قديم 31-05-2009, 02:35 PM
الصورة الرمزية SENY
SENY SENY غير متواجد حالياً
SENY has a spectacular aura aboutSENY has a spectacular aura about
افتراضي رد: أحدث سيارات شيرى الصينية
شكرا علي التقرير الجميل
وياريت يا جماعة اي حد ينزل تقرير بعد كده ينزل معاه اسعار
قديم 01-06-2009, 01:02 AM
الصورة الرمزية د0تامر محمد
د0تامر محمد د0تامر محمد غير متواجد حالياً
من انا؟: طبيب بشرى -كاتب قصة وروائى
التخصص العملى: طبيب بشرى
هواياتي: الكتابه خاصه الادبيه -السيارات
الموقع: الشرقيه
د0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond reputeد0تامر محمد has a reputation beyond repute
*كارى
*المواصفات
Engine1.6L
Transmission5MT
DriveFF
Engine
Engine code zSQR480ED
Number of cylinders4 in line
Valve mechanism8 valves DOHC
Fuel injection systemElectronic Multipoint Injection
Displacement (cc)1596
Bore×stroke (mm)79.96×79.52
Compression ratio9.75:1
Maximum power (Kw/rpm)65/5500
Maximum torque (Nm/rpm)130/3500
Fuel tank capacity (L)65
Fuel consumption at 90KM/h(Litres/100km)7.2
Maximum speed (km/h)141
Fuel typeUnleaded Gasoline
Dimensions & Weight
Length×Width×Height (mm)4610×1693×1855
Wheelbase (mm)2700
Front tread (mm)1456
Rear tread (mm)1446
Minimum ground clearance(full loading) (mm)135
Turning radius(minimum) (m)5.45
Kerb weight (kg)1300
Tyre Size185/70R1492H
Suspension & Brake
Front suspensionIndependent Macpherson strut with coil spring, single transverse link and dual acting tube damper
Rear suspension/
Front BrakeDisc
Rear Brake/
ABS+EBDOptional
*riich
*المواصفات
Engine1.3L
Transmission5MT
DriveFF
Engine
Engine code zSQR473F
Valve mechanism16 valves DOHC
Displacement (cc)1297
Bore×stroke (mm)73×77.5
Compression ratio10:01
Maximum power (Kw/rpm)61/6000
Maximum torque (Nm/rpm)114/3800~4500
Fuel tank capacity (L)45
Fuel consumption at 90KM/h(Litres/100km)7.7
Maximum speed (km/h)140
Dimensions & Weight
Length×Width×Height (mm)4040×1640×1900
Wheelbase (mm)2625
Front tread (mm)1420
Rear tread (mm)1420
Minimum ground clearance(full loading) (mm)150
Turning radius(minimum) (m)5.5
Kerb weight (kg)1220
Tyre Size165/70R14 85H
Suspension & Brake
Rear suspensionRigid axle suspension with leaf spring ,dual-acting tube damper
Front BrakeDisc
Rear BrakeDrum
ABS+EBDOptional
قديم 01-06-2009, 01:08 AM
الموقع: الشرقيه
******معلومات عن شركة شيرى*******
**تأسست تشيري في 97 لدعم
الاقتصاد في مدينة ووهو الصينية التي لم تلق دعماً إقتصادياً إلا في العام 95وقد أشترت أول مصنع لها يستخدم آلات و تكنولوجيا المحركات في اوروبامن شركة فورد الأمريكية مقابل 25 مليون دولار وبدأت إنتاج السيارات في عام 99 وكانت في بداية الأمر لا تمتلك موردين لقطع الغيار مما جعلها لا تمتلك رخصة لبيع السيارات داخل الصين ، وفي عام 2001قامت شركة شنغهاي لصناعة السيارات (سايك) بشراء ما نسبته 20% من أسهم الشركة، لتتولى شركة (سايك) مبيعات التجزئة لقطع غيار تشيري، وبالتالي حصلت تشيري على رخصة التصدير من الحكومة الصينية وقد كانت سوريا أول البلدان التي صدرت تشيري إليها سياراتها.
**في العام 2003 أسست تشيري متظمة للبحث والتطوير وبدأت العمل مع الشركات الأجنبية الاستشارية لتطوير وتحسين التكنولوجيا والجودة، وقد تعاقدت تشيري مع مهندس ياباني من متسوبيشى بإتفاقية خاصة بين الشركتين وجعلته رئيساً لأقسام الإنتاج، حيث أصبحت تستخدم أنظمة حديثة ومتطورة من طلاء السيارات إضافةً إلى الأنطمة المتقدمة من الإلكترونيات واستخدام محركات شركة متسوبيشى إما عن طريق استلامها جاهزة من مصنعتها أو عن طريق تجميع قطعها في مصانع تشيري.
