var v,y,A,B,C=function(){retu rn k.navigator?k.navigator.u serAgent:h};B=A=y=v=i;var D;if(D=C()){var na=k.navigator;v=D.indexO f("Opera")==0;y=!v&&D.ind exOf("MSIE")!=-1;A=!v&&D.indexOf("WebKit ")!=-1;B=!v&&!A&&na.product==" Gecko"}var F=y,oa=B,pa=A,G;a:{var H="",I;if(v&&k.opera){v ar J=k.opera.version;H=typeo f J=="function"?J():J}else{ if(oa)I=/rv\[^\);]+)(\)|/;else if(F)I=/MSIE\s+([^\);]+)(\)|/;else if(pa)I=/WebKit\/(\S+)/;if(I){var qa=I.exec(C());H=qa?qa[1]:""}}if(F){var K,ra=k.document;K=ra?ra.d ocumentMode:undefined;if( K>parseFloat(H)){G=String (K);break a}}G=H}var sa=G,ua={},L=function(a){ var b;if(!(b=ua[a])){b=0;for(var c=String(sa).replace(/^[\s\xa0]+|[\s\xa0]+$/g,"").split("."),d=String (a).replace(/^[\s\xa0]+|[\s\xa0]+$/g,"").split("."),f=Math.m ax(c.length,d.length),e=0 ;b==0&&e<f;e++){var ta=c[e]||"",s=d[e]||"",m=RegExp("(\\d*)(\\D *)","g"),z=RegExp("(\\d*) (\\D*)","g");do{var q=m.exec(ta)||["","",""],o=z.exec(s)||["","",""];if(q[0].length==0&&o[0].length==0)break;b=u(q[1].length==0?0:parseInt(q[1],10),o[1].length==0?0:parseInt(o[1],10))||u(q[2].length==0,o[2].length==0)||u(q[2],o[2])}while(b==0)}b=ua[a]=b>=0}return b};!F||L("9");F&&L("9");v ar va=document,M=window;ia() ;var N=function(a){return!!a&& typeof a=="function"&&!!a.call}, wa=function(a){if(argumen ts.length<2)return a.length;for(var b=1,c=arguments.length;b< c;++b)a.push(arguments[b]);return a.length};function O(a){return typeof encodeURIComponent=="func tion"?encodeURIComponent( a):escape(a)}function xa(a,b){if(a.attachEvent) {a.attachEvent("onload",b );return g}if(a.addEventListener){ a.addEventListener("load" ,b,i);return g}return i}var ya=function(a){if(!("goog le_onload_fired"in a)){a.google_onload_fired =i;xa(a,function(){a.goog le_onload_fired=g})}};var za=ea("0",0),Aa=ea("0",0) ;var Ba=n("false",i),Ca=n("fal se",i),Da=n("false",i);aa ("google_protectAndRun",f unction(a,b,c){a=l(b,k,a) ;b=window.onerror;window. onerror=a;try{c()}catch(d ){c=d.toString();var f="";if(d.fileName)f=d.fi leName;var e=-1;if(d.lineNumber)e=d.lin eNumber;if(!a(c,f,e))thro w d;}window.onerror=b},void 0);aa("google_handleError ",function(a,b,c,d){if(Ma th.random()<0.01){a=["http://",ha(),"/pagead/gen_204","?id=jserror","& jscb=",Ba?1:0,"&jscd=",Ca ?1:0,"&context=",O(a),"&m sg=",O(b),"&file=",O(c)," &line=",O(d.toString())," &url=",O(va.URL.substring (0,512)),"&ref=",O(va.ref errer.substring(0,512))];a.push(["&client=",O(M.google_ad_ client),"&format=",O(M.go ogle_ad_format),"&slotnam e=",O(M.google_ad_slot)," &output=",O(M.google_ad_o utput),"&ad_type=",O(M.go ogle_ad_type)].join(""));a=a.join("");M .google_image_requests||( M.google_image_requests=[]);b=new Image;b.src=a;M.google_im age_requests.push(b)}retu rn!Da},void 0);var Ea=function(a){try{var b=a.google_test;a.google_ test=!b;if(a.google_test= ==!b){a.google_test=b;ret urn g}}catch(c){}return i},P=h,Ga=function(){if(! P){for(var a=window;a!