العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > فولكس > VW News Archive
VW News Archive ارشيف الاخبار نقلاً عن المواقع العالمية
قديم 12-05-2010, 10:10 PM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Spy Shots: Next Volkswagen Passat caught towing
Filed under: Spy Photos, Sedan, Volkswagen
2012 Volkswagen Passat - Click above for high-res image gallery
A fresh batch of photos has turned up in our inbox of the next generation Volkswagen Passat, which will be debuting next year. The only problem is that we are not certain if this is the larger North American specification Passat that will be built in Chattanooga Tennessee or the slightly smaller European model.
The new sedan does feature many of the same styling elements that we've seen on the sketches that Volkswagen has released of the new mid-size (NMS) sedan, as well as other recently introduced models like the Golf, Polo and Touareg. The new horizontal bar grille is visible through the front camouflage along with the rising rocker panel crease that flows into the rear wheel arch.
When the U.S. Passat arrives, it will be offered with a choice of the 2.0-liter TDI diesel found in the Jetta, a hybrid and probably at least two gas engines. Check out our gallery of high-res spy shots below.
Gallery: Spy shots: 2012 Volkswagen Passat sedan
[Source: Carpix]Spy Shots: Next Volkswagen Passat caught towing originally appeared on Autoblog on Wed, 12 May 2010 14:57:00 EST. Please see our terms for use of feeds.
Permalink | Email this | Comments
أكثر...
الساعة الآن 12:16 AM.