**شركة تشيري لا تقوم بصناعة محركات مركباتها بنفسها حتى الآن وإنما يوجد بينها وبين شركة متسوبيشى إتفاقية تنص على تزويدها لشركة تشيري بالمحركات والقطع، حيث أن هناك بعض الطرازات يخصص لها محرك مجمع في شركة متسوبيشى وهناك بعض الطرازات يخصص لها محرك تجمعه شركة تشيري من قطع شركة حيث أن الشركتين تشتركان في نفس قطع الغيار وقطع المحركات ولكن القطع المخصصه لتشيري تقل عن الأخرى المخصصة للاخرىبنسبة 30% من السعر.
تشيري تييجو التي دخلت الأسواق العالمية بالإضافة إلى مجموعة من سيارات تشيري المختلفة الأحجام و المهام
**تسعى شركة تشيري للتواجد في جميع أنحاء العالم عبر وضعها لخطط استراتيجية وبدأ إنشاء شبكة من الوكلاء المحليين في الدول الآسيوية والأوربية وفي القارة الأمريكية، حيث تسعى تشيري للتواجد في السوق الأمريكية التي يتنافس عليها عدد كبير من الشركات الأمريكية واليابانية والكورية والألمانية حيث أن نجاح تشيري في أمريكا يعني تأثر الكثير من الشركات المنتجة في أمريكا بتناقص في حجم المبيعات نظراً للأسعار المغرية التي تضعها شركة تشيري على مركباتها إضافةً إلى المميزات التي تتمتع بها مركبات تشيري مقارنةً بنظيراتها من الشركات الأخرى، حيث تتواجد تشيري الآن في الشرق الاوسط وكانت سوريااولى محطاتها وبدأت بالإنتشار حتى وصلت للسعودية بجميع طرزاتها على أن يتم سحب الطرزات الغير مرغوب فيها حسب رغبة الشعوب في كل البلدان.
ففي القارة الأوروبية يفضلون السيارات الصغيرة والاقتصادية نظراً للارتفاع في أسعار الوقود وازدحام الطرقات وقلة أماكن الوقوف على عكس ما يحصل في السوق الشرق أوسطية حيث أنه هو المنتج الأكبر للنفط في العالم فيتجه الناس للسيارات كبيرة الحجم ذات المحركات الضخمة أحياناً.
**دخلت جميع مركبات شركة تشيري إختبارات السلامة و الأمان في القارة الأوروبية حيث أنها تتمتع بجميع أجهزة السلامة التي تقي الحوادث مثل موانع الانزلاق و الإنغلاق ... الخ ، إلى أنها لم تنجح في اختبار السلامة بسبب وجود ضعف في قاعدة المركبة ( الشاسية ) حيث أن شركة تشيري تسعى لتخفيض قيمة المركبة عن طريق تقليل كثافة قاعدة المركبة (الشاسية) عن طريق إفرغ المعدن من داخله ما يجعل المركبة رخيصة الثمن ولكنها عندما أجري عليها اختبار السلامة ( الاصطدام ) على سرعة 60كم/ساعة تحطمت المركبة حتى أن السائق الإفتراضي قد أصيب إصابات بالغة وبالتالي فقد حازت مركبات تشيري على درجة 0/5 في اختبار السلامة.
**يوجد العديد من المصانع لسيارات شيرى خارج حدود الصين منها روسيا و مصر . و لقد إشتهرت بعض فئات سيارات شيرى بمصر بإسم "إسبيرانزا" و قد لاقت قبول من المستهلك المصرى نظرا لرخص سعر السيارات مقارنة بمثيلاتها من نفس الفئة بل و بمواصفات و إمكانيات تفوق سعرها ,و توكيل شيرى بمصر هو دايو موتورز مصر "أبو الفتوح" و ادخل الوكيل بعض من سيارات شيرى إلى مصر و التى تناسب متطلبات السوق المصرى وهى : A5, A1,EASTER,QQ6,TIGGO أما QQ و COWIN و A11 فقدمت من وكيل أخر و هو CIG
التعديل الأخير تم بواسطة د0تامر محمد ; 01-06-2009 الساعة 01:14 AM
قديم 01-06-2009, 01:16 AM
الصورة الرمزية islam_galal
من انا؟: عبد من عباد الله
الموقع: Alexandria
موضوع رائع يا دكتور جزاك الله خيرا
بس الموديلين اللي في الاخر دول شكلهم بشع ptmnlo123per1125 يععععععععع
قديم 01-06-2009, 01:22 AM
الصورة الرمزية AbOnOrA
Aِِbo(Nora&Islam&Judy)
Wael Magdy Salah
من انا؟: ابو نورا واسلام
التخصص العملى: IT Consultant
الموقع: ام الدنيا مصر
رائع يا دكتور ptmnlo123per1114
واعتذر عن تأخرى فى الرد لانشغالى فى العمل على تطوير الموقع اليومين دول
اخر موضوعاتى
احدث موديلات اسبيرانزا, صور اسبرانزا, صور شيرى, شيرى الصينية
الساعة الآن 03:54 AM.
