قديم 22-12-2013, 11:07 AM
الصورة الرمزية romeoalmansour
التخصص العملى: Engineer
هواياتي: reading and reading
الموقع: cairo
افتراضي موضوع كامل عن فحص وتنظيف الرشاشات
Injector Experts Checklist
Injectors are externally cleaned, visually inspected
Injectors are tested for resistance, inductance, shorts, and current draw
Leak, spray pattern, and flow rate tests are performed and recorded
A three step ultrasonic cleaning process in three separate ultrasonic tanks
A high pressure back-flush is performed to remove any remaining particles
Leak, spray pattern, and flow rate tests are re-performed and recorded
New filter baskets, o-rings, and pintle caps are installed if applicable
Problem Injectors
Symptoms that require service
Poor Performance
Engine does not reach full RPM
Increased fuel consumption
Poor idle
Starting Issues
Rough engine performance
Surging and bucking under various throttle loads
Smoke from the tail pipe
Detonation which can lead to catastrophic engine failure
Pollution
Leaking fuel injectors will cause
Increased Fuel Consumption
Poor Idle
Fuel odors inside and around the car
Hard Starting
Poor Emissions
Oil thinning which can lead to catastrophic engine failure
Hydro lock
الله العظيم أعلي وأعلم
قديم 22-12-2013, 11:13 AM
الموقع: cairo
افتراضي رد: موضوع كامل عن فحص وتنظيف الرشاشات
Electronic fuel injection radically changed the automotive landscape – with the wholesale adoption of multi-point fuel injection systems over the last 20 years, cars have become more powerful, more reliable, cleaner, and more fuel-efficient than their carbureted predecessors could have ever been. And while the heart of EFI, the common fuel injector, is a very simple piece of hardware capable of clicking away literally millions of times over its lifespan, things can and do go wrong. Bad gas, electrical or mechanical failure, and leaking seals can all rob performance and cause problems for even these very durable little solenoid valves
Fortunately, most fuel injectors can be serviced and brought back to health relatively inexpensively when they decide to misbehave – we can clean most of the common types, saving big money over new replacements and restoring missing performance
قديم 22-12-2013, 11:18 AM
الموقع: cairo
قديم 22-12-2013, 11:23 AM
الموقع: cairo
قديم 22-12-2013, 11:24 AM
الموقع: cairo
الساعة الآن 04:34 AM.
