قديم 16-02-2010, 12:55 AM
الصورة الرمزية lancer.style
lancer.style lancer.style غير متواجد حالياً
من انا؟: Mohamed Osama
التخصص العملى: Futuer Academy
هواياتي: CaR RiDe
الموقع: مــ عين ـصـ شمس ـــــر
lancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond reputelancer.style has a reputation beyond repute
عــائـلـة ميتسوبيشى لــــــ2010ــــعام
انها العائلة الخاصة بشركة ميتسوبيشى
و تقرير عن بعض السيارت التى تقدمها هذة الشركة
و شرح مبسط لكل موديل
و اترككم الان مع التقرير
2010 MITSUBISHI LANCER
4 Models
DE ES GTS RALLIART
DE & ES
2000CC
4 Cylinder
DOHC
16 Valve
Mitsubishi Innovative Valve-timing Electronic Control system (MIVEC)
152 hp @ 6000 RPM
146 lb-ft @ 4250 RPM
5-speed manual or Continuously Variable (CVT)
ABS
Fuel Tank 15.6 (gal.)
16-inch steel with full covers DE
16-inch alloy ES
GTS
2000CC
4 Cylinder
DOHC
16 Valve
168 hp @ 6000 RPM
167 lb-ft @ 4100 RPM
5-speed manual or
Continuously Variable (CVT) with paddle shifters
ABS
18-inch alloy
RALLIART
2000 CC
4 Cylinder
turbocharged and intercooled
DOHC
16 Valve
237 @ 6000 RPM
253 lb-ft @ 2500-4750 rpm
6-speed Twin-Clutch Sportronic® Shift Transmission (TC-SST)
ABS
18-inch alloy
2010 MITSUBISHI LANCER EVOLUTION
2000 CC
turbocharged inline-4, aluminum block and head
DOHC 16-valve
Mitsubishi Innovative Valve-timing Electronic Control (MIVEC)
291 hp @ 6,500 RPM
300 lb-ft @ 4,000 RPM
5-speed manual transmission
6-speed Twin Clutch Sportronic Shift Transmission (TC-SST)
Standard 4-channel sports ABS with EBD
Fuel Tank 14.5 (gal.)
18 x 8.5 in Enkei cast aluminum alloy (GSR Model)
18 x 8.5 in BBS® forged aluminum alloy (MR - MR-Touring Models)
P245/40R18 93Y Yokohama ADVAN asymmetrical performance tread
Dimensions
Wheelbase 104.3 (in.)
Length 177.0 (in.)
Width 71.3 (in.)
Height 58.3 (in.)
2010 MITSUBISHI LANCER SPORTBACK
2 Model
GTS & RALLLIART
GTS
2000CC
4 Cylinder
168 hp @ 6000 RPM
161 lb-ft @ 4100 RPM
ABS
18-inch alloy
RALLIART
2000CC
DOHC
16 valve
4 cylinder
237 @ 6000 RPM
ABS18-inch alloy
Exterior
Wheelbase 103.7 (in.)
Length 180.4 (in.)
Width 69.4 (in.)
Height 59.7 (in.)
2010 MITSUBISHI GALANT
2400 CC
4 Cylinder
SOHC 16-Valve
160 hp @ 5,500 RPM
157 lb-ft @ 4,000 RPM
Fuel Tank 17.7 gal
Type 4-speed Sportronic® with INVECS-II adaptive shift control system
(ABS and EBD)
16-inch steel wheels with full wheel covers ( ES Model )
18-inch alloy wheels ( SE Model )
Dimensions
Wheelbase 108.3 (in.)
Length 191.1 (in.)
Width 72.4 (in.)
Height 57.9 (in.)
2010 MITSUBISHI ECLIPSE
3 Model
GS - GS Sport - GT
GS & GS Sport MODEL
2400 CC
SOHC 16 Valve
162 hp @ 6,000 RPM
162 lb-ft @ 4,000 RPM
5-speed manual
4-speed Sportronic® automatic
ABS & EBD
Fuel Tank 17.7 gal
17-inch alloy wheels - GS
18-inch alloy wheels - GS Sport
GT MODEL
3800CC
V6
SOHC 24 Valve
MIVEC
265 hp @ 5,750 RPM
262 lb-ft @ 4,500 RPM
6-speed manual
5-speed Sportronic® automatic
ABS & EBD
Fuel Tank 17.7 gal
2010 MITSUBISHI OUTLANDER
4 Models
ES SE XLS GT
ES & SE
2400 CC
4 Cylinder
DOHC 16-valve
168 hp @ 6000 RPM
Continuously Variable (CVT) ES
Continuously Variable (CVT) with paddle shifters SE
Fuel Tank
2WD - 16.6 (gal.)
AWC - 15.8 (gal.)
ABS
16-inch steel with full covers (optional alloy) ES
18-inch alloy SE
XLS & GT
3000 CC
V6
SOHC 24-valve
230 hp @ 6250 RPM
215 lb-ft @ 3750 RPM
6-speed Sportronic® automatic with paddle shifters and Idle Neutral Logic
Fuel Tank
2WD - 16.6 (gal.)
AWC - 15.8 (gal.)
ABS
18-inch alloy
Exterior
Wheelbase 105.1 (in.)
Length 183.7 (in.)
Width 70.9 (in.)
Height 66.1 (in.)
الموضوع حصرى و خاص بمصر موتورز فقط
قديم 16-02-2010, 01:21 AM
MO MO غير متواجد حالياً
من انا؟: Mo
الموقع: Cairo
MO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond reputeMO has a reputation beyond repute
افتراضي رد: عــائـلـة ميتسوبيشى لــــــ2010ــــعام
عااااااش يا فنان
تصميم ولا احلي
و موضوع ارووع
هي الباجيرو هي الاوت لاند
قديم 16-02-2010, 01:52 AM
الصورة الرمزية horas3000
من انا؟: شريف بيومي منسي
الموقع: Kuwait, Naser Ciry
تسلم ايدك علي التقرير يا زعيم
بس فين الباجيرو و الباجيرو سبورت و البومة
Mo
الباجيرو غير الاوتدلاندر
الباجيرو اكبر و اقوي و Off Roader اكتر من الاوتدلاندر
الاوتلاندر في حجم ال X3 تقريبا
دي صورة الباجيرو
و في برضة حاليا الباجيرو سبورت و دي بين الاتنين
و دي صورتها
Sharief Mansy
التعديل الأخير تم بواسطة horas3000 ; 16-02-2010 الساعة 01:59 AM
قديم 16-02-2010, 02:07 AM
كيكووو كيكووو غير متواجد حالياً
كيكووو is a jewel in the roughكيكووو is a jewel in the roughكيكووو is a jewel in the roughكيكووو is a jewel in the rough
بجد بجد اساذذذذذذذذذذذذذذذذذذذذذذ ذذذذ يا ودييييييييييييييععععععععع عع
ملك الملوك اذا وهب لا تسأل عن السبب وارفع رأسك الى السماء وقف عند حد ألادب
قديم 16-02-2010, 12:45 PM
هواياتي: CaR RiDe
بس الموضوع دة عن عائلة 2010 بس
الساعة الآن 08:27 AM.
