قديم 21-10-2009, 11:58 AM
الصورة الرمزية بدر بسيونى
مشرف الكورى
من انا؟: مصرى
التخصص العملى: كيميائى
Skoda yeti
لو سيارة اس يو فى تنتجها شركة اسكودا التشيكية
الابعاد
External dimensions
Length (mm):
4223
Width (mm):
1793
Height (mm):
1691
Clearance (mm):
180
Wheel base (mm):
2578
Luggage sill height (mm):
712
Wheel track front/rear (mm):
1541/1537
Internal dimensions
Elbow width in front/rear (mm):
1446/1437
Headroom in front/rear (mm):
1034/1027
Luggage room min./max. (l):
405/510*
Luggage room with rear seat backrests down/out (l):
1580/1760
Engines
The range of drive units for the Yeti includes two petrol and three diesel versions. All the units are four-cylinder, in-line, turbo-charged, installed crosswise in the front, with direct high-pressure fuel injection. They stand out due to their low consumption and meet the requirements of the EU 5 emissions standard.
Petrol engines
A four-cylinder 1.2 TSI/77 kW petrol engine will be a completely new feature of the إ koda range. The basic engine for the Yeti is destined for the version with front wheel drive. The range is supplemented by a
Diesel engines
Another new feature that appears in the Yeti model is a 2.0 TDI CR DPF engine, which is available in two performance variants, 81 and 103 kW. The trio is concluded by
a 2.0 TDI CR DPF engine that achieves a power
Manual gearboxes
The six-speed gearboxes provide pleasure thanks to precise and fast gear changes. The five-speed gearbox is available only for cars with front-wheel drive and
a 2.0 TDI CR DPF/81 kW engine.
Automatic gearbox
A technically advanced seven-speed gear box with the option of automatic or sequential manual gear selection will be offered with the 1.2 TSI/77 kW engine and front-wheel drive.
وده كمان الكتالوج
قديم 21-10-2009, 01:53 PM
m_o_sakr m_o_sakr غير متواجد حالياً
m_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond reputem_o_sakr has a reputation beyond repute
افتراضي رد: Skoda yeti
تسلم ايدك, بس شكلها مش حلو, عامله زى العربيات الصينى ptmnlo123per172
الساعة الآن 04:46 PM.
