العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > رينو RENAULT > Renault News Archive
Renault News Archive ارشيف اخبارى نقلاً عن المواقع العالمية
قديم 11-07-2009, 06:20 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Renault unveils updated Clio Renaultsport 200 hot hatch
Filed under: Euro, Hatchbacks, Renault
Renault Clio RS 200 - Click above for high-res image gallery
200. That's a mighty big number for such a tiny car, but it's the horsepower figure that Renaultsport's latest hot hatch packs beneath its bonnet. And while it may be only three measley horses more than the 197 version on which it's based and replaces, Renault's performance and motorsport division has worked to improve the aerodynamics and cut weight to make each one count more.
Complimenting the mid-cycle revised styling of the entire Clio range, the Clio RS 200 and 200 Cup benefit from Renault's Formula One program, with which the French automaker attributes the aerodynamic expertise implemented on its latest hot hatch. Air passes over the front splitter to feed the the revised 200-hp, 2.0-liter 16-valve four-cylinder engine, but it also goes underneath to the flat rear bottom and exits the fully functional rear diffuser. The design also pushes air around the wider front fenders, past the side vents and around the widened track to give the new Clio RS its performance edge. The aerodynamic enhancements gives the car an even meaner look, while customers can choose from a wider variety of look-at-me colors, contrasting with either black or anthracite-finish trim.
Inside it's all business: the compact steering wheel has perforated leather trim with a yellow strip to show when it's centered, and Recaro racing buckets are available along with leather upholstery. Unfortunately the car isn't available Stateside, but across the pond the new Clio Renaultsport 200 starts selling next month at £16,570, while hardcore enthusiasts can save a bit and get the even more focused, stripped-down Cup version for £15,750. Follow the jump for all the details in the press release, and check out the images in the gallery below.
Gallery: Renault Clio RS 200
[Source: Renault]Continue reading Renault unveils updated Clio Renaultsport 200 hot hatch
Renault unveils updated Clio Renaultsport 200 hot hatch originally appeared on Autoblog on Tue, 05 May 2009 09:30:00 EST. Please see our terms for use of feeds.
Permalink | Email this | Comments
أكثر...
الساعة الآن 07:46 AM.
