العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > BMW > BMW News Archive
BMW News Archive BMW News Archive ارشيف اخبار البافارية من المواقع العالمية
قديم 07-11-2013, 02:40 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
افتراضي BMW unleashes 160-hp S 1000 R streetfighter motorcycle
Filed under: , ,
BMW Motorrad unveils the S 1000 R.
BMW Motorrad released the S 1000 RR superbike in 2010, but for those who'd like to take it down a (small) notch, the German motorcycle maker introduced the 2014 S 1000 R, a slightly less-ballsy version of the range-topping superbike, at EICMA on Tuesday.
In its transformation from 193-horsepower superbike to 160-hp sportbike, BMW detuned the 999cc inline four-cylinder engine a bit by lowering the redline from 13,000 RPM to 11,000 RPM, where peak power is made. Torque is rated at "approximately" 83 pound-feet (the RR makes 82.5 lb-ft), but more importantly, engineers tweaked the torque delivery in the R's favor by redesigning the cylinder-head ducts, modifying the camshaft profiles and reprogramming the engine management system. The result is seven lb-ft more torque than the RR up to 7,500 RPM. The R's torque peak occurs at 9,250 RPM.
The bike comes standard with ASC (automatic stability control) and "Race" ABS. Riders can choose between two modes, "Road" and "Rain," which adjust ABS and ASC settings to suit dry or wet roads. DTC (dynamic traction control) is available as an option, and with two modes, "Dynamic" and "Dynamic Pro," the system optimizes traction and helps riders achieve maximum acceleration.
The R uses an aluminum-alloy perimeter frame, in which the engine is a load-bearing structure. The front wheel is located by an adjustable upside-down fork, while the rear wheel is located by a dual swing arm. The bike weighs in at 456 pounds with a full tank of gas, and to slow the mass, the front brakes are a twin-disc setup with two four-piston calipers, while the rear gets a single brake disc and one caliper.
For more information on BMW's newest motorcycle, head on below to the press release. Be sure to check out the extensive photo gallery as well, which has 148 images showing every possible angle and detail.
Continue reading BMW unleashes 160-hp S 1000 R streetfighter motorcycle
BMW unleashes 160-hp S 1000 R streetfighter motorcycle originally appeared on Autoblog on Wed, 06 Nov 2013 18:29:00 EST. Please see our terms for use of feeds.
أكثر...
الساعة الآن 01:39 AM.
