قديم 25-10-2011, 04:04 AM
الصورة الرمزية elmanahry
افتراضي رد: BRISK IS THE BEST SPARK PLUGS IN EGYPT NOW!
ال BERU TITANIUM اين يباعو العنوان ورقم التليفون CARS ADMIRE باشا وهل ممكن تعرف السعر لو سمحت
God grant me the serenity
DR Elmanahry
قديم 25-10-2011, 04:13 AM
نرجع لل VTA 3D بوجيهات تايوانى وشوف اداء البوجيهات
http://www.facebook.com/video/video....30175023693867
DR Elmanahry
قديم 25-10-2011, 09:13 AM
SMG
19862
08007647787
25760425
25779789
25781593
25781594
25781592
الشركة الهندسية للسيارات
قديم 25-10-2011, 09:18 AM
: 018A1D~146::f un_36_3_9[1]:
قديم 25-10-2011, 09:29 AM
حصرى End of the spark plug could be in sight !!!!!
End of the spark plug could be in sight, after scientists designed a laser which can start combustion engines.
Researchers claim that the approach would increase efficiency of engines, and reduce their pollution.
Spark plugs, which have changed little since their invention 150 years ago, are designed to ignite the fuel-air mixture near the spark gap.
But lasers create a more efficient burn, as the beams can be split to ignite the fuel mixture from multiple points deep in the cylinder.
Spark plugs are also susceptible to wear and tear problems and erode easily as they age, and the point at which a plug will spark is also unpredictable.
The idea has only become practical because of the advent of smaller lasers. A team from Romania and Japan has demonstrated a system that can focus two or three laser beams into an engine’s cylinders at variable depths.
“In the past, lasers that could meet those requirements were limited to basic research because they were big, inefficient, and unstable,” said Takunori Taira of the National Institutes of Natural Sciences in Okazaki, Japan. The new lasers, which are the same shape and size as spark plugs, can also be housed in ceramic casings which survive better in the high temperatures of a combustion engine.
They would offer hotter and more precise ignition than spark plugs, which in turn would improve an engine’s fuel efficiency and lower emissions. “Timing — quick combustion — is very important,” Mr Taira said. “The more precise the timing, the more efficient the combustion and the better the fuel economy.”
The team is in discussions to develop the technology with Denso, an international car component manufacturer.
The research will be presented at the Conference on Lasers and Electro-Optics in Baltimore in the US next month.
carsadmire
الساعة الآن 11:15 AM.
