قديم 14-07-2009, 02:40 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
BREAKING: Early Camaro SS manual transmission failures reported, factory hold issued
Filed under: , , , ,
2010 Chevrolet Camaro - Click above for a high-res image gallery
Sporadic reports have begun popping up in the Camaro5 forums about issues with V8-powered SS models equipped with the manual transmission. It seems that doing a hard launch or using the launch control system occasionally results in a broken output shaft, a serious failure that will most likely leave the car immobile and in need of repair. We spoke with General Motors spokesman Adam Dennison about the problem and, as this is being written, a factory hold has been put on deliveries of manual transmission V8 Camaros while Chevrolet engineering teams investigate the problem.
Based on the reports, the transmission issues may not be related to the launch control system as the failures seem to happen whether or not launch control is engaged. The Camaro SS uses the Tremec 6060 six-speed gearbox - the same transmission fitted to the Dodge Viper, Mustang GT500, Corvette Z06 and other performance cars - so this is likely a manufacturing issue with a batch of gearboxes.
Dennison told Autoblog that an engineering meeting is being held this evening to identify the cause and establish a timing for the fix - and a recall seems likely. In the meantime, if you have a manual model Camaro SS, you might want to go easy on the launches for now - and if you have one ordered, you'll have to wait a bit longer. Thanks to Bailey and Derrick for the tips!
[Source: Camaro5.com]
Photos Copyright (C)2009 Alex Núñez / Weblogs, Inc.
BREAKING: Early Camaro SS manual transmission failures reported, factory hold issued originally appeared on Autoblog on Mon, 13 Jul 2009 19:26:00 EST. Please see our terms for use of feeds.
أكثر...
قديم 14-07-2009, 02:49 AM
M7md_S3d M7md_S3d غير متواجد حالياً
M7md_S3d has much to be proud ofM7md_S3d has much to be proud ofM7md_S3d has much to be proud ofM7md_S3d has much to be proud ofM7md_S3d has much to be proud ofM7md_S3d has much to be proud ofM7md_S3d has much to be proud ofM7md_S3d has much to be proud ofM7md_S3d has much to be proud of
افتراضي رد: BREAKING: Early Camaro SS manual transmission failures reported, factory hold issued
يا ترى الكمارو فى فيلم ترانسفورمرز كانت كونسبت والا موديل تجارى
ولو كانت تجارى تبأه موديل كام؟
<<<<<M7md>>>>>
الساعة الآن 05:06 AM.
