العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > BMW > BMW News Archive
BMW News Archive BMW News Archive ارشيف اخبار البافارية من المواقع العالمية
قديم 25-08-2014, 02:30 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
افتراضي Evo pits BMW M3 against Porsche Macan in drag battle
Filed under: , , , , , ,
Evo pits the M3 against the Macan Turbo in a drag race
If you want to move five passengers in very rapid fashion and you've got a $75,000 budget, two newly introduced four-door models immediately come to mind - both are the highest performing vehicles in their respective segments. But which is faster off the line, to the 60-mile-per-hour benchmark or flat-out over an even longer run? Evo took both to paved aircraft runway to find out.
In lane one we've got the all-new Porsche Macan Turbo, which boasts a twin-turbocharged, 3.6-liter V6 rated at 400 horsepower and 406 pound-feet of torque. The Porsche is fitted with a seven-speed, dual-clutch gearbox, and the 4,244-pound crossover has the traction advantage of standard all-wheel drive. In lane two is the all-new BMW M3, powered by a twin-turbo 3.0-liter inline-six rated at 425 horsepower and 406 pound-feet of torque. It is also equipped with a seven-speed, dual-clutch gearbox, but only the rear wheels of the 3,595-pound sedan are driven. Both the BMW and Porsche arrive with launch control, which helps to remove driver error off the line.
Which automaker's launch control system is better off the line? Does all-wheel-drive grip give the crossover the advantage it needs to overcome its adversary's power-to-weight advantage? Will aerodynamics factor into the results? Which would you put in your garage, and why? The video may surprise you.
Continue reading Evo pits BMW M3 against Porsche Macan in drag battle
Evo pits BMW M3 against Porsche Macan in drag battle originally appeared on Autoblog on Sun, 24 Aug 2014 19:29:00 EST. Please see our terms for use of feeds.
أكثر...
الساعة الآن 12:16 AM.
