قديم 13-11-2009, 04:06 PM
الصورة الرمزية بدر بسيونى
مشرف الكورى
من انا؟: مصرى
التخصص العملى: كيميائى
افتراضي FAW Hongqi HQ3
Hongqi HQ3
ومن الداخل
THE TECHNICAL PARAMETERS OF HQ3
Technical ParametersHQ430HQ300
Type for Succeed personsType For GrandType For Business
General Construction
Overall Length(mm)49654965
Overall Width(mm)17951795
Overall Height(mm)14851485
Wheelbase(mm)28502850
Tread Front/Rear (mm)1535/15351535/1535
Turning Radius Min.(m)5.25.2
Luggage Compartment Capacity (VDA Type) (L)430430430
Nominal Total Weights (kg)177517301730
GR Clearance W/Axle (mm)150150
Parameter of Wind Resistance0.270.27
Safe Level of PassivityNCAP 5 NCAP 5
Power Assy
Marking of Engine3UZ-FE3GR-FE
Engine TypeV8/DOHC/32V (VVT-i)V6/DOHC/24V (DUAL-VVT-i)
Engine TechnicsETCS-i, ACIS
Engine Capacity(cc)42922995
Max Power and Rpm Max Power(Kw/rpm)206/5600170/6200
Max Torque(Nm/rpm)430/3400300/4400
Compression Ratio10.510.5
OilNo Plumbum Gasoline Beyond 95# No Plumbum Gasoline Beyond 95#
Fuel Tank Capacity(L)7070
EC(L/100km)11.310.1
EC90km/h(L/100km)6.95.8
0-100km/h ACCELERATED TIME(s)7.38.7
Max Speed(km/h)250235
TransmissionA761E 6ATA760E 6AT
Drive TypeEngine Front Configaration and Rear Drive Engine Front Configaration and Rear Drive
Tyre and Chassis
Tyre Size215/55 R17215/55 R17
Spare Wheel StandardFull DimensionFull Dimension
FR Suspension TypeDouble Wishbone, Coil, Have Subframe (Member) , Have Bar, Stabilizer
RR Suspension TypeMultilink, Coil, Have Subframe (Member), Have Bar, Stabilizer
FR/RR BrakeVentilated Disc Brake with Floating Caliper 1-Cylinder
Power Control SystemABS, EBD, BA, TRC, VSC, HAC
قديم 13-11-2009, 04:14 PM
الصورة الرمزية حازم شاهين
من انا؟: متسامح و حسن النية
الموقع: بورسعيد
افتراضي رد: FAW Hongqi HQ3
موضوع متميز كالعادة يا أستاذ بدر
قديم 13-11-2009, 04:16 PM
samehhefny samehhefny غير متواجد حالياً
مدير قطع غيار بابو غالى
samehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond reputesamehhefny has a reputation beyond repute
مفيش احلى من كدة
قديم 13-11-2009, 06:50 PM
العربيه تحفه بصراحه
تسلم ايدك يا باشا
قديم 13-11-2009, 07:05 PM
الصورة الرمزية محمد حنفى
محمد حنفى محمد حنفى غير متواجد حالياً
التخصص العملى: رسام كمبيوتر
هواياتي: حب السيارات
الموقع: مصر ام الدنيا
محمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond reputeمحمد حنفى has a reputation beyond repute
العربية جميلة جداً بس كنت عايز أعرف سعرها على سبيل المعرفة لا أكثر
وشكراً على الموضوع
الساعة الآن 05:23 AM.
