المشاركة الأصلية كتبت بواسطة mmffor
غالي طبعا السعر
و برضه مقالة طويلة عريضة مفيهاش القوة بتاعة المحرك
المقاله للتاكيد ان السياره انجليزيه وبعدين
Dynamic aspects, SC7 currently has 1.5L, 1.8L two displacement models, the two engines are used with the Imperial match the same engine, 1.8L JL4G18 all-aluminum alloy engine, dual overhead cam 16 -valve structure The maximum power is 118/6200 (kw / rpm), maximum torque is 172/4200 (Nm / rpm), in the power to fully meet the daily use, the other CVVT technology, adding that it has better fuel economy the official nominal hundred kilometers constant fuel consumption for the 6.5L. 1.5L aluminum engine, dual- overhead camshaft 16- valve structure , and with CVVT technology can speed range in 6000-6200 to 78 kilowatts of power output, speed of 4,000 rpm in the issue of the maximum torque of 135 Nm moment.
