العودة   مصر موتورز مجتمع السيارات > منتدى الصيانة و اﻹصلاحات > جسم و هيكل السيارة > دهانات السيارات
دهانات السيارات دهان وسمكرة السيارات
قديم 21-04-2015, 10:26 PM
الصورة الرمزية AbOnOrA
Aِِbo(Nora&Islam&Judy)
Wael Magdy Salah
من انا؟: ابو نورا واسلام
التخصص العملى: IT Consultant
الموقع: ام الدنيا مصر
تعديلات وعناية الطلاء الفولازى Line-X علم اقرب الى الخيال
LINE-X Protective Coatings
باختصار هو شىء اقرب للخيال عبارة عن طلاء بمجرد ان يتم رشة على اى مادة مهما كانت هشة يكسبها صلابة الفولاذ ومرونة المطاط
انا شخصيا مش قادر احدد التطبيق العلمى اللى وراه ايه بالظبط ياريت لو حد متخصص يفيدنا بس الفيديوهات مذهلة والتطبيقات لا حصر لها
شوفو الفيديو
ABOUT LINE-X
About LINE-X Protective Coatings
LINE-X is the nation’s leading provider of spray-on protective coatings. Our products are utilized in commercial, industrial, agricultural, military and custom applications. LINE-X specializes in spray elastomers polyurethanes and polyureas and has led the industry through many years of actual field testing. Specialized equipment is combined with the right materials and product knowledge to produce sprayable elastomeric coatings.
LINE-X is the recognized leader in this industry.
Examples of LINE-X leadership include:
Only company in the industry with dedicated full-time Research & Development staff and a 15,000 square foot research facility.
Recognized market leader in the spray-on truck bedliner industry consistently since 2005 (Source Frost & Sullivan Study 2006 and 2008)
First successful high temp/high pressure elastomeric bedliner.
First nationwide spray-on truck bedliners and protective coating franchise. Recognized in INC 500 and Entrepreneur Magazines. Also recognized in most major truck publications including Motor Trend, Truckin, Sport Truck, Street Trucks, Petersons 4-Wheel and Offroad and many more.
First commercially available pure polyurea.
First to develop a bomb blast coating. This coating has been tested by Army Corps of Engineers and the Air Force Research Laboratory. Product recognized by Popular Mechanics, Nationwide TV News Media, and Sixty Minutes II.
First to apply a non-skid pure polyurea onboard a U.S. Navy Submarine.
First spray-on product to meet MSHA requirements for acceptance of flame-resistance solid products taken into mines.
Only spray-on product in its category to be accepted by MSHA as non-strength enhancing mine sealant.
LINE-X consists of several different products.
All systems utilize a two-component, spray-in-place, 100% solids (no air pollution), thermoplastic polyurethane and polyurea.
There are two separate materials that are precisely dispensed through a high pressure, plural component internal mixing polyurethane spray machine. They are each heated to 120-140 degrees with the temperature maintained through a heated hose. Using high pressure, the materials are mixed internally at a 1:1 ratio at the tip of the spray gun. As the material is applied it takes less than 5 seconds for it to harden. As soon as LINE-X lands on the surface it's dry!
LINE-X products are a fast-cure, multipurpose series of coatings designed for a wide range of retail, commercial, and industrial uses. They exhibit excellent adhesion to most properly prepared surfaces. With its fast cure time it can be sprayed vertically and even overhead without running or dripping. There are no solvents associated with LINE-X products, which means there are no air pollutants or harmful environmental contaminates.
LINE-X Protective Coatings are resistant to most solvents and acids, making them ideal for industrial and commercial applications where corrosion is prevalent. Using LINE-X greatly extends equipment and vehicle life expectancy. It has a high "shore D" hardness rating, offering excellent impact resistance and superior tensile strengths (up to 6,600 psi) resulting in outstanding abrasion resistance. Because the material is sprayed there is a complete seal, making the coating "water tight".
With more than 500 locations in 46 countries, the goal of LINE-X is to consistently produce the highest quality and most reliable materials available. LINE-X is also focused on developing new protective coatings for a wide range of retail, industrial and other applications needing extreme protection.
رابط الشركة المصنعة
LINE-X Sprayon Bedliners, Protective Coatings, Truck Bed Coating, Floor Coating, Industrial Flooring
اخر موضوعاتى
قديم 24-04-2015, 11:58 PM
مصراوى شديد مصراوى شديد غير متواجد حالياً
مصراوى شديد will become famous soon enoughمصراوى شديد will become famous soon enough
افتراضي رد: الطلاء الفولازى Line-X علم اقرب الى الخيال
جميل جدا بس منين نجيبة ما كنش حد غلب يا صاحبى
كل يوم هانلاقى ابهار اكثر و اكثر سبحان الله و علم الانسان ما لا يعلم
coatings
أسعار السيارات فى مصر نبيل عبدالرحمن منتدى السيارات العام 3 04-11-2012 01:42 PM
الان جميع اسعار السيارات بمصر 2012 محمد اشرف منتدى السيارات العام 22 22-06-2012 08:27 PM
أحدث أسعار السيارات : شهر أكتوبر 2011 مبارك القناوى سوق السيارات المصرية 21 04-12-2011 04:58 AM
اخر اسعار السيارات فى شهر أغسطس 2011 فى مصر. مبارك القناوى سوق السيارات المصرية 18 11-09-2011 10:04 AM
اسعار جميع السيارات بمصر Ceasar سوق السيارات المصرية 3 05-09-2011 11:54 PM
الساعة الآن 01:34 PM.
