قديم 31-12-2014, 04:43 PM
خبر جديد خطوة بخطوة تشغيل السيارة بالماء 100% والاستغناء كلياً عن الوقود.
Sources
(1)Water-fuel car unveiled in Japan | Video | Reuters.com
http://worldwide.espacenet.com/publi...44714&KC=&FT=E
Searching PAJ information.
Breakthrough in hydrogen fuel production could revolutionize alternative energy market -- ScienceDaily
(2)http://patft.uspto.gov/netacgi/nph-P...2%0D%0A&d=PTXT
http://www.waterfuelcell.org
I'll get back to this mysterious Zero Point Energy a bit later as it appears in a number of these inventions. But suffice it to say, if the indications are correct, this could really be the solution we're looking for. Also, be sure to read some of the promising articles on John Kanzius' cancer-destroying tech.
Prolific inventor and Japanese national hero, Yoishiro Nakamatsu (inventor of the stiffy disk, CD, digital watch etc.), years ago developed a car engine that runs on nothing but tap water. Yes, tap water. Read about it here. There's an interesting interview with this colourful character here and the patent for his Enerex engine here. One wonders why we haven't seen this engine in production yet. Don't take my word for it but I hear the Yakuza in Japan have a habit of interfering with these sorts of things, perhaps for their own ends.
QUESTION: Fuel from water! Is it fact or fiction?
ANSWER: It is a Fact!
Split water molecules into hydrogen and oxygen and run your car on water!
Water can not burn unless the molecules that make up water are split into hydrogen and oxygen gases.
Learn how to build an electrolyzer fuel cell. We will teach you how to get fuel from simple tap water. You can then apply this knowledge to run any gasoline engine on water ( hydrogen ). Run your truck, car, lawnmower on water ( hydrogen on demand ). Any gasoline engine that uses pistons can be made to run on hydrogen! Turning water into a fuel is very high efficient and is actually very easy to do, and is safe if you follow our safety guidelines. You can also run hydrogen and oxygen in your car as an additive ( HHO ) to INCREASE your gas mileage. Or run your car totally on hydrogen alone using no gasoline at all!. The amount of gas that is output will depend on the proper construction of the cell itself and how large it is built. You can also use hydrogen to cook with or to heat your home with. We have a customer in England ( UK ) that is using hydrogen and oxygen to heat his entire home. His home has a water boiler radiator heating system. The boiler is connected to each room by pipes, which are connected to steam radiators that heat up each room. He made his own HHO brown gas type torches to heat the boiler. He said it works very well. For safety purposes always use hydrogen and oxygen flash back arrestors, the plans tell you the part numbers and the company where you can purchase these items. You can also make your own bubbler container to avoid gas flash back explosions. See these plans for more details.
Converting a gasoline engine to run on hydrogen can be easy, but the draw back is that the gasoline engine has never been as high efficient as an electric motor motors are. Gasoline engines have to many parts that can wear out. A free energy electric motor can last a life time! I highly recommend using our Fuelless Engine and our SP500 Generator to produce electricity. And they can both last a life time when constructed properly.
I remember a customer of ours that contacted us many years ago. He was very happy with our plans. As soon as he received our Fuel from Water plans he began to quickly put together a small hydrogen Fuel Cell. Using only an 8 oz glass of water, he had enough hydrogen to power his Bunsen burner for days and days! He said he was amazed that he could get that much energy from just one glass of water. The fuel cells are easy to build from supplies you can find in your home or at any hardware store in your area.
These plans are loaded with information! Including color photos and illustrations, as well as a supply list, and where to buy the parts needed to successfully construct a working Fuel Cell.
In July 2005, an American mechanic released most of the details of his simple conversion system which allows an ordinary car to use water as the only fuel. A long time has elapsed since then and it is highly probably that the inventor has been intimidated into silence since mid-August 2005. This has left the information as only a partial disclosure of this system. Some years ago, a similar system was developed by Adam Crawford of Scotland.
This vehicle was demonstrated to, and tested by, Automobile Association automotive engineers and shown on Scottish Television. Also, the scientific papers which accompany this document include several which show conclusively that explosions can occur in fog, water mist and under water, so there is no doubt at all that the principle behind the system shown below is definitely valid.
