قديم 27-10-2009, 06:00 PM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Nissan recalls 163,000+ 2008-2009 Rogue crossovers over potential steering fault
Filed under: , ,
Nissan Rogue - Click above for high-res image gallery
On Sunday, we brought you word of a Nissan recall affecting 2009-2010 Altima sedans, and today, we bring you word of an even larger safety issue impacting its CUV lineup. The Japanese automaker is recalling 163,659 2008 and 2009 model year Rogue crossovers due to a potentially serious safety issue involving the crossover's steering gear housing cover. The National Highway Traffic Safety Administration is reporting that a screw could loosen, potentially causing the steering response to be compromised. In a worst-case scenario, the screw could come out completely, and if large steering inputs are made, the pinion shaft could come out, resulting in total loss of steering.
Affected Rogue owners will be contacted by Nissan to have the repair scheduled at the local Nissan dealer. The dealers will re-tighten the screw and install a cover plate to prevent the screw from loosening in the future. The recall is scheduled to begin in November, but if you're currently experiencing steering issues (or if this sort of thing keeps you up at night) you should stop by the local dealer right away. Hit the jump to read over NHTSA's press release, and if you have any questions, you can call Nissan at 1-800-647-7261.
Gallery: Nissan Rogue
[Source: NHTSA]
Continue reading Nissan recalls 163,000+ 2008-2009 Rogue crossovers over potential steering fault
Nissan recalls 163,000+ 2008-2009 Rogue crossovers over potential steering fault originally appeared on Autoblog on Tue, 27 Oct 2009 10:39:00 EST. Please see our terms for use of feeds.
Read | Permalink | Email this | Comments
أكثر...
الساعة الآن 02:05 AM.
