BMW رغم ما تعرضت له الشركة من ازمات كثيره اخرها ازمة شرائها لروفر الانجليزية الا انها مازالت تؤكد على ريادتها فلسلفتها الخاصة فى سيارتها التى تجمع بين الجمال متعة الاداء اشترت حقوق رولز رويس الانجليزية بالاضافة الى مينى ومن اشهر سيارتها BMW X5 X3 M6 M5 7 series - 5 series - 3 series |
أدوات الموضوع |
#181
Video: BMW turns Singapore buildings into amazing 3D Joy
Filed under: Etc., Marketing/Advertising, Videos, BMW ![]() BMW takes Singapore - Click above to watch video after the jump BMW advertising gurus have a big job ahead of them when it comes to supplementing their longstanding (and intentionally arrogant) "Ultimate Driving Machine" slogan with the company's new "Joy" campaign. Bimmer fanboys had lived and died by the company's proclamation of superiority for years, so it's going to take some coaxing to get BMW loyalists to swallow the new ads. Fortunately, BMW has never been one to skimp on advertising dollars, and the company has pulled a stunt in Singapore to make sure the ball gets rolling in the right direction. BMW has used two buildings for a massive, unique 3D projection display right in the middle of downtown Suntec City. Talk about cool. Two massive hands appear to disassemble the structures and rearrange them for their own diabolical, Joy-soaked plans. You can hit the jump to see the whole shindig for yourself. Thanks for the tip, John! [Source: YouTube via Bimmer Boost] Continue reading Video: BMW turns Singapore buildings into amazing 3D Joy Video: BMW turns Singapore buildings into amazing 3D Joy originally appeared on Autoblog on Thu, 27 May 2010 20:00:00 EST. Please see our terms for use of feeds. Permalink | Email this | Commentsأكثر... |
#182
BMW 530d passes crash test using emergency brake intervention
Filed under: Sedan, Europe, Safety, Technology, BMW, Diesel, Luxury ![]() The new 2011 BMW 530d has easily passed its first crash test evaluation while using active emergency brake intervention. Like a number of other cars to come to market recently, the 5 Series is available with a radar-based active cruise control system that can use the brake system to manage vehicle speed and keep the car a safe distance from the vehicle in front. Recently these systems have been enhanced with emergency brake intervention that allows full braking force to be applied if crash is imminent - even when the cruise control is not being used. However, current crash test procedures don't allow for the activation of such systems. For example, in the European 40 mile per hour frontal offset test, the vehicle is expected to crash at 40 mph. In the real world, active braking would reduce the speed of the impact, likely reducing severity as well. However, applying full brakes also causes the nose to pitch down and the cars occupants to shift position can alter the test's results. As more cars get these types of systems, they need to be accounted for in crash testing, and BMW is working with German testing agency DEKRA to develop new procedures. Check out the official press release after the jump. [Source: BMW] Continue reading BMW 530d passes crash test using emergency brake intervention BMW 530d passes crash test using emergency brake intervention originally appeared on Autoblog on Fri, 28 May 2010 11:01:00 EST. Please see our terms for use of feeds. Permalink | Email this | Commentsأكثر... |
#183
BMW 760 Li
م . نبيل عبد الرحمن مصر موتورز الإسكندرية
#184
![]() سامحك الله
لماذا هذا التعقيدptmnlo123per144 ألف شكر يا غالي |
#185
BMW experimenting with electronic noise canceling tech for diesels
Filed under: Technology, BMW, Diesel ![]() BMW sound engineer Manuel Reichle and the 635d - Click above for high-res image gallery When considering how to go about improving fuel efficiency and reducing emissions, we typically think of smaller engines, alternative fuels and electrification. One area that doesn't typically come to mind is that of sound design and acoustics. While the noises produced by a vehicle don't directly affect fuel efficiency, soundtracks are important because they are often a prime determinant in whether a given powertrain solution is acceptable to drivers and passengers. Companies like BMW, General Motors, Honda and others have been actively pursuing mechanisms of controlling noise at the source in order to create more flexibility for modifying the powertrains. A key example is the 2010 Chevrolet Equinox with its 2.4-liter inline four-cylinder gasoline engine. GM added active noise cancellation so it could allow the engine to spend more time running at lower speeds where the engine tends to make more of a low booming sound. Without the noise cancellation technology, the engine's sountrack would turn off drivers. Similarly, BMW has been carefully studying the structures of engine blocks and engine bays. Careful application of ribs and tuning of the structural shapes have allowed these structures to be made lighter without risk of excessive vibration. Similarly, adding insulation materials closer to the engine also reduces the amount needed overall as well as facilitating the use of other types of engines that might be inherently noisier. All of these factors play into making more efficient vehicles that are appealing to customers. After all, if consumers don't want to buy a vehicle for reasons that have nothing to do with function, all of the efficiency advantages they might offer will be left stuck in 'park.' [Source: BMW] Continue reading BMW experimenting with electronic noise canceling tech for diesels BMW experimenting with electronic noise canceling tech for diesels originally appeared on Autoblog on Mon, 31 May 2010 09:03:00 EST. Please see our terms for use of feeds. Permalink | Email this | Commentsأكثر... |