Since then, two other people have managed to get engines running briefly on this system, in spite of the lack of some important information, and it is expected that full success will follow as these excellent results are very recent. Many people have delayed, waiting to see if additional information would be given, before starting an attempted implementation of their own. A very small amount of extra information has now been given and is shown at the end of this document.
The inventor’s car, is run on a daily basis. It is a restored, eight-cylinder 1978 Chevy ‘Camaro’ with stock 350 (5.7litre) engine, no computer controls, automatic transmission, stock 4-barrel carburettor and stock fuel pump. The fuel tank has been replaced with a metal water tank with the filler cap vented to release heat and pressure. The exhaust was replaced with a new 2 inch pipe which is ducted into the water tank. The water tank has baffles inside it which also muffles the exhaust noise. The stock exhaust manifolds were used, but they will rust on the inside – custom stainless steel pipes would be best but these were not used due to their cost.
All of the stock ignition system is used and no changes have been made. A second battery was placed on the opposite side in the engine compartment. A 400 watt (800W peak) 110 volt 60Hz DC inverter was placed in the engine compartment on the passenger side and a fresh air duct located behind the grill directs air into covers placed around the inverter to keep it cool.
When the ignition switch is on, a relay turns the inverter on, the relay lead contains a 20 amp in-line fuse. This relay only turns the inverter on and off and has no other function. The inverter is connected to the battery via a positive wire and a negative wire (not the chassis). The inverter is not grounded to the car at any point and instead, is carefully insulated to ensure that accidental grounding never occurs.
The wire which would normally go to the spark plug is replaced by a wire which is taken to a box containing one pre-war mechanical twin-coil relay or vibrator per cylinder. Each of these wires drives its own dedicated ‘relay’, the current energises the relay coil but the other side of the relay coil is left unconnected. The wiring arrangement is shown in the diagrams below.
It is important that the electrical feed to each plug is fed via one wire to the plug cap and a second wire connecting to a washer clamped under the spark plug. This wiring is repeated for each of the spark plugs. To emphasise this, each spark plug should have two wires running to it, one to the cap and one to the washer clamped between the body of the spark plug and the engine block. The wiring is done with “12-2″ wire which is 2-core solid copper wire American Wire Gauge size 12 which has core diameters of 2.05 mm giving 3.31 sq. mm. per core, the nearest SWG size is 14. The under-plug washer can be made by bending the end of the solid core into a circle of appropriate size and then flattening the wire slightly.
In the relay box, the relays are positioned with a one-inch gap between them. It is important that the physical construction insures that all of the high-voltage connections are fully insulated should anyone open the relay box when the inverter is running. The batteries used are deep-cycle types with high cranking current ratings – this is important because the inverter must stay on when the engine is being started and it will cut out if the starter motor current drain pulls the battery voltage down excessively. The alternator is the stock 95 Amp type and it charges both batteries simultaneously. When the engine is started, the relays are heard clicking until the cylinders fire and after that, no sound can be heard from the relays. It is distinctly possible that the relays take up a fixed, immobile position when the engine is running. The diagram below marked ‘Effective circuit’ is based on that assumption, and it should be stressed that all of the diagrams are only what I understand from the information provided to date.
The engine timing has to be retarded for the car to run off water. This adjustment should be made to the point where the engine runs the best and this is likely to be different for each make of engine. The Chevy ‘Camaro’ engine runs best with the timing retarded by 35 . The spark plug gap used to be 65 thou. but is now set to 80 thou. (0.08″). The plugs used are the cheap ‘Autolite’ (25) copper core type. Using carburettor jets two sizes larger than normal, allows the engine to produce more power and rev higher than tick-over.
The engine tends to knock when first started from cold but it is likely that this can be overcome by using a heater on the water feed to the carburettor, raising the water temperature to say, 120 degrees Fahrenheit and fitted with a thermostat to disconnect the heater when the engine reaches its normal operating temperature. This car has been run 30,000 miles on water alone and covers some 300 miles per gallon as much of the water vapour in the exhaust condenses in the water tank.
The disadvantages: the car runs with slightly reduced power and the exhaust system will rust unless stainless steel replacements are used.
