قديم 07-06-2010, 04:30 PM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Jeep recalling nearly 300k 2006-2010 Wrangler models over possible brake fluid leak
Filed under: , , , ,
2010 Jeep Wrangler - Click above for high-res image gallery
Chrysler is quietly racking up quite a few recalls so far in 2010, with a pair of 300,000 unit minivan recalls, a Dodge Caliber sticking gas pedal concern and now a brake issue with the Jeep Wrangler. The Pentastar is calling home 288,968 2006-2010 Jeep Wrangler models due to front fender liners that could make contact with the right front and left rear brake tubes. The National Highway Traffic Safety Administration says the friction caused by the fender liners could "cause wear of the tubes causing a brake fluid leak." That leaking fluid could cause partial loss of service brakes at the affected wheel, increasing the risk of a crash.
The NHTSA website states that Jeep Wranglers build between May 15, 2006 and August 9, 2010 are affected by the recall. August 9, 2010 is still two months away, so we're thinking NHTSA made a mistake since Chrysler will begin repairing vehicles beginning in June. If your Wrangler is covered by the recall, you can take your Go Anywhere off-roader to the local Jeep dealer for a free fix. Hit the jump to read over official NHTSA press release.
[Source: National Highway Traffic Safety Administration]
Continue reading Jeep recalling nearly 300k 2006-2010 Wrangler models over possible brake fluid leak
Jeep recalling nearly 300k 2006-2010 Wrangler models over possible brake fluid leak originally appeared on Autoblog on Mon, 07 Jun 2010 09:01:00 EST. Please see our terms for use of feeds.
أكثر...
الساعة الآن 09:19 AM.
