العودة   مصر موتورز مجتمع السيارات > السيارات الامريكية > فورد FORD
قديم 18-11-2009, 03:06 PM
الصورة الرمزية بدر بسيونى
مشرف الكورى
من انا؟: مصرى
التخصص العملى: كيميائى
افتراضي 2010 Ford Fusion
2010 Ford Fusion
Exterior Dimensions
Wheelbase (in.) 107.4
Length (in.) 190.6
Height - empty (in.) 56.9
Width without mirrors (in.) 72.2
Width with mirrors (in.) 80.1
Track Width - front/rear (in.) 61.7/61.3
Interior Dimensions
Head Room front/rear (in.) 38.7/37.8
Shoulder Room front/rear (in.) 57.4/56.5
Hip Room front/rear (in.) 54.0/53.3
Leg Room front/rear (in.) 42.3/37.1
Capacities: Passenger, Luggage, Fuel
Seating Capacity 5
Passenger Volume (cu. ft.) 100.3
Trunk Volume (cu. ft.) 16.5
Fuel Capacity (gal.) 17.5 FWD; 16.5 AWD
Engine Specifications (Gas-Powered Models)
Engine Type 2.5L Duratec 16V I4 Engine 3.0L Duratec 24V Flex Fuel V6 Engine 3.5L Duratec 24V V6 Engine
Drive Type Front-Wheel Drive Front-Wheel Drive; All-Wheel Drive Optional Front-Wheel Drive; All-Wheel Drive Optional
Transmission Type 6-Speed Manual, Standard; 6-Speed Automatic, Optional 6-Speed SelectShift Automatic 6-speed SelectShift Automatic
Engine Electronics EEC-V EEC-V EEC-V
Horsepower (SAE net @ rpm) 175 @ 6,000 240 @ 6,550 263 @ 6,250
Torque (lb.-ft. @ rpm) 172 @ 4,500 223 @ 4,300 249 @ 4,500
Compression Ratio 9.7:1 9.86:1 10.3:1
Final Drive Ratio 4.39:1 (Manual Transmission); 3.86:1 Automatic Transmission) 3.46:1 3.16 (Front-Wheel Drive) 3.16 (All-Wheel Drive)
Valve Lifters Direct Acting Mechanical Bucket Direct Acting Mechanical Bucket Direct Acting Mechanical Bucket
Fuel Delivery Sequential Multi-port Electronic Fuel Injection Sequential Multi-port Electronic Fuel Injection Sequential Multi-port Electronic Fuel Injection
Recommended Fuel Unleaded Regular Unleaded Regular Unleaded Regular
Exhaust Dual Chrome-Tipped with Catalytic Converter Dual Chrome-Tipped with Catalytic Converter Dual Chrome-Tipped Pipe-in-Pipe with Catalytic Converter
Fuel Economy
(EPA estimated mpg)
22 City/31 Hwy (Manual, S Model)
22 City/29 Hwy (Manual, SE and SEL Models)
23 City/34 Hwy (Automatic, S Model)
22 City/31 Hwy (Automatic, SE and SEL Models)
18 City/27 Hwy (FWD)
18 City/25 Hwy (AWD)
17 City/24 Hwy (AWD)
Engine block material Cast Aluminum Cast Aluminum Cast aluminum
Cylinder head material Cast Aluminum Cast Aluminum Cast aluminum
Electric Motor Specifications (Hybrid Model)
Motor type Permanent Magnet AC Synchronous Motor
Battery 275-Volt Nickel-Metal-Hydride (NiMH)
Chassis Specifications
Front Suspension Independent Short-and Long-Arm (SLA) with Double Lower Ball Joints, Stabilizer Bar
Front Shocks Hydraulic Gas-Pressurized
Rear Suspension Independent Multi-link Twist Blade with Stabilizer Bar
Rear Shocks Hydraulic Gas-Pressurized
Front and Rear Brakes Power Front/Rear Disc, Anti-Lock Brakes (ABS)
Traction Control AdvanceTrac™ with Electronic Stability Control (ESC) Standard
All-Wheel Drive Optional (requires V6 Engine)
Steering Electric Power-Assisted (Fusion S, SE, SEL, Hybrid); Hydraulic Power-Assisted (Fusion Sport)
Back to Top
التعديل الأخير تم بواسطة بدر بسيونى ; 18-11-2009 الساعة 03:22 PM
قديم 18-11-2009, 03:27 PM
MaXx MaXx غير متواجد حالياً
MaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond reputeMaXx has a reputation beyond repute
افتراضي رد: 2010 Ford Fusion
هي عربية هايلة ,,, و بالنسبة للسعر ؟؟ و ما اعتقدش انها نزلت عندنا مصر في فكري جروب
قديم 18-11-2009, 03:58 PM
m_o_sakr m_o_sakr غير متواجد حالياً
m_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond repute
تسلم ايدك يا استاذ بدر, التقرير جميل و العربيه جميله
و يا استاذ ماكس العربيه 3000 و 3500 سى سى فحتكون غاليه اوى فى مصر بس ممكن تلاقيها عند فكرى طلب خالص
(لا تنسى ذكر الله)
((لا تنسونا بالدعاء))
إحترس من السرعه
قديم 18-11-2009, 04:23 PM
tefa_king1 tefa_king1 غير متواجد حالياً
من انا؟: mostafa rabea
هواياتي: cars,races
الموقع: nasr city)cairo)
tefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond reputetefa_king1 has a reputation beyond repute
شكرا على الموضوع بس العربيه هتكون غاليه اوى فى مصر و زى ما قال sakr باشا لو هتتجاب لازم طلب خاص لحد ما الوكيل ينزلها مصر
قديم 18-11-2009, 06:05 PM
Gamed Gamed غير متواجد حالياً
Gamed has much to be proud ofGamed has much to be proud ofGamed has much to be proud ofGamed has much to be proud ofGamed has much to be proud ofGamed has much to be proud ofGamed has much to be proud ofGamed has much to be proud of
يا جمالو اد العربيات ولابلاش
الساعة الآن 06:19 PM.