The inventor of this conversion wants to go on living a quiet life and does not want the nuisance value of high levels of interest. Consequently, he wishes to remain anonymous. He says: “I didn’t build this to sell or to get a patent on it, or make big bucks from the information. I did it because I could and I did. The only thing I can add is ‘just try it’.
Some points of note:
A car with this modification produces NO carbon dioxide and NO carbon monoxide, but since air is mixed with the gas combustion, it is likely that the greenhouse gas Nitrous Oxide is produced. But Nitrous Oxide dissolves reasonably well in water, so since the exhaust gasses are passed through the header tank which contains the water fuel, it is likely that this engine arrangement is a good deal greener than most.
The vented filler cap arrangement will not suit many European car designs which have a locking flap covering the filler cap. For these cars, it would probably be better if the gas exiting from the water tank is passed through a normal exhaust pipe, and the filler cap be a screwed airtight fitting.
رابط اول شرح بالعربى
كيفية تشغيل محرك السيارة باستعمال الماء
لربما لم يكن صاحب الفكرة الأولى، ولكنه اتخذ منحى آمنا في اختراعه ،من خلال توليد الغاز من الماء بطريقة نظيفة واستخدامه لتشغيل محرك السيارة كبديل عن البنزين والسولار اللذين يشح وجودهما في قطاع غزة.
مهدي القوقا( 47 ) عاما يقطن في مدينة غزة ويعمل نجارا، استطاع أن يشغل محرك سيارته بالماء، حيث تقوم فكرة اختراعه على تفكيك ذرات الهيدروجين والأكسجين من الماء، واستخدام الغاز الناجم كوقود بديل لتشغيل السيارة.
وأوضح القوقا لـ"فلسطين" أن استخراج الغاز يتم من خلال عملية تحليل كهربائي لجزئيات الماء، حيث يتم تركيب لوحة من معدن "الستانلس ستيل" في طبقات، ومن ثم يتم عمل قطبين سالب وموجب لتفكيك الماء، ومن ثم يتم عمل ثقوب داخل لوحة المعدن ثقب كمدخل للماء وثقب يمثل مخرج للغاز".
وبين أنه لسلامة عملية الذبذبة يتم وضع لوحين "عظم" _يستخدمهما الجزارين_ للفصل من أجل تفادي أي تماس كهربائي، بعد ذلك يشد على "البراغي" حتى لا يتسرب الماء، ومن ثم يتم تجليس الجهاز بالقرب من محرك السيارة فيوصل بأنبوب به ماء مضاف إليه مادة هيدروكسيد الصوديوم، موصول من أعلى بأنبوب يمر عبره الغاز المستخرج، ويدخل بعدها على وحدة فلترة ومن ثم غرفة المحرك.
ولفت القوقا إلى أن مادة هيدروكسيد الصوديوم أهميتها تكمن في تسهيل عملية ذرات الماء.
وأكد أن الطريقة التي يستخدمها آمنة بشكل كلي، ولا تشكل خطورة على مستخدمها لاستبعاد فكرة تخزين الغاز التي تؤدي إلى اشتعاله وانفجاره.
ونوه إلى أنه استطاع تحريك السيارة على السرعة الأولى فقط وليس السير لمسافات طويلة، لافتا إلى أن الجهاز لم يكتمل بعد ولكي يصبح قابلا للتنفيذ يحتاج إلى ماكينة شفط صغيرة لسحب الغاز لأنه خفيف ولا يخرج بسهولة، وذلك من أجل تشغيل المحرك بقوة أكبر.
وقال :" من المتوقع أن لتر الماء الواحد يحرك السيارة لمسافة 20 كيلو، في حال توافرت ماكينة الشفط واكتمل الاختراع".
وذكر القوقا أنه أمضى سنة ونصف في التجارب حتى وصل إلى الطريقة النهائية لاختراعه، وقدر تكاليف التجارب سبعة آلاف دولار، ولم يكتمل الاختراع بعد وهو بحاجة إلى تكاليف إضافية.
وأفاد أن مثيل الجهاز يستخدم في بعض الدول المتقدمة، ويسمى جهاز مساعد لتخفيف استهلاك البنزين بنسبة 25%، ويباع بـ1500 دولار، لافتا إلى أن بعض شركات اللحام بدأت تستخدم تقنية اللحام بالماء للمعادن الخفيفة.
