العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > BMW > BMW News Archive
BMW News Archive BMW News Archive ارشيف اخبار البافارية من المواقع العالمية
قديم 30-09-2013, 01:10 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
افتراضي Mini announces thoroughly modern engines and chassis for 2014 Cooper
Filed under: , ,
Mini TwinPower engine
The 2014 Cooper will come with a three-cylinder engine and the Cooper S will get a 2.0-liter four-cylinder, both with Mini's TwinPower turbochargers.
We have seen spy photos of the all-new Mini Cooper. We have been teased about its drivetrain. Now we have the engine details confirmed by BMW.
The next Cooper, which will be officially unveiled at the Oxford factory in November and then at the Los Angeles Auto Show a couple of days later, will come with a 1.5-liter three-cylinder engine for the base model, and a 2.0-liter four-cylinder for the Cooper S. The base engine produces 134 horsepower and 162 pound-feet of torque, the plateau of which is reached at just 1,250 rpm. An overboost function allows up to 170 lb-ft for short bursts. The four-banger produces 189 horsepower and 207 lb-ft of torque (221 lb-ft with overboost). These power figures come thanks to MINI's TwinPower turbocharging and direct injection, technologies that are borrowed from Mini's parent company, BMW. In case you forgot, this is actually the first engine used by Mini sourced from BMW. The first of the reborn Cooper models was powered by a joint-venture engine with Chrysler. The second-generation uses an engine from Peugeot.
A higher-performing package will, of course, accompany the John Cooper Works edition that we're certain will be coming shortly after the new Cooper launches in Spring 2014.
Mini has chosen to hook its new engines to six-speed transmissions, which, contrary to the trend of adding more gears for more efficiency, is the same number of ratios found in the current Cooper. Stop-start will be standard as well. Cooper models equipped with navigation, meanwhile, will get new technology from BMW that can anticipate upcoming downshifts, such as when approaching an intersection or sharp turn.
Continue reading Mini announces thoroughly modern engines and chassis for 2014 Cooper
Mini announces thoroughly modern engines and chassis for 2014 Cooper originally appeared on Autoblog on Sun, 29 Sep 2013 18:00:00 EST. Please see our terms for use of feeds.
أكثر...
الساعة الآن 11:16 AM.
