قديم 10-06-2008, 05:25 AM
الصورة الرمزية AbOnOrA
Aِِbo(Nora&Islam&Judy)
Wael Magdy Salah
من انا؟: ابو نورا واسلام
التخصص العملى: IT Consultant
الموقع: ام الدنيا مصر
Post مواصفات النترا مو 2005
2005 Hyundai Elantra
Technical Specifications
ENGINE
Type: Hyundai DOHC four-cylinder, inline
(transverse mounted)
Materials: cast iron block/aluminum cylinder head
Displacement: 2.0 liters (1975cc/120.5 cubic inches)
Bore x stroke: 82.0mm x 93.5mm (3.22 inches x 3.68 inches)
Compression ratio: 10.3:1
Horsepower: 138 @ 6,000 RPM (ULEV)
132 @ 6,000 RPM (SULEV)
Torque: 136 lb-ft @ 4,500 RPM (ULEV)
133 lb-ft @ 4,500 RPM (SULEV)
Valves per cylinder: four
Fuel system: electronic multi-port fuel injection
four-jet fuel injectors, in-tank fuel pump
Ignition: electronic distributorless ignition
Emission controls: three-way catalyst with EGR
TRANSMISSION
Five-speed manual
Gear ratios:
1st 3.62:1
2nd 2.05:1
3rd 1.37:1
4th 1.06:1
5th 0.84:1
Reverse 3.25:1
Final drive ratio 3.65:1
Four-speed automatic
Gear ratios:
1st 2.84:1
2nd 1.53:1
3rd 1.00:1
4th 0.71:1
Reverse 2.48:1
Final drive ratio 3.77:1
2005 Hyundai Elantra Technical Specifications / page 2
SUSPENSION
Front: Independent, MacPherson struts with offset coil springs, gas-filled hydraulic shock absorbers and anti-roll bar (GLS 4-door 23mm, GT & 5-door GLS 24mm)
Rear: Independent, strut with multi-links, coil springs, gas-filled hydraulic shock absorbers and anti-roll bar (GLS 4-door 12mm, GT & 5-door GLS 15mm)
STEERING
Type: power-assisted rack-and-pinion
Overall ratio: 15.4:1
Turns, lock to lock: 3.15
Turning circle: 32.5 feet (curb-to-curb)
BRAKES
Power assisted, dual-diagonal braking system
Front: 10.15-inch (258mm) vented disc with floating caliper and pad wear sensor
Rear: 8.0-inch (203mm) drum (GLS 4-door), 10.12-inch (257mm) solid rear disc (GT & GLS 5-door)
ABS: Optional, four-wheel, four channel
WHEELS 15 x 5.5-inch steel (GLS) 15 x 6J cast aluminum alloy (GT)
TIRES P195/60R15 all season, Michelin steel-belted radials,
Compact spare
ELECTRICAL
Battery: Maintenance-free, 12 volt, 60-amp hour
Alternator: 80 amp with internal IC regulator
EXTERIOR DIMENSIONS
4-door sedan 5-door hatchback
Wheelbase: 102.7 inches (2610mm)
Overall length: 178.1 inches (4495mm) 177.9 (4519mm)
Overall width: 67.9 inches (1724mm) 67.7 (1719mm)
Overall height: 56.1 inches (1425mm)
Track, front: 58.5 inches (1485mm)
Track, rear: 58.1 inches (1475mm)
2005 Hyundai Elantra Specifications / page 3
INTERIOR DIMENSIONS
Head Room
Front: 39.6 inches (1005mm)
Rear: 38.0 inches (964mm)
Leg Room
Front: 43.2 inches (1097mm)
Rear: 35.0 inches (889mm)
Shoulder room
Front: 54.7 inches (1390mm)
Rear: 53.5 inches (1360mm)
Hip Room
Front: 53.0 inches (1345mm)
Rear: 55.6 inches (1412mm)
EPA Passenger volume: 94 cubic feet 94 cubic feet
EPA Cargo Volume: 12.9 cubic feet (rear seat up) 26.6 cubic feet (rear seat up)
37.0 cubic feet (rear seat down/loaded to ceiling)
EPA Total Volume: 106.9 cubic feet 122.28 cubic feet
TOWING
With trailer brake 3086 lbs. (1400 kg)
Without trailer brake 1212 lbs. (550 kg)
CAPACITIES
Fuel tank: 14.5 gallons (55 liters)
Crankcase: 4.2 quarts
Coolant: 6.3 quarts
CURB WEIGHT
Manual trans: 2635 lbs. (1199 kg)
Auto trans: 2698 lbs. (1224 kg)
FUEL ECONOMY
City Highway
Manual trans: est. 27 mpg est. 34 mpg (ULEV)
est. 27 mpg est. 34 mpg (ULEV 5-door)
Auto trans: est. 24 mpg est. 32 mpg (ULEV)
est. 24 mpg est. 32 mpg (SULEV)
اخر موضوعاتى
قديم 17-05-2010, 12:02 AM
hgfdsa hgfdsa غير متواجد حالياً
hgfdsa is on a distinguished road
افتراضي رد: مواصفات النترا مو 2005
اقولك ايه منك لله مافهمتش منك اي حاجة روح يا شيخ وتعالي بسرعة
قديم 17-05-2010, 10:37 AM
الصورة الرمزية Devill Blood
Devill Blood Devill Blood غير متواجد حالياً
من انا؟: when u lose your dreams u become no thing at all
التخصص العملى: student at mansoura university - faculty of law - english section
هواياتي: أخبار السيارات-الرسم-الكمبيوتر والأنترنت
الموقع: المنصورة
Devill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond reputeDevill Blood has a reputation beyond repute
أشكرك أخى العزيز ولكن النسخة ال2000 سى سى لم ولن تنزل مصر
قديم 07-12-2010, 08:10 AM
eskenderiya eskenderiya غير متواجد حالياً
eskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond reputeeskenderiya has a reputation beyond repute
ايه الموضوع الغريب ده
اولا الموضوع باللغة الانجليزية فمنتدى مصرى
ماشى
انما كمان ديه مش نفس مواصفات الالنترا الى فمصر موديل 2005 !!!!!!1
قديم 23-05-2011, 12:34 AM
adamlion adamlion غير متواجد حالياً
adamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to behold
مشكور على المجهود لكن السيارة دى قليليه جدا بمصر
المتوافر 1600 cc .انا فهمت الموضوع لكن الغالبية لا .
وزى ما بيقولوا النبى عربى .مع الشكر . دا شكر وعتاب .ادم
قطع غيار السيارات الكورى استعمال الخارج remoo82 سوق قطع الغيار 142 18-03-2015 11:01 AM
فانوس النترا 2005 سبور tamerdsoky منتدى السيارات العام 0 06-03-2014 10:28 AM
كام جمارك النترا 2004 2005 mhopa2440 جمارك السيارات 1 17-07-2013 12:31 AM
النترا 2005 منوال عايز اغيرها باتوماتيك سرور Hyundai Elantra - النترا 1 27-10-2012 03:17 PM
مواصفات النترا وصورها akmal8000 Hyundai Elantra - النترا 12 02-11-2009 12:05 PM
الساعة الآن 01:27 PM.