وعن الفرق بين فكرة جهازه والاختراعات الأخرى، بين أن النظام الذي تعمل به الأجهزة الأخرى هي نظام الغاطس وهو نظام غير آمن ومعرض للانفجار والاشتعال، أما نظامه فهو آمن، لأن الخلايا (اللوحات) منفصلة عن الماء، حيث يتم إرجاع الماء بعد عملية تفكيكه داخل اللوحة على شكل رغوة محملة بالغازات والفقاعات الهوائية.
ولفت القوقا إلى أن جهازه يحتاج إلى دعم من قبل الحكومة أو المؤسسات الدولية، حتى تقل تكلفته ويكتمل بصورته النهائية.
وسبق القوقا اختراع نسب لفضل الكفارنة الذي استطاع تشغيل المولد الكهربائي بالماء بعد تفكيك ذراته كما يتم استخدامه في الطهي وتوليد التيار الكهربائي.
ويعتمد جهاز الكفارنة الذي يعمل في مجال التكييف والتبريد، على قيام اللوحة الإلكترونية على تحليل الهيدروجين في الماء وينتج عنه غاز له مميزات غاز الميثان قادر على الاشتعال، ويمكن استخدامه في مجالات عديدة.
و الاختراع يشبه جهاز "يو بي أس" ويعتمد على تحويل التيار الكهربائي من "أي سي" إلى "دي سي"، ويمكن أن يعمل الجهاز على الكهرباء العادية (دي سي) وشحنه بها، أو شحنه عن طريق المولد الكهربائي، أو الشحن ذاتيا كبطارية السيارة.
ويتطلع الكفارنة والقوقا إلى أن جهازهما يحتاجان إلى دعم وتمويل مؤسسات حكومية أو مؤسسات ومنظمات دولية، حتى يكتملا بصورتهما النهائية ويتمكن العامة من استخدامهما بشكل آمن وبأسعار مناسبة.
رابط تانى بالعربى
إخطار إعادة التوجيه
تسعى معظم شركات السيارات الكبرى لتدشين نماذج جديدة من سيارات تعمل على الهيدروجين عوضاً عن الوقود المحترق. تهدف هذه المحاولات إلى إنتاج سيارات صديقة للبيئة، ولكنها لا تزال في مراحلها الأولى، وتواجه عوائق تقنية كبيرة. ما يحدث في المعامل الكبرى نفّذ أيضاً في مختبر صغير، داخل منزل شاب فلسطيني. إذ تمكّن محمود عيد، 26 عاماً، من استخدام الماء كوقود طبيعي لتشغيل المركبات. محمود، من سكان مدينة البيرة، يعمل موظفاً في شركة كهرباء القدس. “المخترع” كما يدعوه أصدقاؤه، أصرّ على تنفيذ فكرة بقيت تدور في باله 5 سنوات، رغم كل المعوقات، وهو تسيير سيارة باستخدام الماء. تقوم فكرته على تحويل محرك السيارة إلى استخدام غاز الهيدروجين المستخرج من الماء، والاستغناء كلياً عن الوقود.
استغرق المشروع 5 سنوات، لم يكن يملك فيها عيد أي تسهيلات. لا مختبر يعمل فيه، ولا معدات. بمبادرة شخصية، تنقل تيسير بين مصر، الأردن والسعودية لتجميع معلومات وتلقي دورات حول غاز الهيدروجين وتفاعلاته الكيميائية وكيفية استخراجه واستخلاصه من الماء. بعد استيراد المواد الخام التي يحتاجها من السعودية، قام بتصنيع القطع اللازمة في منزله. من تجربة إلى أخرى، تمكن من تحويل سيارته للعمل باستخدام وقود الماء. لم يكتف بتغيير المحرك، بل جهز السيارة لتتناسب مع هذا التغيير.