=a.parent&&Ea( a.parent)a=a.parent;P=a }return P};var Q,R=function(a){this.e=[];this.b=a||window;this.a= 0;this.c=h},Ha=function(a ,b){this.h=a;this.n=b};R. prototype.g=function(a,b) {this.e.push(new Ha(a,b||this.b));S(this)} ;R.prototype.i=function(a ){this.a=1;if(a)this.c=th is.b.setTimeout(l(this.f, this),a)};R.prototype.f=f unction(){if(this.a==1){i f(this.c!=h){this.b.clear Timeout(this.c);this.c=h} this.a=0}S(this)};R.proto type.l=function(){return g};R.prototype.nq=R.proto type.g;R.prototype.al=R.p rototype.i;R.prototype.rl =R.prototype.f;R.prototyp e.sz=R.prototype.l;var S=function(a){a.b.setTime out(l(a.m,a),0)};R.protot ype.m=function(){if(this. a==0&&this.e.length){var a=this.e.shift();this.a=2 ;a.n.setTimeout(l(this.j, this,a),0);S(this)}};R.pr ototype.j=function(a){thi s.a=0;a.h()};var Ia=function(a){try{return a.sz()}catch(b){return i}},Ja=function(a){return !!a&&(typeof a=="object"||typeof a=="function")&&Ia(a)&&N( a.nq)&&N(a.al)&&N(a.rl)}, Ka=function(){if(Q&&Ia(Q) )return Q;var a=Ga(),b=a.google_jobrunn er;if(Ja(b))return Q=b;return a.google_jobrunner=Q=new R(a)};var T,U;U=T=i;var V=C();if(V)if(V.indexOf(" Firefox")!=-1)T=g;else if(V.indexOf("Camino")==-1)if(!(V.indexOf("iPhone" )!=-1||V.indexOf("iPod")!=-1))if(V.indexOf("iPad")==-1)if(V.indexOf("Android") ==-1)if(V.indexOf("Chrome")! =-1)U=g;var La=T,Ma=U;var Na=function(a,b,c){var d=["<iframe"],f;for(f in a)wa(d,f+"="+a[f]);d.push('style="left:0;p osition:absolute;top:0;"' );d.push("></iframe>");b="border:none; height:"+c+"px;margin:0;p adding:0;position:relativ e;visibility:visible;widt h:"+b+"px";return['<ins style="display:inline-table;',b,'"><ins id="',a.id+"_anchor",'" style="display:block;',b, '">',d.join(" "),"</ins></ins>"].join("")};var Oa=function(){},Qa=functi on(a,b,c){switch(typeof b){case "string":Pa(a,b,c);break; case "number":c.push(isFinite( b)&&!isNaN(b)?b:"null");b reak;case "boolean":c.push(b);break ;case "undefined":c.push("null" );break;case "object":if(b==h){c.push( "null");break}if(b instanceof Array){var d=b.length;c.push("[");for(var f="",e=0;e<d;e++){c.push( f);Qa(a,b[e],c);f=","}c.push("]");break}c.push("{");d="" ;for(f in b)if(b.hasOwnProperty(f)) {e=b[f];if(typeof e!="function"){c.push(d); Pa(a,f,c);c.push(":");Qa( a,e,c);d=","}}c.push("}") ;break;case "function":break;default: throw Error("Unknown type: "+typeof b);}},Ra={'"':'\\"',"\\": "\\\\","/":"\\/","\u0008":"\\b","\u000c" :"\\f","\n":"\\n","\r":"\ \r","\t":"\\t","\u000b":" \\u000b"},Sa=/\uffff/.test("\uffff")?