قديم 18-04-2010, 02:30 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon
Filed under: , , , ,
Toyota engineers in Japan have apparently replicated the lift-throttle oversteer problem recently found by Consumer Reports on the new 2010 Lexus GX460 and are working on a fix. Toyota spokesman Bill Kwong has confirmed the existence of the handling problem to The New York Times.
According to the NYT, as soon as CR discovered the problem, they contacted Toyota and worked with the automaker to make sure it understood the organization's test conditions. The engineers in Japan are currently trying to understand the root cause and come up with a robust solution.
For now, Toyota has stopped selling the GX globally until a corrective action is identified, and owners in the field can get loaner vehicles from their dealers until their SUVs are repaired. The solution could end up being either hardware changes or software updates to the stability control, or a combination thereof. For more on the testing and what might be causing the oversteer problem, check out our in-depth analysis.
[Source: The New York Times]
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon originally appeared on Autoblog on Sat, 17 Apr 2010 19:03:00 EST. Please see our terms for use of feeds.
أكثر...
الساعة الآن 01:24 PM.