يعتبر عيد اليوم أن بإمكانه تشغيل أي آلة أو جهاز أو مولد يعمل على النفط باستخدام الماء. حصل على براءة اختراع لتقنيته من وزارة الاقتصاد الوطني بدرجة امتياز وهو يسعى اليوم للحصول على براءة اختراع دولية. تواصل مع شركة مرسيدس علّها تتبنى الفكرة، لكونها مكلفة، ولأنه لن يتمكن من تغطية تكاليف تحويل سيارات أخرى. لكنه، يأمل ببيع السيارة الأولى، بعد وضع بعض اللمسات الأخيرة عليها، وإنتاج سيارة ثانية من مردودها.
طبيب وميكانيكى وكلمة فيها العبرة
بينما كان طبيب جراحة القلب يصلح سيارته عند الميكانيكي، كان الميكانيكي يفتح محرك سيارة الطبيب ويبدل فيه بعض الأشياء و يصلح البعض الآخر.
فأقترب الميكانيكي للطبيب وقال له :أتسمح لي بأن أسألك سؤال
فقال الطبيب بحذر : تفضل اسأل
فقال الميكانيكي : أنت تجري العمليات على
القلوب وأنا أيضاً أُجري الصيانة والتصليحات والعمليات على قلوب السيارات مثلك تماما ؟ …فلماذا تكسب أنت الكثير من الأموال بينما نحن مكسبنا أقل منكم بكثير!
فاقترب الطبيب من الميكانيكي وهمس في أذنه بكل هدوء : ( إذا كنت تستطيع )حاول ان تصلحها دون ان تطفئ المحرك !
العبرة : بعض الأمور تتشابه قوالبها لكن تفاصيل صغيرة تصنع الفارق !
لا تتعجل فهم الامور بطريقتك فلربما كان الاخرون على حق وانت المخطئ دائما استمع الى وجهات النظر الاخرى وارض بما قسمه الله لك ولا تتعجل النهايات فلربما كان حاضرك افضل
الصور المرفقة
نوع الملف: jpg 678261.jpg‏ (19.8 كيلوبايت, المشاهدات 3)
نوع الملف: jpg 30045942_Path.jpg‏ (88.5 كيلوبايت, المشاهدات 14)
نوع الملف: jpg 18545404_Path.jpg‏ (131.8 كيلوبايت, المشاهدات 6)
نوع الملف: jpg 69742271_Path.jpg‏ (142.1 كيلوبايت, المشاهدات 2)
نوع الملف: jpg 47135719_Path.jpg‏ (140.5 كيلوبايت, المشاهدات 4)
قديم 31-12-2014, 05:35 PM
الصورة الرمزية nktis
nktis nktis غير متواجد حالياً
من انا؟: عبد من عباد الله
التخصص العملى: صيدلي
هواياتي: الصيد والتربيه
الموقع: هنا
افتراضي رد: خطوة بخطوة تشغيل السيارة بالماء 100% والاستغناء كلياً عن الوقود.
:1201 05~352:
وأتت ملائكة النعيم كما روت*
روحي بطون أكفها خضراء*
صعدت بروحك والعبير يحفها*
والنور ترسم دربه الأنواء*
شرقت حشاشات النحيب وأينعت*
أكبادنا فبكاؤنا إيماء*
قديم 31-12-2014, 07:17 PM
:1201 05~352:
رابط صورة هامة
http://i.ytimg.com/vi/cVB3fvaMbrI/0.jpg
رابط صفحة هامة
إخطار إعادة التوجيه
The precise direct water injection system could improve vehicle
قديم 31-12-2014, 10:12 PM
nktis, zing0
قديم 01-01-2015, 06:42 AM
حضرتك شغلت عربيتك بالميه و لا لسة ؟
ماء, هيدروجين
رابطة مالكى الاكسل Good09 Hyundai Excel - اكسيل 1111 14-03-2018 03:52 PM
54 معلومة لصيانة وسلامة سيارتك ahmedsalah منتدى الصيانة العام 73 10-03-2015 06:06 PM
ماذا تعرف عن السيارات asalacenter منتدى السيارات العام 10 29-12-2011 12:41 PM
رفع السيارة لمدة ... samirsaid1 Hyundai هيونداى 0 01-12-2011 01:20 PM
قواعد القيادة درش سلامتك على الطريق 1 19-06-2008 11:40 PM
الساعة الآن 08:00 AM.