/[\\\"\x00-\x1f\x7f-\uffff]/g:/[\\\"\x00-\x1f\x7f-\xff]/g,Pa=function(a,b,c){c.pu sh('"');c.push(b.replace( Sa,function(d){if(d in Ra)return Ra[d];var f=d.charCodeAt(0),e="\\u" ;if(f<16)e+="000";else if(f<256)e+="00";else if(f<4096)e+="0";return Ra[d]=e+f.toString(16)}));c.pu sh('"')};var W=["google_ad_block","google _ad_channel","google_ad_c lient","google_ad_format" ,"google_ad_height","goog le_ad_host","google_ad_ho st_channel","google_ad_ho st_tier_id","google_ad_ou tput","google_ad_override ","google_ad_region","goo gle_ad_section","google_a d_slot","google_ad_type", "google_ad_width","google _adtest","google_allow_ex pandable_ads","google_alt ernate_ad_url","google_al ternate_color","google_an alytics_domain_name","goo gle_analytics_uacct","goo gle_bid","google_city","g oogle_color_bg","google_c olor_border","google_colo r_line","google_color_lin k","google_color_text","g oogle_color_url","google_ container_id","google_con tents","google_country"," google_cpm","google_ctr_t hreshold","google_cust_ag e","google_cust_ch","goog le_cust_gender","google_c ust_id","google_cust_inte rests","google_cust_job", "google_cust_l","google_c ust_lh","google_cust_u_ur l","google_disable_video_ autoplay","google_ed","go ogle_eids","google_enable _osd","google_encoding"," google_font_face","google _font_size","google_frame _id","google_gl","google_ hints","google_image_size ","google_kw","google_kw_ type","google_language"," google_max_num_ads","goog le_max_radlink_len","goog le_num_radlinks","google_ num_radlinks_per_unit","g oogle_num_slots_to_rotate ","google_only_ads_with_v ideo","google_only_pyv_ad s","google_only_userchoic e_ads","google_override_f ormat","google_page_url", "google_referrer_url","go ogle_region","google_reus e_colors","google_rl_dest _url","google_rl_filterin g","google_rl_mode","goog le_rt","google_safe","goo gle_skip","google_tag_inf o","google_targeting","go ogle_ui_features","google _ui_version","google_vide o_doc_id","google_video_p roduct_type","google_with _pyv_ads"];var Ta=function(a){this.b=a;a .google_iframe_oncopy||(a .google_iframe_oncopy={ha ndlers:{},log:[],img:Math.random()<0.1?[]:h});this.d=a.google_ifra me_oncopy;a.setTimeout(l( this.k,this),3E4)},Ua;var X="var i=this.id,s=window.google _iframe_oncopy,H=s&&s.han dlers,h=H&&H[i],w=this.contentWindow,d;t ry{d=w.document}catch(e){ }if(h&&d&&(!d.body||!d.bo dy.firstChild)){if(h.call ){i+='.call';setTimeout(h ,0)}else if(h.match){i+='.nav';w.l ocation.replace(h)}s.log& &s.log.push(i)}";if(/[&<>\"]/.test(X)){if(X.indexOf("& ")!=-1)X=X.replace(ja,"&");if( X.indexOf("<")!=-1)X=X.replace(ka,"<");if( X.indexOf(">")!=-1)X=X.replace(la,">");if( X.indexOf('"')!=-1)X=X.replace(ma,"&quot;" )}Ua=X;Ta.prototype.set=f unction(a,b){this.d.handl ers[a]=b};Ta.prototype.k=functi on(){if(this.d.img){var a=this.d.log,b=this.b.doc ument;if(a.length){b=["http://",ha(),"/pagead/gen_204?id=iframecopy&log =",O(a.join("-")),"&url=",O(b.URL.subst ring(0,512)),"&ref=",O(b. referrer.substring(0,512) )].join("");a.length=0;a=ne w Image;this.d.img.push(a); a.src=b}}};var Va=function(){var a="script";return["<",a,' src="http://',ia(),"/pagead/js/r20101110/r20101117/show_ads_impl.js",'"></',a,">"].join("")},Wa=function(a, b,c,d){return function(){var f=i;d&&Ka().al(3E4);try{v ar e;try{e=!!a.document.getE lementById(b).contentWind ow.document}catch(ta){e=i }if(e){var s=a.document.getElementBy Id(b).contentWindow,m=s.d ocument;if(!