قديم 12-08-2008, 07:48 AM
الصورة الرمزية AbOnOrA
Aِِbo(Nora&Islam&Judy)
Wael Magdy Salah
من انا؟: ابو نورا واسلام
التخصص العملى: IT Consultant
الموقع: ام الدنيا مصر
صنعت للامريكان Hyundai Veracruz
Engine All Models
3.8L (3778cc) Lambda DOHC 24-valve V6, and CVVT s
Displacement (liters) 3.8L
Horsepower @ rpm 260 @ 6,000 RPM
Torque @ rpm 257 lb.-ft @ 4,500 RPM
Compression ratio 10.4:1
Recommended Fuel Unleaded
Exhaust Outlets Dual
Drivetrain/transmission All Models
Drive configuration: FWD s
Drive configuration: AWD o
6-speed electronic automatic s
OD lock-up torque converter s
SHIFTRONIC™ manual shift mode s
Final Drive Axle Ratio 3.20:1
Body/Suspension/Chassis GLS SE Limited
Unibody body type s
Front suspension type: Independent McPherson Strut s
Front suspension stabilizer bar: 27 mm s
Front suspension twin-tube gas filled damper s
Rear suspension type: Independent Multi-link s
Rear suspension stabilizer bar: 17 mm s
Rear suspension gas shock absorber s
Rack and pinion type steering gear s
Power Assisted (Engine-RPM-Sensing) steering s
Turns (lock to lock) 3.5
Turning Diameter (curb to curb, in feet) 36.7
ABS with Electronic Brake-force Distribution (EBD) and Brake Assist s
17 x 7 Aluminum Alloy, with P245/65R-17 Tires s - -
18 x 7 Aluminum Alloy, with P245/60R-18 Tires - s s
All Models
Wheelbase (in.) 110.4
Overall Length 190.6
Overall Width 76.6
Overall Height with / without Roof Rack 71.1 / 68.9
Track (front / rear) 65.7 / 65.7
Minimum Ground Clearance 8.1
Curb Weight (lbs., FWD/AWD) 4266/4431
Towing Capacity (lbs) 3,500
All Models
Head Room (front/2nd/3rd row) 40.3 / 39.9 / 36.1
Leg Room (front/2nd/3rd row) 42.6 / 38.4 / 31.5
Shoulder Room (front/2nd/3rd row) 60.6 / 60.2 / 56.1
Hip Room (front/2nd/3rd row) 57.5 / 57.4 / 45.6
Cargo volume behind front seats (cu. ft.) 86.8
Cargo volume behind 2nd row (3rd row folded down) (cu. ft.) 40.0
Cargo volume behind 3rd row seats (cu. ft.) 6.5
Total interior volume (cu. ft.) 150.6
All Models
FWD w/ Automatic Transmission (City/Highway) 16 / 23
AWD w/ Automatic Transmission (City/Highway) 15 / 22
Emissions Classification LEV-II (LEV)
قديم 12-08-2008, 08:32 AM
الصورة الرمزية islam_galal
من انا؟: عبد من عباد الله
الموقع: Alexandria
افتراضي رد: صنعت للامريكان Hyundai Veracruz
جميلة بس الموديل اسمه إيه
مثلا هيونداي الأمريكاني ptmnlo123per154
عل صنعت للأمريكان أو لكولشن كان طالما لم تمتد فيها قدم فرعونيه فلن تنال البركة ptmnlo123per171
و طالما لم تمتد فيها يد فرعونية فلن تسؤ سمعتها ptmnlo123per144
و عجبي
ptmnlo123per160
قديم 12-08-2008, 09:33 AM
Wael Magdy Salah
معتقدش ديه تنزل هنا ابدا علشان اقل موتور فيها 3000CC
بس العربية ديه من العربيات اللى مقصود منها تغيير صورة هيونداى من شركة تصنع سيارات اقتصادية لشركة عالمية (السادس على العالم تقريبا دلوقتى) قادرة على صناعة سيارات فخمة بجوده عالية لاستهداف اسواق امريكا الشمالية واوربا كبديل لسيارات اسيوية زى لكسزس ونيسان وتويوتا
ادينا بنتفرج وهنشوف هيوصلوا لايه بس المهم ان كيا متتظلمش فى النص ptmnlo123per111
وديه شوية مواقع فيها تفاصيل عنها
http://en.wikipedia.org/wiki/Hyundai_Veracruz
http://worldwide.hyundai-motor.com/c...ruz/focus.html
http://www.motortrend.com/roadtests/...350/index.html
http://www.hyundaiusa.com
اخر موضوعاتى
قديم 23-06-2011, 03:11 AM
سمسوماه سمسوماه غير متواجد حالياً
سمسوماه is just really niceسمسوماه is just really niceسمسوماه is just really niceسمسوماه is just really niceسمسوماه is just really nice
امكانيااات حلوة اوى
على كدة تعمل سعرها كاااااام؟؟
مشكور اخى ع موضوعك
قديم 26-06-2011, 11:37 PM
الصورة الرمزية Mr.Mamo
Mr.Mamo Mr.Mamo غير متواجد حالياً
مدير مبيعات - جنرال أوتوموتيف
التخصص العملى: منسق مبيعات سيارات
هواياتي: العاب الكمبيوتر الجماعية(كره القدم )
الموقع: كفر الزيات - الغربيه
Mr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond reputeMr.Mamo has a reputation beyond repute
حتي العربيه دي كمان معتقتوهاش يا ابو نورا
بلاش تجيبوا سيره العربيات دي تاني لحسن غبور يقولوكوا نقفلها هنا
وساعه الكاش الغالي يبقي ببلاش
بس بجد
مجهود رائع وتركيز اكثر من رائع ونقل ولا اروع
تحياتي ليك يا ابو نورا يا جامد
Mr / Mahmoud Gamal
استشاري عام و مدير مبيعات سيارات
mahmoud_gamal_1000@yahoo. com
للتعاقد وشراء ( أي سياره ) الرجاء الالتزام بمواعيد الاتصال
نيسان : ا / فكري الحلوجي 01223311114
هيونداي
و شيفروليه
و اوبل
وجيلي ومازدا
: ا/ احمد دعباس 01210301121
( الاتصال من الساعه العاشره صباحا وحتي العاشره مساء ماعدا يوم الجمعه )
hyundai
الساعة الآن 03:29 AM.
