أدوات الموضوع |
رد: محرك البنزين و محرك الديزل !!!يمكن أن تتلوث السيارات عن طريق الفطريات
هى المادة القاتلة دى عبارة عن اية فنيك ولا ديتول
ONE DAY YOU WILL SEE MY PLACE IN THE WORLD OF HISTORY |
This is a fuel Microbiocide which will kill bacteria !!!!!!!!!!!!!!!!!! vehicle‑vitamin ... FFI helpfully provide a good explanation of how the MPG- Caps supposedly work. ... but even if it is true, a solid fuel rocket is not a gasoline or diesel engine! A benefit to a rocket absolutely does not prove benefit to car engines. ... Improve Vehicle Gas Mileage, Save Money Increase MPG: Drive 7% – 14% Farther on the Same Amount of Fuel ... mpg gas caplet The MPG-CAP™ is a revolutionary combustion chamber treatment that increases fuel economy and reduces harmful exhaust emissions. MPG-CAPS™ consist of 100% active ingredients , with no dilutents or fillers, and are safe to use and handle. They are manufactured as a convenient, easy to use, solid caplet which you simply drop in your fuel tank prior to fill-up. Emissions testing with the use of MPG-CAPS™ has shown reductions of smog producing emissions such as hydrocarbons, carbon monoxide and nitrogen oxides. These emissions are harmful to the earth’s atmosphere and contribute to global warming. : 140109~347::1 40109~347::14 0109~347:: 286: التعديل الأخير تم بواسطة cars admire ; 27-09-2011 الساعة 03:24 PM |
محرك البنزين و محرك الديزل !!!يمكن أن تتلوث السيارات عن طريق الفطريات!!!
CARS ADNIRE باشا صاروخ المعلومات كالعادة شكرا جزيلا
God grant me the serenity to accept the things I cannot change courage to change the things I can and wisdom to know the difference DR Elmanahry
الكلمات الدليلية |
وقود الديزل |