(m.body&&m.bo dy.firstChild)){m.open(); s.google_async_iframe_clo se=g;m.write(c)}}else{var z=a.document.getElementBy Id(b).contentWindow,q;e=c ;e=String(e);if(e.quote)q =e.quote();else{s=['"'];for(m=0;m<e.length;m++){ var o=e.charAt(m),Fa=o.charCo deAt(0),jb=s,kb=m+1,da;if (!(da=p[o])){var E;if(Fa>31&&Fa<127)E=o;el se{var r=o;if(r in t)E=t[r];else if(r in p)E=t[r]=p[r];else{var w=r,x=r.charCodeAt(0);if( x>31&&x<127)w=r;else{if(x <256){w="\\x";if(x<16||x> 256)w+="0"}else{w="\\u";i f(x<4096)w+="0"}w+=x.toSt ring(16).toUpperCase()}E= t[r]=w}}da=E}jb[kb]=da}s.push('"');q=s.join( "")}z.location.replace("j avascript:"+q)}f=g}catch( rb){z=Ga().google_jobrunn er;Ja(z)&&z.rl()}f&&(new Ta(a)).set(b,Wa(a,b,c,i)) }},Xa=function(){return za&&Aa/za||typeof window.google_hash_ratio= ="number"&&window.google_ hash_ratio||h};window.goo gle_loader_used=g;var Ya;if(Ya=window.google_en able_async===g||Da&&g)Ya= window.google_enable_asyn c===i?iF&&L(7)||Ma||La& &!!window.document.body)& &!window.google_container _id&&(!window.google_ad_o utput||window.google_ad_o utput=="html");if(Ya){var Za=window;if(Za.google_un ique_id)++Za.google_uniqu e_id;else Za.google_unique_id=1;ya( window);for(var Y=window,_script$$inline_ 200="script",$a,Z={allowt ransparency:'"true"',fram eborder:'"0"',height:'"'+ Y.google_ad_height+'"',hs pace:'"0"',marginwidth:'" 0"',marginheight:'"0"',on load:'"'+Ua+'"',scrolling :'"no"',vspace:'"0"',widt h:'"'+Y.google_ad_width+' "'},ab=Y.document,$=Z.id, bb=0;!$||Y.document.getEl ementById($)$="aswift_" +bb++;Z.id=$;Z.name=$;ab. write(Na(Z,Y.google_ad_wi dth,Y.google_ad_height)); $a=$;for(var cb,db=[],eb=0,fb=W.length;eb<fb;e b++){var gb=W[eb];if(Y[gb]!=h){var hb;try{var ib=[];Qa(new Oa,Y[gb],ib);hb=ib.join("")}catch (lb){}hb&&wa(db,gb,"=",hb ,";")}}cb=db.join("");for (var mb=0,nb=W.length;mb<nb;mb ++)Y[W[mb]]=h;var ob=(new Date).getTime(),pb=Xa(),q b=["<!doctype html><html><body><",_scri pt$$inline_200,">",cb,"go ogle_show_ads_impl=true;g oogle_unique_id=",Y.googl e_unique_id,';google_asyn c_iframe_id="',$a,'";goog le_start_time=',j,";",pb? "google_hash_ratio="+pb+" ;":"","google_bpp=",ob>j? ob-j:1,";</",_script$$inline_200,">" ,Va(),"</body></html>"].join(""),sb=Wa(Y,$a,qb,g );Ka().nq(sb,void 0)}else{window.google_sta rt_time=j;window.google_h ash_ratio=Xa();document.w rite(Va())};})();</SCRIPT><SCRIPT src="http://pagead2.googlesyndication .com/pagead/js/r20101110/r20101117/show_ads_impl.js"></SCRIPT><SCRIPT>google_pro tectAndRun("ads_core.goog le_render_ad", google_handleError, google_render_ad);</SCRIPT>
يا جماعة الخير وخبراء وعباقرة المنتدى ارجوكم انصحوني ، محتار اشتري بين هيونداي اكسنت 2011 مانيوال فول ابشن ونسيان صني 2011 مانيوال فول اوبشن بنفس السعر تقريبا وارجو افادتي من الافضل من حيث :-
