قديم 12-11-2010, 10:40 PM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Nissan recalling 605,000 Frontier, Xterra and Sentra models over two issues
Filed under: , , , , ,
2002 Nissan Frontier
Nissan XterraNissan has issued a voluntary recall on select Frontier and Xterra models due to problems with the lower steering column joint and shaft, as well as the Sentra sedan for problems with the positive battery cable terminal. Just under 605,000 vehicles are affected by this recall, which is set to ramp up in early December.
Approximately 303,000 Frontiers and 283,000 Xterras in the United States, Canada and a number of Latin American countries can develop corrosion that limits the movement of the lower steering column joint. If this issue is overlooked, it can lead to the steering shaft cracking.
Sentras, on the other hand, have developed a problem with the connector on the positive battery cable terminal, which can cause the car to have issues starting, or can possibly result in stalling at low speeds. Approximately 18,500 Sentras manufactured between May 15, 2010 and July 8, 2010 are being recalled for this reason.
Affected model years depend on where the vehicle was manufactured, and you can see the full details in Nissan's press release, after the jump. Thanks to all for the tips!
[Sources: Nissan, CNN Money]
Continue reading Nissan recalling 605,000 Frontier, Xterra and Sentra models over two issues
Nissan recalling 605,000 Frontier, Xterra and Sentra models over two issues originally appeared on Autoblog on Fri, 12 Nov 2010 14:32:00 EST. Please see our terms for use of feeds.
Read | Permalink | Email this | Comments
أكثر...
الساعة الآن 09:31 AM.
