العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > ستروين Citroën > Citroen News Archive
Citroen News Archive ارشيف اخبارى نقلاً عن المواقع العالمية
قديم 02-07-2010, 11:30 PM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Citro?«n DS3 R3 ready for customer combat
Filed under: Motorsports, Performance, Hatchback, Citro?«n
Citroën DS3 R3 - Click above for high-res image gallery
Citroën has just introduced a new customer rally car for the FIA's Group R3T class based on the DS3. The DS3 R3 will be available as either a turn-key racer or a do-it-yourself kit. Either way, power comes from a 210-horsepower high-pressure turbocharged 1.6-liter inline-four driving through the six-speed semi-automatic sequential gearbox. Shifts are handled via carbon fiber paddles mounted on the back of the steering wheel.
The suspension has been developed to make it easily adaptable to different racing surfaces ranging from gravel to tarmac. Tubular wishbones are attached to a revised front subframe while the rear hubs are removable to allow for independent toe and camber adjustments. The bodyshell comes with a multi-point steel roll-cage already welded in, but buyers will have to supply seats, harnesses and fire suppression equipment. Citroën says it has accumulated over 6,000 miles of testing since last August.
The DS3 R3 will at the end of this year, but if you can't swing one for your weekend racing sessions, you can at least check out the press release after the jump and the high-res images below.
Gallery: Citroen DS3 R3
[Source: Citroën]Continue reading Citro?«n DS3 R3 ready for customer combat
Citro?«n DS3 R3 ready for customer combat originally appeared on Autoblog on Fri, 02 Jul 2010 15:57:00 EST. Please see our terms for use of feeds.
Permalink | Email this | Comments
أكثر...
الساعة الآن 03:30 AM.