** من ترضي اغلب الاذواق ( شباب - عائلي - كبار في السن)
** من التوكيل كويس الافضل - خدمه صيانه كويسه
واحتفاظ العربية بقوتها و تماسكها مع الوقت أو العمر الافتراضي
** تكون استثمار جيد .... يعني لو جيت تبيعها في اي وقت تلاقي سعر كويس ......
**** و طبعا استهلاك البنزين و العفشه و و توافر قطع الغيار بسعر مناسب
قديم 23-11-2010, 12:09 PM
الصورة الرمزية atef_5005
atef_5005 atef_5005 غير متواجد حالياً
atef_5005 has a spectacular aura aboutatef_5005 has a spectacular aura about
افتراضي رد: يا خبراء المنتدى ومؤسسيه ارجوكم افيدوني محتار بين الاكسنت 2011والصني 2011
النيسان افضل
قديم 23-11-2010, 12:21 PM
corsair
طبعا النيسان هيه شكلها مش حلو اوي بس ادائها برقبة النيو اكسينت عربية حمارة شغل
خليك في النيسان بجد عربية ملهاش حل واقوي ماتور في فئة ال 1600 سي سي
قديم 23-11-2010, 12:24 PM
الصورة الرمزية harpoonattack
harpoonattack harpoonattack غير متواجد حالياً
من انا؟: !!!!!
هواياتي: الصيد والقراءه والسفر والقياده طبعا
الموقع: القاهره
harpoonattack has a spectacular aura aboutharpoonattack has a spectacular aura about
انا الحقيقه ما ركبتش الاتنين بس اعتقد الاكسنت افضل وتنجح فى المقارنه وخصوصا انى سمعت من واحد صاحبى ان النيسان مش أد كده عشان التقفيل وكلام من ده ... والله اعلم
خالص تحياتى واحترامى للجميع
حازم عبد السلام
الهيئة العامة للرقابة المالية
لا تأسفن على غدر الزمان لطالما
رقصت على جثث الاسود كلابا
لا تحسبن برقصها تعلو على اسيادها
تبقى الاسود اسودا والكلاب كلابا
قديم 23-11-2010, 05:42 PM
الصورة الرمزية phantiza
شوف انا كنت في نفس الحيرة بتاعتك ووفي الاخر حاجز نيسان مانيوال فول اوبش عشان
1 الامان اعلي من الاكسنت فيها ايرباج وفرامل absوصاج قوي
2 شكل نيسان اظرف من الاكسنت
3 توكيل نيسان فوق المحترم بشهادة الجميع بعكس غبور الي محدش قال كلمة حلوة ابدا في حقة
4 عربية 118 حصان يعني اداء قوي وتسارع ممتاز الاكسنت 112 حصان
العيوب
1 قطع غيار غالية بمقارنة بالاكسنت بس طبعا بعد 5 سنين لما تفكر في قطع الغيار
2 اعادة بيع للكسنت افضل طبعا الي بيشتري زيرو صعب انة يغير الا بعد فترة كبيرة تكون اخدت خير العربية
يعني مفيش عيوب جوهرية للصني
ولك حرية الاختيار وربنا يوفقك
الساعة الآن 06:00 PM.
