العودة   مصر موتورز مجتمع السيارات > تعديل السيارات والاكسسوارت > منتدى سبير كار - فرش واكسسوارات السيارات
منتدى سبير كار - فرش واكسسوارات السيارات قسم (تجارى) خاص بمنتجات سبير كار من فرش واكسسوارات السيارات
قديم 22-12-2009, 10:26 PM
الصورة الرمزية SpareCar
SpareCar SpareCar غير متواجد حالياً
مدير العلاقات العامة (سبير كار)
من انا؟: amir mohmd mstfa
التخصص العملى: general relation manager in spare car group
الموقع: cairo
SpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond reputeSpareCar has a reputation beyond repute
افتراضي احدث صب ووفر من سبير كار
sub wover
In past years, square, triangular, hexagonal and pentagonal subwoofers have tried to change & excite the marketplace.
The very simple fact is that if you have any given area, a square woofer will yield the most cone area which means higher SPL.
Even so, most square woofers have been poorly designed and do not meet the expectations.
The PSQ subwoofers are engineered from the ground up, and do yield higher SPL than any of our other subwoofers!
• 28% More Cone Area Than Round Woofer
• Stamped Steel Basket w/ Rolled Edges
• Aluminum Voice Coil Former
• Direct Wire Terminal Design
• Injection Molded Polypropylene Dust Cap
• Silver Polypropylene Cone
• Multi-Roll NBR Rubber Surround
• Vented Back Plate
• Suspension Integrated Tinsel Leads
AWB-12P 1000 Watts MAX active woofer box with built in amplifier
• Black piano finish
• Bass knob remote control
• P.W.M. Mosfet power supply
• Phase switch (normal/reverse)
• Thermal/short/over load protection circuit
• Power & distress indicator
• Variable low pass (50-150Hz)
• Soft delayed remote turn-on
• 0-12dB variable bass EQ at 45Hz
• Low & high level inputs
• Auto cooling
• Two 12” woofers (one passive without magnet)
• 4 Ohm impedance
• S/N ratio: 93dB
• Dimensions: 18.5” X14.75” X9.7”
AWB-10 800 Watts MAX active woofer box with built in amplifier
• Auto cooling
• Two 10” woofers (one passive without magnet)
• 4 Ohm impedance
• S/N ratio: 91dB
• Dimensions: 16” x 12.3” x 9.5”
Subwoofers do not need to have monster magnets to work properly. These allnew drivers are great for the modest powered system and yield great sound quality and much lower bass than the previous models. Each model features a molded Polypropylene cone and Butyl Rubber surround for great performance and durability. Dual 4-ohm voice coils are wound on Kapton formers for versatility and better heat dissipation. Check out the new entry level drivers and see for yourself that lost cost subs do not have to sacrifice performance!
• Polypropylene Injection Molded Cone
• Butyl-Rubber Surround
• KSV Kapton Voice Coil
• Nickel Plated 8 ga. Compression Wire Terminal
• Poly Cotton Spider
• Texture Coat Finish on Stamped Steel Basket
• Suspension Intergrated Tinsel Leads
قديم 24-12-2009, 01:00 AM
sikostar sikostar غير متواجد حالياً
sikostar is just really nicesikostar is just really nicesikostar is just really nicesikostar is just really nice
افتراضي رد: احدث صب ووفر من سبير كار
ايه ده يا جماعة
حد يتطوع ويترجم للناس
التعليم المجاني عامل عمايله
استاذ امير - برجاء توضيح الاسعار
شكرا
قديم 01-01-2010, 02:08 AM
wlelw2003 wlelw2003 غير متواجد حالياً
wlelw2003 is a jewel in the roughwlelw2003 is a jewel in the roughwlelw2003 is a jewel in the roughwlelw2003 is a jewel in the rough
ما شاء الله السعر كام
قديم 01-01-2010, 12:46 PM
kasten kasten غير متواجد حالياً
من انا؟: Mamado ElGolfawy
التخصص العملى: Designer
هواياتي: Cars
الموقع: El Haram
kasten is a jewel in the roughkasten is a jewel in the roughkasten is a jewel in the rough
الموضوع ده Copy - Paste
ياترى حد فاهم حاجه
وايه امكانيات الصبات وال RMS اد ايه والاسعار .. ؟؟
كله على كله ولما تشوفو قوله
ياريت الصور تكون من سبير كار والمنتج فيها مش صور من على النت
قديم 01-01-2010, 03:46 PM
happy401 happy401 غير متواجد حالياً
happy401 is on a distinguished road
الساعة الآن 01:01 PM.
